I am trying to install Eclipse marketplace as new software to Nsight on my host machine.
During the installation I get the error message:
An error occurred while installing the items
session context was:(profile=cider, phase=org.eclipse.equinox.internal.p2.engine.phases.Install, operand=null → [R]org.eclipse.equinox.launcher.gtk.linux.x86_64 1.1.200.v20140603-1326, action=org.eclipse.equinox.internal.p2.touchpoint.eclipse.actions.InstallBundleAction).
The artifact file for osgi.bundle,org.eclipse.equinox.launcher.gtk.linux.x86_64,1.1.200.v20140603-1326 was not found.
I can not find the file on my disk. Where can I find it or how can I solve the issue?
Thank you
I’ve installed Eclipse marketplace you mentioned above without any problem. External Media External Media
Could you please let me know where the error occurred? Thanks.
Then I choose the marketplace client from General Purpose Tools.
After that I click “Next” and "Finish in the next window. After that I accept two certificates, the installation continues before it finishes I get the Error message:
‘Installing Software’ has encountered a problem. An error occured while installing the items
I kind of found the issue now. When I start Nsight from the command line by typing “nsight”, I am not able to install Eclipse Marketplace. When I start it from the search, I can install it without a problem.
I don’t know why that’s the case but it is working now.
I am facing the same issue. The problem appears for me with with fresh installs of of Kubuntu 20.04 as well as 18.04 running in VirtualBox. Both/usr/bin/nsight and /usr/lib/nvidia-nsight/nsight are affected.
