Issue Installing Required GXF Extensions
I am encountering an error while attempting to install the required GXF extensions using the following command:
registry extn install -e MultimediaExtension
Here are the commands I executed:
registry extn install -e StandardExtension
registry extn install -e PythonCodeletExtension
registry extn install -e SampleExtension
The installation works fine for the other extensions, but the MultimediaExtension fails with the following error:
2024-11-25 16:40:57,689 - Registry - ERROR - File download failed /home/anavid-server/.cache/nvgraph_workspace/gxf/multimedia/py_srcs.tar.gz
2024-11-25 16:40:57,690 - Registry - ERROR - Failed to download py srcs for extension: MultimediaExtension:2.3.0
Failed to install extension MultimediaExtension:None
I referred to the official documentation:
NVIDIA Metropolis Graph Tools Guide
https://docs.nvidia.com/metropolis/deepstream/dev-guide/graphtools-docs/docs/text/GraphComposer_Getting_Started.html#
However, I could not find a clear solution to this issue. Here are the steps I have already tried:
Verified internet connectivity.
Cleared the cache at the following location:
rm -rf /home/anavid-server/.cache/nvgraph_workspace
Retried the installation command.
Despite these attempts, the issue persists.
I used deepstram 6.3.
Could you please assist me in resolving this problem?
Thank you in advance for your support.
Hi @amine.ghamgui.anavid ,
We suggest you to raise this request in Deepstream Forum.
