2021-12-12 02:02:23 [Warning] [gpu.foundation.plugin] Raytracing is not supported on GPU: 1. Skipping this device.
2021-12-12 02:02:23 [Warning] [carb.graphics-direct3d.plugin] Leaking graphics objects. Live device refcount: 5. Release all the graphics objects prior to destroying the device.
2021-12-12 02:02:23 [Warning] [gpu.foundation.plugin] Different GPUs have different availalbe VRAM. The texture streaming system will be limited to the lower VRAM number
2021-12-12 02:02:23 [Warning] [carb.renderer.plugin] Not starting stream server for live stream, due to conflicts with cloudXR
There’s only one GPU on the MSI Stealth laptop and it’s an RTX 2080, so why would I be getting these errors? All my other renderers pick it up fine. Thanks in advance :)
