Error : IsaacROS release-4.0 Mission_client(IsaacSimExamples with jazzy ros2-bridge)
I try to run Mission_client(IsaacSimExamples) like below.
https://nvidia-isaac-ros.github.io/v/release-4.0/concepts/missions/isaac_ros_mission_client.html#tutorial-with-isaac-sim
But I found Error like below.
mission
[Our Environment]
Isaac Sim Version:5.1.0-full(download&install below link)
Operating System:Ubuntu 24.04
GPU Information:RTX 6000 Ada
CUDA : 13.0
I would appreciate if you check the behavior & tell us how to solve this problem.
Best regards
Thank you for your help.
Do you have any update on this?
Our customer is waiting for the answer.
I would appreciate if you tell us about the progress on this.
Best regards,
Thank you for reporting this, and apologies for delayed response. For now, you can install the package manually with:
sudo apt update
sudo apt install ros-jazzy-nav2-route
Please try that and let us know if it resolves the problem or you encounter any further issues.
Thank you very much for your kindness.
I really appreciate your help.
I’d like to check the behavior with your feedback.
Best regards,
