Errors Following Tutorial for Drive TurtleBot: Seeking Solutions
I followed the tutorial but after I sent the command to /cmd_vel topic. The robot didn’t move and the following errors appeared.
Tutorial Link:
https://docs.omniverse.nvidia.com/isaacsim/latest/ros2_tutorials/tutorial_ros2_drive_turtlebot.html
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh articulation /World/turtlebot3_burger
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/wheel_right_link (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/wheel_left_link (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/imu_link (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/base_scan (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/base_footprint (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/caster_back_link (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh body /World/turtlebot3_burger/base_link (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh joint /World/turtlebot3_burger/base_link/wheel_right_joint (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh joint /World/turtlebot3_burger/base_link/wheel_left_joint (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh joint /World/turtlebot3_burger/base_link/scan_joint (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh joint /World/turtlebot3_burger/base_link/imu_joint (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh joint /World/turtlebot3_burger/base_link/caster_back_joint (no suitable physics object)
2024-10-02 18:19:56 [82,188ms] [Error] [omni.isaac.dynamic_control.plugin] Failed to refresh joint /World/turtlebot3_burger/base_footprint/base_joint (no suitable physics object)
I put /World/turtlebot3_burger as the targetPrim and delete Articulation Root from turtlebot3_burger/base_footprint, then add Articulation Root to turtlebot3_burger.
The issue remains unresolved
Could anyone offer insights or solutions to address these errors?
Thank you in advance for your time and assistance.
I managed it!
Thank you!!
