Export blendshape meshes from a2f, and create morpher with these blendshape meshes in 3dsmax.Then use USD for 3ds Max 0.7 export usd to a2f, and when setup the blendshape solve, there will be some errors.
2024-04-10 13:48:29 [Warning] [omni.deform.shared.scripts.utils] Could not find the output point attribute on Node(“/World/audio2face/c_headWatertight_hi_WritePrimsV2”).
2024-04-10 13:48:29 [Error] [omni.graph.core.plugin] /World/audio2face/BlendshapeSolve_01: [/World/audio2face] Assertion raised in compute - arrays used as indices must be of integer (or boolean) type
2024-04-10 13:48:29 [Error] [omni.graph.core.plugin] File “e:\program data\nvidia\omniverse\pkg\audio2face-2023.2.0\exts\omni.audio2face.exporter\omni\audio2face\exporter\ogn\python\nodes\OgnBsSolveNode.py”, line 124, in compute
2024-04-10 13:48:29 [Error] [omni.graph.core.plugin] if db.internal_state.load_blendshape_data(prim_path):
2024-04-10 13:48:29 [Error] [omni.graph.core.plugin] File “e:\program data\nvidia\omniverse\pkg\audio2face-2023.2.0\exts\omni.audio2face.exporter\omni\audio2face\exporter\ogn\python\nodes\OgnBsSolveNode.py”, line 60, in load_blendshape_data
2024-04-10 13:48:29 [Error] [omni.graph.core.plugin] poseMat[indices, :] = offsets.copy()
2024-04-10 13:48:29 [Warning] [omni.usd] Warning (secondary thread): in ProcessPropertyChange at line 522 of W:\ac88d7d902b57417\USD\pxr\usdImaging\usdSkelImaging\skeletonAdapter.cpp – Unhandled ProcessPropertyChange callback for cachePath </World/Claire_bs_3dsmax/Bones/bs_anim> in UsdSkelImagingSkelAdapter.
3ds max blendshape problem.zip (72.6 MB)
