@SivaRamaKrishnaNV Hi, I’ve followed the steps in the thread about the GUI not showing up after flashing. I’ve re-flashed the device with the --clean flag, restarted gdm 5 tried multiple cables and monitors, including DP-to-DP which didn’t solve the problem.
Here are my diagnostic logs.
benchdev2@tegra-ubuntu:~$ sudo service gdm status
[sudo] password for benchdev2:
Sorry, try again.
�● gdm.service - GNOME Display Manager
Loaded: loaded (/lib/systemd/system/gdm.service; static; vendor preset: en>
Active: active (running) since Wed 2024-04-24 13:43:34 UTC; 5min ago
Main PID: 2084 (gdm3)
Tasks: 3 (limit: 34419)
Memory: 3.8M
CGroup: /system.slice/gdm.service
�└�─2084 /usr/sbin/gdm3
Apr 24 13:43:34 tegra-ubuntu systemd[1]: Starting GNOME Display Manager...
Apr 24 13:43:34 tegra-ubuntu systemd[1]: Started GNOME Display Manager.
Apr 24 13:43:34 tegra-ubuntu gdm-launch-environment][2088]: pam_unix(gdm-launch>
Apr 24 13:43:35 tegra-ubuntu gdm-launch-environment][2088]: pam_unix(gdm-launch>
Apr 24 13:43:35 tegra-ubuntu gdm3[2084]: GdmDisplay: Session never registered, >
Apr 24 13:43:35 tegra-ubuntu gdm-launch-environment][2307]: pam_unix(gdm-launch>
lines 1-15/15 (END)
Output for cat /etc/nvidia/rootfilesystem-manifest/driveos-rfs.MANIFEST.json
benchdev2@tegra-ubuntu:~$ cat /etc/nvidia/rootfilesystem-manifest/driveos-rfs.MANIFEST.json
"Copyright": [
"# Copyright (c) 2022-2023, NVIDIA CORPORATION & AFFILIATES.",
"# All rights reserved.",
"# NVIDIA CORPORATION, its affiliates and its licensors retain all intellectual",
"# property and proprietary rights in and to this software, related",
"# documentation and any modifications thereto. Any use, reproduction,",
"# disclosure or distribution of this software and related documentation",
"# without an express license agreement from NVIDIA CORPORATION or its",
"# affiliates is strictly prohibited."
"OS": "linux",
"Parent": "",
"Output": "driveos-oobe-desktop-ubuntu-20.04-rfs",
"Distro": "focal-fossa-20.04",
"Base": "${BASE_DIR}/ubuntu-base-20.04.1-base-arm64.tar.gz",
"FilesystemType": "standard",
"AssociatedFilesystems": [
"driveos-oobe-desktop-rfs-user-metadata.CONFIG.json",
"driveos-oobe-desktop-rfs-user-data.CONFIG.json"
"Mounts": {
"/home/": {
"Device": "#/dev/vblkdev3",
"MountOptions": "defaults",
"Type": "ext4"
"/persistence/": {
"Device": "#/dev/vblkdev1",
"Type": "ext4"
"/etc/": {
"Device": "#overlayfs",
"MountOptions": "lowerdir=/etc/,upperdir=/persistent/driveos/security/etc,workdir=/persistent/driveos/security/tmp/etc/"
"Type": "overlayfs"
"PreInstalls": {
"${BUILD_FS_DIR}/helpers/copy_cuda_keyring.sh": "host",
"${BUILD_FS_DIR}/helpers/create_dummy_host_keys.sh": "host"
"CopyTargets": [
"Manifest": "${COPYTARGETYAML_DIR}/copytarget-configs.yaml"
"PostInstalls": {
"/usr/local/cuda/bin/cuda-install-samples-11.4.sh /opt/nvidia/drive-linux": "target",
"/etc/nvidia/run-once/nv-run-once-run-ldconfig": "target",
"/etc/nvidia/run-once/nv-run-once-run-depmod": "target",
"${SCRIPTS_DIR}/dwx_customizations.sh": "target_copy"
"FilesystemCleanup": [
"/var/tmp/*",
"/etc/apt/sources.list.d/local-apt-repos.list",
"/etc/ssh/ssh_host_dsa_key*",
"/etc/ssh/ssh_host_rsa_key*",
"/tmp/*",
"/etc/ssh/ssh_host_ecdsa_key*",
"/var/cache/apt/srcpkgcache.bin",
"/var/cache/apt/pkgcache.bin",
"/etc/ssh/ssh_host_ed25519_key*"
"Mirrors": [
"Type": "local_debian_mirror",
"Path": "${MIRROR_DIR}"
"Type": "local_debian_folder",
