Could you please guide how to fix this error?
(base) 2025-02-05 09:05:35 [mona@DOS ~]$ sudo systemctl daemon-reload && sudo systemctl restart docker
(base) 2025-02-05 09:05:47 [mona@DOS ~]$ sudo apt-get install git-lfs
Reading package lists... Done
Building dependency tree... Done
Reading state information... Done
The following packages were automatically installed and are no longer required:
python-pkg-resources python-setuptools
Use 'sudo apt autoremove' to remove them.
The following NEW packages will be installed:
git-lfs
0 upgraded, 1 newly installed, 0 to remove and 153 not upgraded.
Need to get 3,544 kB of archives.
After this operation, 10.5 MB of additional disk space will be used.
Get:1 http://us.archive.ubuntu.com/ubuntu jammy-updates/universe amd64 git-lfs amd64 3.0.2-1ubuntu0.3 [3,544 kB]
Fetched 3,544 kB in 1s (2,998 kB/s)
Selecting previously unselected package git-lfs.
(Reading database ... 723352 files and directories currently installed.)
Preparing to unpack .../git-lfs_3.0.2-1ubuntu0.3_amd64.deb ...
Unpacking git-lfs (3.0.2-1ubuntu0.3) ...
Setting up git-lfs (3.0.2-1ubuntu0.3) ...
Processing triggers for man-db (2.10.2-1) ...
(base) 2025-02-05 09:07:12 [mona@DOS ~]$ git lfs install --skip-repo
Git LFS initialized.
(base) 2025-02-05 09:07:15 [mona@DOS ~]$ mkdir -p ~/workspaces/isaac_ros-dev/src
(base) 2025-02-05 09:07:31 [mona@DOS ~]$ echo "export ISAAC_ROS_WS=${HOME}/workspaces/isaac_ros-dev/" >> ~/.bashrc
(base) 2025-02-05 09:07:47 [mona@DOS ~]$ source ~/.bashrc
2025-02-05 09:07:59 [mona@DOS ~]$ realsense-viewer
05/02 09:10:44,019 WARNING [137654437938752] (model-views.cpp:4229) Exception caught trying to detect presets: could not open directory: /home/mona/Documents/librealsense2/presets/
05/02 09:10:53,024 ERROR [137654395995712] (librealsense-exception.h:52) map_device_descriptor Cannot open '/dev/video4 Last Error: No such file or directory
05/02 09:10:53,033 ERROR [137654395995712] (sensor.cpp:572) acquire_power failed: map_device_descriptor Cannot open '/dev/video4 Last Error: No such file or directory
05/02 09:10:53,033 ERROR [137654395995712] (error-handling.cpp:78) Error during polling error handler: map_device_descriptor Cannot open '/dev/video4 Last Error: No such file or directory
05/02 09:10:54,781 WARNING [137655938001984] (model-views.cpp:4229) Exception caught trying to detect presets: could not open directory: /home/mona/Documents/librealsense2/presets/
05/02 09:10:59,784 ERROR [137653957690944] (librealsense-exception.h:52) map_device_descriptor Cannot open '/dev/video4 Last Error: No such file or directory
05/02 09:10:59,784 ERROR [137653957690944] (sensor.cpp:572) acquire_power failed: map_device_descriptor Cannot open '/dev/video4 Last Error: No such file or directory
05/02 09:10:59,784 ERROR [137653957690944] (error-handling.cpp:78) Error during polling error handler: map_device_descriptor Cannot open '/dev/video4 Last Error: No such file or directory
05/02 09:11:01,229 WARNING [137655938001984] (model-views.cpp:4229) Exception caught trying to detect presets: could not open directory: /home/mona/Documents/librealsense2/presets/
2025-02-05 09:11:36 [mona@DOS ~]$ realsense-viewer
05/02 09:12:03,030 WARNING [129274868663872] (model-views.cpp:4229) Exception caught trying to detect presets: could not open directory: /home/mona/Documents/librealsense2/presets/
2025-02-05 09:13:04 [mona@DOS ~]$ cd ${ISAAC_ROS_WS}/src
2025-02-05 09:13:14 [mona@DOS src]$ git clone -b release-3.2 https://github.com/NVIDIA-ISAAC-ROS/isaac_ros_common.git isaac_ros_common
Cloning into 'isaac_ros_common'...
