[Error] [carb.gym.plugin] Function fillActorRootStateTensor is not implemented
Hi @DDPG7,
As the RL examples use the Tensor APIs, they aren’t compatible with Flex, I’m afraid. While we do have a limited set of Tensor APIs available for Flex, they aren’t sufficient to run the RL examples.
I’ll also note that you seem to have a potential Vulkan issue with an integrated GPU being used for rendering. Make sure that you’re able to successfully run vulkaninfo and that you are rendering using the NVIDIA GPU. See Cannot Run the Examples for some info on that.
Take care,
-Gav