"Path": "${MLNX_OFED_DIR}"
"Path": "${MIRROR_DIR}/"
"Type": "debian",
"Path": "${CUDA_INSTALL_DEB_DIR}/${CUDA_TARGET_Linux}"
"Type": "debian",
"Path": "${TRT_INSTALL_DEB_DIR}/${TRT_TARGET_Linux}"
"Type": "debian",
"Path": "${CUDNN_INSTALL_DEB_DIR}/${CUDNN_TARGET_Linux}"
"Path": "${NVIDIA_DOCKER_DIR}"
"Path": "${DWSDK_DIR}"
"Path": "${NV_MIRROR_DIR}/standard/"
"SELinux": {
"SetFiles": "${SELINUX_SETFILES_PATH}",
"PolicyFile": "${SELINUX_POLICY_PATH}",
"ContextFile": "${SELINUX_CONTEXT_PATH}"
"DebianPackages": [
"accountsservice=0.6.55-0ubuntu12~20.04.6",
"acl=2.2.53-6",
"adduser=3.118ubuntu2",
"adwaita-icon-theme=3.36.1-2ubuntu0.20.04.2",
"alsa-base=1.0.25+dfsg-0ubuntu5",
"alsa-utils=1.2.2-1ubuntu2.1",
"apg=2.2.3.dfsg.1-5",
"apt=2.0.10",
"apt-clone=0.4.1ubuntu3",
"aptdaemon=1.1.1+bzr982-0ubuntu32.3",
"aptdaemon-data=1.1.1+bzr982-0ubuntu32.3",
"archdetect-deb=1.117ubuntu7",
"base-files=11ubuntu5.7",
"base-passwd=3.5.47",
"bash=5.0-6ubuntu1.2",
"bash-completion=1:2.10-1ubuntu1",
"bc=1.07.1-2build1",
"binutils=2.34-6ubuntu1.6",
"binutils-aarch64-linux-gnu=2.34-6ubuntu1.6",
"binutils-common=2.34-6ubuntu1.6",
"bluez=5.53-0ubuntu3.6",
"bogl-bterm=0.1.18-13ubuntu2",
"bridge-utils=1.6-2ubuntu1",
"bsdutils=1:2.34-0.1ubuntu9.4",
"bubblewrap=0.4.0-1ubuntu4",
"build-essential=12.8ubuntu1.1",
"busybox-static=1:1.30.1-4ubuntu6.4",
"bzip2=1.0.8-2",
"ca-certificates=20230311ubuntu0.20.04.1",
"can-utils=2018.02.0-1ubuntu1",
"cheese-common=3.34.0-1ubuntu1",
"chromium-browser=112.0.5615.49-0ubuntu0.18.04.1",
"chromium-codecs-ffmpeg=112.0.5615.49-0ubuntu0.18.04.1",
"colord=1.4.4-2",
"colord-data=1.4.4-2",
"console-setup=1.194ubuntu3",
"console-setup-linux=1.194ubuntu3",
"containerd=1.7.2-0ubuntu1~20.04.1",
"coreutils=8.30-3ubuntu2",
"cpp=4:9.3.0-1ubuntu2",
"cpp-9=9.4.0-1ubuntu1~20.04.2",
"cryptsetup=2:2.2.2-3ubuntu2.4",
"cryptsetup-bin=2:2.2.2-3ubuntu2.4",
"cuda-cccl-11-4=11.4.532-1",
"cuda-command-line-tools-11-4=11.4.30-1",
"cuda-compiler-11-4=11.4.30-1",
"cuda-cudart-11-4=11.4.532-1",
"cuda-cudart-dev-11-4=11.4.532-1",
"cuda-cuobjdump-11-4=11.4.532-1",
"cuda-cupti-11-4=11.4.532-1",
"cuda-cupti-dev-11-4=11.4.532-1",
"cuda-cuxxfilt-11-4=11.4.532-1",
"cuda-documentation-11-4=11.4.532-1",
"cuda-driver-dev-11-4=11.4.532-1",
"cuda-gdb-11-4=11.4.532-1",
"cuda-libraries-11-4=11.4.30-1",
"cuda-libraries-dev-11-4=11.4.30-1",
"cuda-nvcc-11-4=11.4.532-1",
"cuda-nvdisasm-11-4=11.4.532-1",
"cuda-nvprune-11-4=11.4.532-1",
"cuda-nvrtc-11-4=11.4.532-1",
"cuda-nvrtc-dev-11-4=11.4.532-1",
"cuda-nvtx-11-4=11.4.532-1",
"cuda-profiler-api-11-4=11.4.532-1",
"cuda-samples-11-4=11.4.532-1",
"cuda-sanitizer-11-4=11.4.532-1",
"cuda-toolkit-11-4=11.4.30-1",
"cuda-toolkit-11-4-config-common=11.4.532-1",
"cuda-toolkit-11-config-common=11.4.532-1",
"cuda-toolkit-config-common=11.4.532-1",
"cuda-tools-11-4=11.4.30-1",
"cuda-visual-tools-11-4=11.4.30-1",
"dash=0.5.10.2-6",
"dbus=1.12.16-2ubuntu2.3",
"dbus-user-session=1.12.16-2ubuntu2.3",
"dbus-x11=1.12.16-2ubuntu2.3",
"dconf-cli=0.36.0-1",
"dconf-gsettings-backend=0.36.0-1",
"dconf-service=0.36.0-1",
"dctrl-tools=2.24-3",
"debconf=1.5.73",
"debconf-utils=1.5.73",
"debianutils=4.9.1",
"desktop-file-utils=0.24-1ubuntu3",
"dictionaries-common=1.28.1",
"diffutils=1:3.7-3",
"dirmngr=2.2.19-3ubuntu2.2",
"distro-info-data=0.43ubuntu1.14",
"dmsetup=2:1.02.167-1ubuntu1",
"docker.io=24.0.5-0ubuntu1~20.04.1",
"dpkg=1.19.7ubuntu3.2",