remote: Enumerating objects: 1225, done.
remote: Counting objects: 100% (229/229), done.
remote: Compressing objects: 100% (140/140), done.
remote: Total 1225 (delta 150), reused 94 (delta 89), pack-reused 996 (from 2)
Receiving objects: 100% (1225/1225), 694.71 KiB | 2.22 MiB/s, done.
Resolving deltas: 100% (528/528), done.
2025-02-05 09:13:24 [mona@DOS src]$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common/scripts
2025-02-05 09:13:41 [mona@DOS scripts]$ touch .isaac_ros_common-config
2025-02-05 09:14:26 [mona@DOS scripts]$ echo CONFIG_IMAGE_KEY=ros2_humble.realsense > .isaac_ros_common-config
2025-02-05 09:16:10 [mona@DOS scripts]$ cd ${ISAAC_ROS_WS}/src/isaac_ros_common
2025-02-05 09:16:22 [mona@DOS isaac_ros_common]$ ./scripts/run_dev.sh -d ${ISAAC_ROS_WS}
Launching Isaac ROS Dev container with image key x86_64.ros2_humble.realsense: /home/mona/workspaces/isaac_ros-dev/
Building x86_64.ros2_humble.realsense base as image: isaac_ros_dev-x86_64
Building layered image for key x86_64.ros2_humble.realsense as isaac_ros_dev-x86_64
Using configured docker search paths: /home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker
Checking if base image nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble-realsense_abaf95dbad7ec06f92397c4406c5ffea exists on remote registry
Checking if base image nvcr.io/nvidia/isaac/ros:x86_64-ros2_humble_e46da4110307fe0d4de2a3060b8e9ba8 exists on remote registry
Checking if base image nvcr.io/nvidia/isaac/ros:x86_64_c14449e6861459ec29509bbf8d8ad1de exists on remote registry
Resolved the following 3 Dockerfiles for target image: x86_64.ros2_humble.realsense
/home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.realsense
/home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.ros2_humble
/home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.x86_64
Building /home/mona/workspaces/isaac_ros-dev/src/isaac_ros_common/scripts/../docker/Dockerfile.x86_64 as image: x86_64-image with base:
[+] Building 0.9s (3/3) FINISHED docker:default
=> [internal] load build definition from Dockerfile.x86_64 0.0s
=> => transferring dockerfile: 17.49kB 0.0s
=> ERROR [internal] load metadata for nvcr.io/nvidia/tritonserver:24.08-py3 0.8s
=> [auth] nvidia/tritonserver:pull token for nvcr.io 0.0s
> [internal] load metadata for nvcr.io/nvidia/tritonserver:24.08-py3:
Dockerfile.x86_64:16
14 | # https://docs.nvidia.com/deeplearning/frameworks/user-guide/index.html
15 | # https://docs.nvidia.com/deeplearning/frameworks/support-matrix/index.html
16 | >>> FROM nvcr.io/nvidia/tritonserver:24.08-py3 AS base-amd64
17 |
18 | FROM nvcr.io/nvidia/12.6.11-devel:12.6.11-devel-aarch64-ubuntu22.04 AS base-arm64
ERROR: failed to solve: nvcr.io/nvidia/tritonserver:24.08-py3: failed to authorize: failed to fetch oauth token: unexpected status from GET request to https://nvcr.io/proxy_auth?scope=repository%3Anvidia%2Ftritonserver%3Apull: 401
~/workspaces/isaac_ros-dev/src/isaac_ros_common
I am following these instructions Isaac ROS RealSense Setup — isaac_ros_docs documentation
