Error trying to run Gaze Redirect on an EC2 Instance
What I did so far
Launched an EC2 Instance - Windows Server 2019, g4dn.xlarge (T4 GPUS), Driver Version 560.94
https://github.com/NVIDIA/MAXINE-AR-SDK/releases
  • Extract all from Zip file
Maxine Windows ARD SDK (BIN) folder:
  • Extract all from Nvidia AR SDK
  • Drag and drop the “bin” folder to the main folder in the first download. It has a file named README.MD
  • GazeRedirect is located on \samples\GazeRedirect\
  • Change Name of the run file to run.bat if it isn’t already.
  • Duplicate the run.bat file and name the duplicate run.bat original.
  • edit run.bat file, copy paste from below: (need for live recording)
SETLOCAL
SET PATH=%PATH%;....\samples\external\opencv\bin;....\bin;
SET NVAR_MODEL_DIR=....\bin\models
GazeRedirect.exe --split_screen_view=false
  • run it from Command Prompt in the directory bar at the top (cmd)
After troubleshooting a couple of errors I reached:
ERROR: The GPU is not supported, line 77
ERROR: An error has occured while initializing Gaze Redirection
ERROR: an error has occured while creating a feature
[ WARN:1] terminating async callback
An error which I got on my laptop with a GTX 1650Ti hence why running it on an EC2 instance. T4 should be supported I believe. What should I do now? Is there anything I can do instead or anything that I messed up?