"dpkg-dev=1.19.7ubuntu3.2",
"dpkg-repack=1.46",
"driveworks=5.20.24~linux6.0.10.0-360336400",
"driveworks-cgf=5.20.24~linux6.0.10.0-360336400",
"driveworks-stm=22.0.24",
"e2fsprogs=1.45.5-2ubuntu1.1",
"emacsen-common=3.0.4",
"ethtool=1:5.4-1",
"evolution-data-server=3.36.5-0ubuntu1",
"evolution-data-server-common=3.36.5-0ubuntu1",
"fdisk=2.34-0.1ubuntu9.4",
"file=1:5.38-4",
"file-roller=3.36.3-0ubuntu1.1",
"findutils=4.7.0-1ubuntu1",
"fio=3.16-1",
"fontconfig=2.13.1-2ubuntu3",
"fontconfig-config=2.13.1-2ubuntu3",
"fonts-dejavu-core=2.37-1",
"freeglut3=2.8.1-3",
"freeglut3-dev=2.8.1-3",
"fuse=2.9.9-3",
"g++=4:9.3.0-1ubuntu2",
"g++-9=9.4.0-1ubuntu1~20.04.2",
"gcc=4:9.3.0-1ubuntu2",
"gcc-10-base=10.5.0-1ubuntu1~20.04",
"gcc-9=9.4.0-1ubuntu1~20.04.2",
"gcc-9-base=9.4.0-1ubuntu1~20.04.2",
"gcr=3.36.0-2build1",
"gdisk=1.0.5-1",
"gdm3=3.36.3-0ubuntu0.20.04.4",
"geoclue-2.0=2.5.6-0ubuntu1",
"gettext-base=0.19.8.1-10build1",
"gir1.2-accountsservice-1.0=0.6.55-0ubuntu12~20.04.6",
"gir1.2-atk-1.0=2.35.1-1ubuntu2",
"gir1.2-atspi-2.0=2.36.0-2",
"gir1.2-freedesktop=1.64.1-1~ubuntu20.04.1",
"gir1.2-gck-1=3.36.0-2build1",
"gir1.2-gcr-3=3.36.0-2build1",
"gir1.2-gdesktopenums-3.0=3.36.0-1ubuntu1",
"gir1.2-gdkpixbuf-2.0=2.40.0+dfsg-3ubuntu0.4",
"gir1.2-gdm-1.0=3.36.3-0ubuntu0.20.04.4",
"gir1.2-geoclue-2.0=2.5.6-0ubuntu1",
"gir1.2-glib-2.0=1.64.1-1~ubuntu20.04.1",
"gir1.2-gnomebluetooth-1.0=3.34.3-0ubuntu1",
"gir1.2-gnomedesktop-3.0=3.36.8-0ubuntu1",
"gir1.2-graphene-1.0=1.10.0-1build2",
"gir1.2-gtk-3.0=3.24.20-0ubuntu1.1",
"gir1.2-gweather-3.0=3.36.1-1~ubuntu20.04.1",
"gir1.2-ibus-1.0=1.5.22-2ubuntu2.1",
"gir1.2-javascriptcoregtk-4.0=2.38.6-0ubuntu0.20.04.1",
"gir1.2-json-1.0=1.4.4-2ubuntu2",
"gir1.2-mutter-6=3.36.9-0ubuntu0.20.04.2",
"gir1.2-nm-1.0=1.22.10-1ubuntu2.3",
"gir1.2-nma-1.0=1.8.24-1ubuntu3",
"gir1.2-notify-0.7=0.7.9-1ubuntu3.20.04.2",
"gir1.2-packagekitglib-1.0=1.1.13-2ubuntu1.1",
"gir1.2-pango-1.0=1.44.7-2ubuntu4",
"gir1.2-polkit-1.0=0.105-26ubuntu1.3",
"gir1.2-rsvg-2.0=2.48.9-1ubuntu0.20.04.4",
"gir1.2-soup-2.4=2.70.0-1",
"gir1.2-timezonemap-1.0=0.4.6-2",
"gir1.2-upowerglib-1.0=0.99.11-1build2",
"gir1.2-vte-2.91=0.60.3-0ubuntu1~20.04",
"gir1.2-webkit2-4.0=2.38.6-0ubuntu0.20.04.1",
"gir1.2-xkl-1.0=5.4-4",
"gjs=1.64.5-0ubuntu0.20.04.01",
"glib-networking=2.64.2-1ubuntu0.1",
"glib-networking-common=2.64.2-1ubuntu0.1",
"glib-networking-services=2.64.2-1ubuntu0.1",
"gnome-control-center=1:3.36.5-0ubuntu4",
"gnome-control-center-data=1:3.36.5-0ubuntu4",
"gnome-desktop3-data=3.36.8-0ubuntu1",
"gnome-keyring=3.36.0-1ubuntu1",
"gnome-session-bin=3.36.0-2ubuntu1",
"gnome-session-common=3.36.0-2ubuntu1",
"gnome-settings-daemon=3.36.1-0ubuntu1.1",
"gnome-settings-daemon-common=3.36.1-0ubuntu1.1",
"gnome-shell=3.36.9-0ubuntu0.20.04.2",
"gnome-shell-common=3.36.9-0ubuntu0.20.04.2",
"gnome-terminal=3.36.2-1ubuntu1~20.04",
"gnome-terminal-data=3.36.2-1ubuntu1~20.04",
"gnupg=2.2.19-3ubuntu2.2",
"gnupg-l10n=2.2.19-3ubuntu2.2",
"gnupg-utils=2.2.19-3ubuntu2.2",
"gnupg1=1.4.23-1",
"gpg=2.2.19-3ubuntu2.2",
"gpg-agent=2.2.19-3ubuntu2.2",
"gpg-wks-client=2.2.19-3ubuntu2.2",
"gpg-wks-server=2.2.19-3ubuntu2.2",
"gpgconf=2.2.19-3ubuntu2.2",
"gpgsm=2.2.19-3ubuntu2.2",
"gpgv=2.2.19-3ubuntu2.2",
"gpiod=1.4.1-4",
"grep=3.4-1",
"grub-common=2.04-1ubuntu26.17",
"gsettings-desktop-schemas=3.36.0-1ubuntu1",
"gstreamer1.0-clutter-3.0=3.0.27-1",
"gstreamer1.0-plugins-base=1.16.3-0ubuntu1.2",
