ERROR_INCOMPATIBLE_DRIVER when using Isaac Lab?
Isaac Sim Version
5.0.0
Isaac Lab Version
2.2.1
Operating System
Other (please specify): CentOS 8.1 (cluster)
GPU Information
  • Model: TITAN RTX
  • Driver Version: 560.35.03
Topic Description
When RL training in Isaac Lab (using the default RSL-RL training code) on a TITAN RTX (driver version 560.35.03), I get the following errors:
2025-09-26T11:13:06Z [11,597ms] [Error] [carb.graphics-vulkan.plugin] VkResult: ERROR_INCOMPATIBLE_DRIVER
2025-09-26T11:13:06Z [11,598ms] [Error] [carb.graphics-vulkan.plugin] vkCreateInstance failed. Vulkan 1.1 is not supported, or your driver requires an update.
I see that the Isaac Sim technical requirements state that:
Versions greater than 535.255 have their version reported incorrectly in Vulkan, causing the driver to be misidentified as incompatible. A workaround is to disable the driver verification check with the command-line argument ā€˜ā€“/rtx/verifyDriverVersion/enabled=false’
I’ve tried applying this argument as follows:
./isaaclab.sh -p scripts/reinforcement_learning/rsl_rl/train.py --task=Ext-Isaac-Velocity-Rough-Anymal-C-v0 --headless --kit_args=ā€œā€“/rtx/verifyDriverVersion/enabled=falseā€
That didn’t work, so I then tried adding the argument in isaaclab/apps/isaaclab.python.headless.kit:
[settings]
# MGPU is always on, you can turn it from the settings, and force this off to save even more resource if you
# only want to use a single GPU on your MGPU system
# False for Isaac Sim
renderer.multiGpu.enabled = true
renderer.multiGpu.autoEnable = true
rtx.verifyDriverVersion.enabled = false # <- added it here
'rtx-transient'.resourcemanager.enableTextureStreaming = true
app.asyncRendering = false
However, this didn’t work either, and I still get the ERROR_INCOMPATIBLE_DRIVER error.
Additional Context
I’m training on a SLURM CentOS 8.1 cluster using Isaac Lab’s cluster training setup. My local machine (Ubuntu 22.04) has a compatible driver version (535.247.01) so the error doesn’t come up when I train on that instead.
Thank you for your interest in Isaac Lab. To ensure efficient support and collaboration, please submit your topic to its GitHub repo following the instructions provided on Isaac Lab’s Contributing Guidelines regarding discussions, submitting issues, feature requests, and contributing to the project.
We appreciate your understanding and look forward to assisting you.
