Please provide the following info (check/uncheck the boxes after clicking “+ Create Topic”):
Software Version
Target Operating System
Linux
Hardware Platform
SDK Manager Version
1.6.0.8170
Host Machine Version
native Ubuntu 18.04
I am trying to flash both Xavier A and B through the SDK manager. The installation guide displays a GUI as follows:
But when I am trying to flash I am getting a UI as below:
What should be the IP address,username and other details to be given as Xavier A and Xavier B will have different IP addresses.
Can you please clarify above point and also let me know how a each Xavier can be flashed separately if the above UI is available.
VickNV
July 28, 2021, 12:56pm
#3
Hi @aniruddha.nadgouda ,
I’ll check this and get back to you. Thanks.
VickNV
July 28, 2021, 1:19pm
#4
Could you try with 1.5.0.7774 SDK Manager (download via NVIDIA DRIVE Downloads | NVIDIA Developer )?
VickNV
July 28, 2021, 2:33pm
#5
Please try with fill in only “Password” of “Set the intial user details for the DRIVE OS” and click the flash button. Thanks.
@VickNV : Thanks for the solution, I could go ahead with flashing the hardware (Xavier A+B).
How can just 1 Xavier (Xavier A or B) be flashed from the same GUI if needed in future?
Is it that above part of flasher GUI can be used for flashing single Xavier by specifying the IP address?
Dear @aniruddha.nadgouda ,
We are working fixing the GUI issue and update you.
VickNV
July 29, 2021, 1:00pm
#9
AFAIK, it doesn’t support flashing single Xavier. Thanks.
We have fixed the GUI issue in sdkmanager. It will be available in future release.
VickNV
August 3, 2021, 2:24pm
#11
This issue was also fixed in the current sdkmanager version.
You can try again now. Thanks.