"gstreamer1.0-plugins-good=1.16.3-0ubuntu1.2",
"gstreamer1.0-x=1.16.3-0ubuntu1.2",
"gtk-update-icon-cache=3.24.20-0ubuntu1.1",
"gvfs=1.44.1-1ubuntu1.2",
"gvfs-common=1.44.1-1ubuntu1.2",
"gvfs-daemons=1.44.1-1ubuntu1.2",
"gvfs-libs=1.44.1-1ubuntu1.2",
"gzip=1.10-0ubuntu4.1",
"hicolor-icon-theme=0.17-2",
"hostname=3.23",
"htop=2.2.0-2build1",
"humanity-icon-theme=0.6.15",
"hunspell-en-us=1:2018.04.16-1",
"i2c-tools=4.1-2build2",
"ibutils2=2.1.1-0.156.MLNX20221016.g4aceb16.58101",
"ibverbs-providers=58mlnx43-1.58101",
"ifstat=1.1-8.1build2",
"im-config=0.44-1ubuntu1.3",
"infiniband-diags=58mlnx43-1.58101",
"init-system-helpers=1.57",
"iperf=2.0.13+dfsg1-1build1",
"iperf3=3.7-3",
"iproute2=5.5.0-1ubuntu1",
"iptables=1.8.4-3ubuntu2.1",
"iputils-ping=3:20190709-3",
"isc-dhcp-client=4.4.1-2.1ubuntu5.20.04.5",
"iso-codes=4.4-1",
"kbd=2.0.4-4ubuntu2",
"keyboard-configuration=1.194ubuntu3",
"keyutils=1.6-6ubuntu1.1",
"kmod=27-1ubuntu2.1",
"language-selector-common=0.204.2",
"language-selector-gnome=0.204.2",
"laptop-detect=0.16",
"less=551-1ubuntu0.1",
"libaa1=1.4p5-46",
"libaccountsservice0=0.6.55-0ubuntu12~20.04.6",
"libacl1=2.2.53-6",
"libaio1=0.3.112-5",
"libapparmor1=2.13.3-7ubuntu5.2",
"libapt-pkg6.0=2.0.10",
"libarchive13=3.4.0-2ubuntu1.2",
"libargon2-1=0~20171227-0.2",
"libasan5=9.4.0-1ubuntu1~20.04.2",
"libasn1-8-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libasound2=1.2.2-2.1ubuntu2.5",
"libasound2-data=1.2.2-2.1ubuntu2.5",
"libasound2-plugins=1.2.2-1ubuntu1",
"libaspell15=0.60.8-1ubuntu0.1",
"libassuan0=2.5.3-7ubuntu2",
"libasyncns0=0.8-6",
"libatasmart4=0.19-5",
"libatk-bridge2.0-0=2.34.2-0ubuntu2~20.04.1",
"libatk1.0-0=2.35.1-1ubuntu2",
"libatk1.0-data=2.35.1-1ubuntu2",
"libatomic1=10.5.0-1ubuntu1~20.04",
"libatopology2=1.2.2-2.1ubuntu2.5",
"libatspi2.0-0=2.36.0-2",
"libattr1=1:2.4.48-5",
"libaudit-common=1:2.8.5-2ubuntu6",
"libaudit1=1:2.8.5-2ubuntu6",
"libavahi-client3=0.7-4ubuntu7.3",
"libavahi-common-data=0.7-4ubuntu7.3",
"libavahi-common3=0.7-4ubuntu7.3",
"libavahi-glib1=0.7-4ubuntu7.3",
"libavc1394-0=0.5.4-5",
"libbinutils=2.34-6ubuntu1.6",
"libblkid1=2.34-0.1ubuntu9.4",
"libblockdev-fs2=2.23-2ubuntu3",
"libblockdev-loop2=2.23-2ubuntu3",
"libblockdev-part-err2=2.23-2ubuntu3",
"libblockdev-part2=2.23-2ubuntu3",
"libblockdev-swap2=2.23-2ubuntu3",
"libblockdev-utils2=2.23-2ubuntu3",
"libblockdev2=2.23-2ubuntu3",
"libboost-iostreams1.71.0=1.71.0-6ubuntu6",
"libboost-thread1.71.0=1.71.0-6ubuntu6",
"libbrotli1=1.0.7-6ubuntu0.1",
"libbsd0=0.10.0-1",
"libbz2-1.0=1.0.8-2",
"libc-bin=2.31-0ubuntu9.12",
"libc-dev-bin=2.31-0ubuntu9.12",
"libc6=2.31-0ubuntu9.12",
"libc6-dev=2.31-0ubuntu9.12",
"libcaca0=0.99.beta19-2.1ubuntu1.20.04.2",
"libcairo-gobject2=1.16.0-4ubuntu1",
"libcairo2=1.16.0-4ubuntu1",
"libcamel-1.2-62=3.36.5-0ubuntu1",
"libcanberra-gtk3-0=0.30-7ubuntu1",
"libcanberra0=0.30-7ubuntu1",
"libcap-ng0=0.7.9-2.1build1",
"libcap2=1:2.32-1ubuntu0.1",
"libcap2-bin=1:2.32-1ubuntu0.1",
"libcbor0.6=0.6.0-0ubuntu1",
"libcc1-0=10.5.0-1ubuntu1~20.04",
"libcdparanoia0=3.10.2+debian-13",
"libcheese-gtk25=3.34.0-1ubuntu1",
"libcheese8=3.34.0-1ubuntu1",
"libclutter-1.0-0=1.26.4+dfsg-1",
"libclutter-gst-3.0-0=3.0.27-1",
"libclutter-gtk-1.0-0=1.8.4-4",
"libcogl-pango20=1.22.6-1",
"libcogl-path20=1.22.6-1",
"libcogl20=1.22.6-1",
"libcolord-gtk1=0.2.0-0ubuntu1",
"libcolord2=1.4.4-2",
"libcolorhug2=1.4.4-2",
