Error while attempting to install the required GXF extensions
I am encountering an error while attempting to install the required GXF extensions using the following command:
registry extn install -e MultimediaExtension
Here are the commands I executed:
registry extn install -e StandardExtension
registry extn install -e PythonCodeletExtension
registry extn install -e SampleExtension
The installation works fine for the other extensions, but the MultimediaExtension fails with the following error:
2024-11-25 16:40:57,689 - Registry - ERROR - File download failed /home/anavid-server/.cache/nvgraph_workspace/gxf/multimedia/py_srcs.tar.gz
2024-11-25 16:40:57,690 - Registry - ERROR - Failed to download py srcs for extension: MultimediaExtension:2.3.0
Failed to install extension MultimediaExtension:None
I referred to the official documentation:
NVIDIA Metropolis Graph Tools Guide
https://docs.nvidia.com/metropolis/deepstream/dev-guide/graphtools-docs/docs/text/GraphComposer_Getting_Started.html#
However, I could not find a clear solution to this issue. Here are the steps I have already tried:
Verified internet connectivity.
Cleared the cache at the following location:
rm -rf /home/anavid-server/.cache/nvgraph_workspace
Retried the installation command.
Despite these attempts, the issue persists.
I used deepstram 6.3.
Could you please assist me in resolving this problem?
Thank you in advance for your support.
The DeepStream 6.3 and Graph Composer 3.0.0 are very old. Please upgrade to DeepStream 7.1 and Graph Composer 4.1.0. There is no such issue with the latest version.
