I have the Jetson Nano devkit, which has JetPack 4.6.1 on it. For this specific tutorial, I have not done anything on the Jetson Nano yet because the instructions say to use a “computer running Linux (a Linux host) which has the GCC toolchain installed that is recommended for building L4T”. The Jetson Linux Version I am trying to build is 32.7.4, which I got from here:
For some reason, the link to the PDF instructions does not work when pasting here on the forums. I will try again below.
If for some reason that does not work, type this in your search browser: Jetson Nano Developer Kit 40-Pin Expansion Header Configuration filetype:PDF
I am using the devkit with SD module. I originally flashed it with the JetPack 4.6.1 version from the Jetson Download Center link below:
What is the best way to update to the latest JP4.6.4?
Also, I have had a difficult time trying to understand how to configure the 40 pins header with Jetson-IO. All I am trying to do is configure one pin to be a wake up pin. Do you have any suggestions on how to do this with Jetson-IO?
Do you suggest using SDKM to flash the Jetson Nano devkit on a x86_64 system with Ubuntu 18.04?
I was attempting to use Pin 36 as wake up pin when I was following the PDF instructions I listed above, and I have already modified and exported the pinmux spreadsheet according to those instructions. Do you suggest I follow different instructions? What do I do after modifying the spreadsheet? Is there something I do in SDKM after modifying the pinmux spreadsheet?