"libcom-err2=1.45.5-2ubuntu1.1",
"libcrack2=2.9.6-3.2",
"libcrypt-dev=1:4.4.10-10ubuntu4",
"libcrypt1=1:4.4.10-10ubuntu4",
"libcryptsetup12=2:2.2.2-3ubuntu2.4",
"libctf-nobfd0=2.34-6ubuntu1.6",
"libctf0=2.34-6ubuntu1.6",
"libcublas-11-4=11.6.6.316-1",
"libcublas-dev-11-4=11.6.6.316-1",
"libcudla-11-4=11.4.532-1",
"libcudla-dev-11-4=11.4.532-1",
"libcudnn8=8.9.2.19-1+cuda11.4",
"libcue2=2.2.1-2ubuntu0.1",
"libcufft-11-4=10.6.0.436-1",
"libcufft-dev-11-4=10.6.0.436-1",
"libcups2=2.3.1-9ubuntu1.6",
"libcurand-11-4=10.2.5.531-1",
"libcurand-dev-11-4=10.2.5.531-1",
"libcurl3-gnutls=7.68.0-1ubuntu2.20",
"libcusolver-11-4=11.2.0.531-1",
"libcusolver-dev-11-4=11.2.0.531-1",
"libcusparse-11-4=11.6.0.531-1",
"libcusparse-dev-11-4=11.6.0.531-1",
"libdatrie1=0.2.12-3",
"libdb5.3=5.3.28+dfsg1-0.6ubuntu2",
"libdbus-1-3=1.12.16-2ubuntu2.3",
"libdbusmenu-glib4=16.04.1+18.10.20180917-0ubuntu6",
"libdconf1=0.36.0-1",
"libdebconfclient0=0.251ubuntu1",
"libdebian-installer4=0.110ubuntu3",
"libdee-1.0-4=1.2.7+17.10.20170616-4ubuntu6",
"libdevmapper1.02.1=2:1.02.167-1ubuntu1",
"libdns-export1109=1:9.11.16+dfsg-3~ubuntu1",
"libdouble-conversion3=3.1.5-4ubuntu1",
"libdpkg-perl=1.19.7ubuntu3.2",
"libdrm-amdgpu1=2.4.107-8ubuntu1~20.04.2",
"libdrm-common=2.4.107-8ubuntu1~20.04.2",
"libdrm-nouveau2=2.4.107-8ubuntu1~20.04.2",
"libdrm-radeon1=2.4.107-8ubuntu1~20.04.2",
"libdrm2=2.4.107-8ubuntu1~20.04.2",
"libdv4=1.0.0-12",
"libebackend-1.2-10=3.36.5-0ubuntu1",
"libebook-1.2-20=3.36.5-0ubuntu1",
"libebook-contacts-1.2-3=3.36.5-0ubuntu1",
"libecal-2.0-1=3.36.5-0ubuntu1",
"libedata-book-1.2-26=3.36.5-0ubuntu1",
"libedata-cal-2.0-1=3.36.5-0ubuntu1",
"libedataserver-1.2-24=3.36.5-0ubuntu1",
"libedataserverui-1.2-2=3.36.5-0ubuntu1",
"libedit2=3.1-20191231-1",
"libefiboot1=37-2ubuntu2.2",
"libefivar1=37-2ubuntu2.2",
"libegl-dev=1.3.2-1~ubuntu0.20.04.2",
"libegl-mesa0=21.2.6-0ubuntu0.1~20.04.2",
"libegl1=1.3.2-1~ubuntu0.20.04.2",
"libelf1=0.176-1.1ubuntu0.1",
"libenchant-2-2=2.2.8-1ubuntu0.20.04.1",
"libepoxy0=1.5.4-1",
"libestr0=0.1.10-2.1",
"libevdev2=1.9.0+dfsg-1ubuntu0.2",
"libevent-2.1-7=2.1.11-stable-1",
"libexempi8=2.5.1-1ubuntu0.1",
"libexif12=0.6.21-6ubuntu0.4",
"libexiv2-27=0.27.2-8ubuntu2.7",
"libexpat1=2.2.9-1ubuntu0.6",
"libext2fs2=1.45.5-2ubuntu1.1",
"libfastjson4=0.99.8-2",
"libfdisk1=2.34-0.1ubuntu9.4",
"libffi7=3.3-4",
"libfftw3-single3=3.3.8-2ubuntu1",
"libfido2-1=1.3.1-1ubuntu2",
"libflac8=1.3.3-1ubuntu0.2",
"libfontconfig1=2.13.1-2ubuntu3",
"libfontenc1=1:1.1.4-0ubuntu1",
"libfreetype6=2.10.1-2ubuntu0.3",
"libfribidi0=1.0.8-2ubuntu0.1",
"libfuse2=2.9.9-3",
"libgbm1=21.2.6-0ubuntu0.1~20.04.2",
"libgcc-9-dev=9.4.0-1ubuntu1~20.04.2",
"libgcc-s1=10.5.0-1ubuntu1~20.04",
"libgck-1-0=3.36.0-2build1",
"libgcr-base-3-1=3.36.0-2build1",
"libgcr-ui-3-1=3.36.0-2build1",
"libgcrypt20=1.8.5-5ubuntu1.1",
"libgd3=2.2.5-5.2ubuntu2.1",
"libgdata-common=0.17.12-1",
"libgdata22=0.17.12-1",
"libgdbm-compat4=1.18.1-5",
"libgdbm6=1.18.1-5",
"libgdk-pixbuf2.0-0=2.40.0+dfsg-3ubuntu0.4",
"libgdk-pixbuf2.0-common=2.40.0+dfsg-3ubuntu0.4",
"libgdm1=3.36.3-0ubuntu0.20.04.4",
"libgeoclue-2-0=2.5.6-0ubuntu1",
"libgeocode-glib0=3.26.2-2",
"libgexiv2-2=0.12.0-2",
"libgfapi0=7.2-2build1",
"libgfrpc0=7.2-2build1",
"libgfxdr0=7.2-2build1",
"libgif7=5.1.9-1",
"libgirepository-1.0-1=1.64.1-1~ubuntu20.04.1",
"libgjs0g=1.64.5-0ubuntu0.20.04.01",
"libgl-dev=1.3.2-1~ubuntu0.20.04.2",
"libgl1=1.3.2-1~ubuntu0.20.04.2",
"libgl1-mesa-dri=21.2.6-0ubuntu0.1~20.04.2",
"libglapi-mesa=21.2.6-0ubuntu0.1~20.04.2",
"libgles-dev=1.3.2-1~ubuntu0.20.04.2",
"libgles1=1.3.2-1~ubuntu0.20.04.2",
"libgles2=1.3.2-1~ubuntu0.20.04.2",
"libglib2.0-0=2.64.6-1~ubuntu20.04.6",
"libglib2.0-bin=2.64.6-1~ubuntu20.04.6",
"libglib2.0-data=2.64.6-1~ubuntu20.04.6",
"libglu1-mesa=9.0.1-1build1",
"libglu1-mesa-dev=9.0.1-1build1",
"libglusterfs0=7.2-2build1",
"libglvnd-dev=1.3.2-1~ubuntu0.20.04.2",
"libglvnd0=1.3.2-1~ubuntu0.20.04.2",
"libglx-dev=1.3.2-1~ubuntu0.20.04.2",
"libglx-mesa0=21.2.6-0ubuntu0.1~20.04.2",
"libglx0=1.3.2-1~ubuntu0.20.04.2",
"libgmp10=2:6.2.0+dfsg-4ubuntu0.1",
"libgnome-autoar-0-0=0.2.3-2ubuntu0.4",
"libgnome-bluetooth13=3.34.3-0ubuntu1",
"libgnome-desktop-3-19=3.36.8-0ubuntu1",
"libgnutls30=3.6.13-2ubuntu1.9",
"libgoa-1.0-0b=3.36.1-0ubuntu1",
"libgoa-1.0-common=3.36.1-0ubuntu1",
"libgoa-backend-1.0-1=3.36.1-0ubuntu1",
"libgomp1=10.5.0-1ubuntu1~20.04",
"libgpg-error0=1.37-1",
"libgphoto2-6=2.5.25-0ubuntu0.1",
"libgphoto2-port12=2.5.25-0ubuntu0.1",
"libgpiod2=1.4.1-4",
"libgpm2=1.20.7-5",
"libgraphene-1.0-0=1.10.0-1build2",
"libgraphite2-3=1.3.13-11build1",
"libgsf-1-114=1.14.46-1",
"libgsf-1-common=1.14.46-1",
"libgsound0=1.0.2-4",
"libgssapi-krb5-2=1.17-6ubuntu4.4",
"libgssapi3-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libgstreamer-gl1.0-0=1.16.3-0ubuntu1.2",
"libgstreamer-plugins-base1.0-0=1.16.3-0ubuntu1.2",
"libgstreamer-plugins-good1.0-0=1.16.3-0ubuntu1.2",
"libgstreamer1.0-0=1.16.3-0ubuntu1.1",
"libgtk-3-0=3.24.20-0ubuntu1.1",
"libgtk-3-common=3.24.20-0ubuntu1.1",
"libgtop-2.0-11=2.40.0-2",
"libgtop2-common=2.40.0-2",
"libgudev-1.0-0=1:233-1",
"libgusb2=0.3.4-0.1",
"libgweather-3-16=3.36.1-1~ubuntu20.04.1",
"libgweather-common=3.36.1-1~ubuntu20.04.1",
"libgxps2=0.3.1-1",
"libharfbuzz-icu0=2.6.4-1ubuntu4.2",
"libharfbuzz0b=2.6.4-1ubuntu4.2",
"libhcrypto4-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libheimbase1-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libheimntlm0-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libhogweed5=3.5.1+really3.5.1-2ubuntu0.2",
"libhunspell-1.7-0=1.7.0-2build2",
"libhx509-5-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libhyphen0=2.8.8-7",
"libi2c0=4.1-2build2",
"libibmad5=58mlnx43-1.58101",
"libibnetdisc5=58mlnx43-1.58101",
"libibumad3=58mlnx43-1.58101",
"libibus-1.0-5=1.5.22-2ubuntu2.1",
"libibverbs1=58mlnx43-1.58101",
"libical3=3.0.8-1",
"libice-dev=2:1.0.10-0ubuntu1",
"libice6=2:1.0.10-0ubuntu1",
"libicu66=66.1-2ubuntu2.1",
"libidn2-0=2.2.0-2",
"libiec61883-0=1.2.0-3",
"libieee1284-3=0.2.11-13build1",
"libimobiledevice6=1.2.1~git20191129.9f79242-1build1",
"libinput-bin=1.15.5-1ubuntu0.3",
"libinput10=1.15.5-1ubuntu0.3",
"libip4tc2=1.8.4-3ubuntu2.1",
"libip6tc2=1.8.4-3ubuntu2.1",
"libiperf0=3.7-3",
"libisc-export1105=1:9.11.16+dfsg-3~ubuntu1",
"libisl22=0.22.1-1",
"libitm1=10.5.0-1ubuntu1~20.04",
"libiw30=30~pre9-13ubuntu1",
"libjack-jackd2-0=1.9.12~dfsg-2ubuntu2",
"libjansson4=2.12-1build1",
"libjavascriptcoregtk-4.0-18=2.38.6-0ubuntu0.20.04.1",
"libjbig0=2.1-3.1ubuntu0.20.04.1",
"libjpeg-turbo8=2.0.3-0ubuntu1.20.04.3",
"libjpeg8=8c-2ubuntu8",
"libjson-c4=0.13.1+dfsg-7ubuntu0.3",
"libjson-glib-1.0-0=1.4.4-2ubuntu2",
"libjson-glib-1.0-common=1.4.4-2ubuntu2",
"libk5crypto3=1.17-6ubuntu4.4",
"libkeyutils1=1.6-6ubuntu1.1",
"libkmod2=27-1ubuntu2.1",
"libkrb5-26-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libkrb5-3=1.17-6ubuntu4.4",
"libkrb5support0=1.17-6ubuntu4.4",
"libksba8=1.3.5-2ubuntu0.20.04.2",
"liblcms2-2=2.9-4",
"libldap-2.4-2=2.4.49+dfsg-2ubuntu1.9",
"libldap-common=2.4.49+dfsg-2ubuntu1.9",
"libldb2=2:2.4.4-0ubuntu0.20.04.2",
"libllvm12=1:12.0.0-3ubuntu1~20.04.5",
"liblmdb0=0.9.24-1",
"liblocale-gettext-perl=1.07-4",
"liblsan0=10.5.0-1ubuntu1~20.04",
"libltdl7=2.4.6-14",
"liblz4-1=1.9.2-2ubuntu0.20.04.1",
"liblzma5=5.2.4-1ubuntu1.1",
"liblzo2-2=2.10-2",
"libmagic-mgc=1:5.38-4",
"libmagic1=1:5.38-4",
"libmm-glib0=1.18.6-1~ubuntu20.04.1",
"libmnl0=1.0.4-2",
"libmount1=2.34-0.1ubuntu9.4",
"libmozjs-68-0=68.6.0-1ubuntu1",
"libmp3lame0=3.100-3",
"libmpc3=1.1.0-1",
"libmpdec2=2.4.2-3",
"libmpfr6=4.0.2-1",
"libmpg123-0=1.25.13-1",
"libmtdev1=1.1.5-1.1",
"libmutter-6-0=3.36.9-0ubuntu0.20.04.2",
"libmysqlclient21=8.0.35-0ubuntu0.20.04.1",
"libnautilus-extension1a=1:3.36.3-0ubuntu1.20.04.2",
"libncurses6=6.2-0ubuntu2.1",
"libncursesw6=6.2-0ubuntu2.1",
"libnetfilter-conntrack3=1.0.7-2",
"libnettle7=3.5.1+really3.5.1-2ubuntu0.2",
"libnewt0.52=0.52.21-4ubuntu2",
"libnfnetlink0=1.0.1-3build1",
"libnfsidmap2=0.25-5.1ubuntu1",
"libnftnl11=1.1.5-1",
"libnghttp2-14=1.40.0-1ubuntu0.2",
"libnl-3-200=3.4.0-1ubuntu0.1",
"libnl-genl-3-200=3.4.0-1ubuntu0.1",
"libnl-route-3-200=3.4.0-1ubuntu0.1",
"libnm0=1.22.10-1ubuntu2.3",
"libnma0=1.8.24-1ubuntu3",
"libnotify4=0.7.9-1ubuntu3.20.04.2",
"libnpp-11-4=11.4.0.521-1",
"libnpp-dev-11-4=11.4.0.521-1",
"libnpth0=1.6-1",
"libnspr4=2:4.25-1",
"libnss3=2:3.49.1-1ubuntu1.9",
"libntfs-3g883=1:2017.3.23AR.3-3ubuntu1.3",
"libnuma1=2.0.12-1",
"libnvidia-container-tools=1.10.0-1",
"libnvidia-container0=0.11.0+jetpack",
"libnvidia-container1=1.10.0-1",
"libnvinfer-bin=8.6.13.3-1+cuda11.4",
"libnvinfer-dispatch8=8.6.13.3-1+cuda11.4",
"libnvinfer-lean8=8.6.13.3-1+cuda11.4",
"libnvinfer-plugin8=8.6.13.3-1+cuda11.4",
"libnvinfer-vc-plugin8=8.6.13.3-1+cuda11.4",
"libnvinfer8=8.6.13.3-1+cuda11.4",
"libnvonnxparsers8=8.6.13.3-1+cuda11.4",
"libnvparsers8=8.6.13.3-1+cuda11.4",
"libogg0=1.3.4-0ubuntu1",
"libopengl-dev=1.3.2-1~ubuntu0.20.04.2",
"libopengl0=1.3.2-1~ubuntu0.20.04.2",
"libopenjp2-7=2.3.1-1ubuntu4.20.04.1",
"libopenvswitch=2.17.2-1.58101",
"libopus0=1.3.1-0ubuntu1",
"liborc-0.4-0=1:0.4.31-1",
"libp11-kit0=0.23.20-1ubuntu0.1",
"libpackagekit-glib2-18=1.1.13-2ubuntu1.1",
"libpam-modules=1.3.1-5ubuntu4.6",
"libpam-modules-bin=1.3.1-5ubuntu4.6",
"libpam-runtime=1.3.1-5ubuntu4.6",
"libpam-systemd=245.4-4ubuntu3.22",
"libpam0g=1.3.1-5ubuntu4.6",
"libpango-1.0-0=1.44.7-2ubuntu4",
"libpangocairo-1.0-0=1.44.7-2ubuntu4",
"libpangoft2-1.0-0=1.44.7-2ubuntu4",
"libpangoxft-1.0-0=1.44.7-2ubuntu4",
"libparted-fs-resize0=3.3-4ubuntu0.20.04.1",
"libparted2=3.3-4ubuntu0.20.04.1",
"libpcap0.8=1.9.1-3",
"libpci3=1:3.6.4-1ubuntu0.20.04.1",
"libpciaccess0=0.16-0ubuntu1",
"libpcre2-16-0=10.34-7ubuntu0.1",
"libpcre2-8-0=10.34-7ubuntu0.1",
"libpcre3=2:8.39-12ubuntu0.1",
"libpcsclite1=1.8.26-3",
"libperl5.30=5.30.0-9ubuntu0.4",
"libphonenumber7=7.1.0-5ubuntu11",
"libpixman-1-0=0.38.4-0ubuntu2.1",
"libplist3=2.1.0-4build2",
"libpng16-16=1.6.37-2",
"libpolkit-agent-1-0=0.105-26ubuntu1.3",
"libpolkit-gobject-1-0=0.105-26ubuntu1.3",
"libpoppler-glib8=0.86.1-0ubuntu1.4",
"libpoppler97=0.86.1-0ubuntu1.4",
"libpopt0=1.16-14",
"libprocps8=2:3.3.16-1ubuntu2.4",
"libprotobuf17=3.6.1.3-2ubuntu5.2",
"libproxy1v5=0.4.15-10ubuntu1.2",
"libpsl5=0.21.0-1ubuntu1",
"libpthread-stubs0-dev=0.4-1",
"libpulse-mainloop-glib0=1:13.99.1-1ubuntu3.13",
"libpulse0=1:13.99.1-1ubuntu3.13",
"libpulsedsp=1:13.99.1-1ubuntu3.13",
"libpwquality-common=1.4.2-1build1",
"libpwquality1=1.4.2-1build1",
"libpython2-stdlib=2.7.17-2ubuntu4",
"libpython2.7-minimal=2.7.18-1~20.04.3",
"libpython2.7-stdlib=2.7.18-1~20.04.3",
"libpython3-stdlib=3.8.2-0ubuntu2",
"libpython3.8=3.8.10-0ubuntu1~20.04.8",
"libpython3.8-minimal=3.8.10-0ubuntu1~20.04.8",
"libpython3.8-stdlib=3.8.10-0ubuntu1~20.04.8",
"libqt5core5a=5.12.8+dfsg-0ubuntu2.1",
"libqt5dbus5=5.12.8+dfsg-0ubuntu2.1",
"libqt5gui5=5.12.8+dfsg-0ubuntu2.1",
"libqt5network5=5.12.8+dfsg-0ubuntu2.1",
"libqt5qml5=5.12.8-0ubuntu1",
"libqt5quick5=5.12.8-0ubuntu1",
"libqt5svg5=5.12.8-0ubuntu1",
"libqt5widgets5=5.12.8+dfsg-0ubuntu2.1",
"librados2=15.2.17-0ubuntu0.20.04.4",
"libraw1394-11=2.1.2-1",
"librbd1=15.2.17-0ubuntu0.20.04.4",
"librdmacm1=58mlnx43-1.58101",
"libreadline8=8.0-4",
"librest-0.7-0=0.8.1-1",
"libroken18-heimdal=7.7.0+dfsg-1ubuntu1.4",
"librsvg2-2=2.48.9-1ubuntu0.20.04.4",
"librsvg2-common=2.48.9-1ubuntu0.20.04.4",
"librtmp1=2.4+20151223.gitfa8646d.1-2build1",
"libsamplerate0=0.1.9-2",
"libsane=1.0.29-0ubuntu5.2",
"libsane-common=1.0.29-0ubuntu5.2",
"libsasl2-2=2.1.27+dfsg-2ubuntu0.1",
"libsasl2-modules-db=2.1.27+dfsg-2ubuntu0.1",
"libsctp1=1.0.18+dfsg-1",
"libseccomp2=2.5.1-1ubuntu1~20.04.2",
"libsecret-1-0=0.20.4-0ubuntu1",
"libsecret-common=0.20.4-0ubuntu1",
"libselinux1=3.0-1build2",
"libsemanage-common=3.0-1build2",
"libsemanage1=3.0-1build2",
"libsensors-config=1:3.6.0-2ubuntu1.1",
"libsensors5=1:3.6.0-2ubuntu1.1",
"libsepol1=3.0-1ubuntu0.1",
"libshout3=2.4.3-1",
"libslang2=2.3.2-4",
"libsm-dev=2:1.2.3-1",
"libsm6=2:1.2.3-1",
"libsmartcols1=2.34-0.1ubuntu9.4",
"libsmbclient=2:4.15.13+dfsg-0ubuntu0.20.04.7",
"libsnapd-glib1=1.58-0ubuntu0.20.04.0",
"libsndfile1=1.0.28-7ubuntu0.2",
"libsnmp-base=5.8+dfsg-2ubuntu2.9",
"libsnmp35=5.8+dfsg-2ubuntu2.9",
"libsoup-gnome2.4-1=2.70.0-1",
"libsoup2.4-1=2.70.0-1",
"libsoxr0=0.1.3-2build1",
"libspeex1=1.2~rc1.2-1.1ubuntu1.20.04.1",
"libspeexdsp1=1.2~rc1.2-1.1ubuntu1.20.04.1",
"libsqlite3-0=3.31.1-4ubuntu0.5",
"libss2=1.45.5-2ubuntu1.1",
"libssh-4=0.9.3-2ubuntu2.3",
"libssl1.1=1.1.1f-1ubuntu2.20",
"libstartup-notification0=0.12-6",
"libstdc++-9-dev=9.4.0-1ubuntu1~20.04.2",
"libstdc++6=10.5.0-1ubuntu1~20.04",
"libstemmer0d=0+svn585-2",
"libsystemd0=245.4-4ubuntu3.22",
"libtag1v5=1.11.1+dfsg.1-0.3ubuntu2",
"libtag1v5-vanilla=1.11.1+dfsg.1-0.3ubuntu2",
"libtalloc2=2.3.3-0ubuntu0.20.04.1",
"libtasn1-6=4.16.0-2",
"libtcl8.6=8.6.10+dfsg-1",
"libtdb1=1.4.5-0ubuntu0.20.04.1",
"libtevent0=0.11.0-0ubuntu0.20.04.1",
"libtext-iconv-perl=1.7-7",
"libthai-data=0.1.28-3",
"libthai0=0.1.28-3",
"libtheora0=1.1.1+dfsg.1-15ubuntu2",
"libtiff5=4.1.0+git191117-2ubuntu0.20.04.11",
"libtimezonemap-data=0.4.6-2",
"libtimezonemap1=0.4.6-2",
"libtinfo6=6.2-0ubuntu2.1",
"libtirpc-common=1.2.5-1ubuntu0.1",
"libtirpc3=1.2.5-1ubuntu0.1",
"libtk8.6=8.6.10-1",
"libtotem-plparser-common=3.26.5-1ubuntu1",
"libtotem-plparser18=3.26.5-1ubuntu1",
"libtracker-control-2.0-0=2.3.6-0ubuntu1",
"libtracker-miner-2.0-0=2.3.6-0ubuntu1",
"libtracker-sparql-2.0-0=2.3.6-0ubuntu1",
"libtsan0=10.5.0-1ubuntu1~20.04",
"libtwolame0=0.4.0-2",
"libubsan1=10.5.0-1ubuntu1~20.04",
"libudev1=245.4-4ubuntu3.22",
"libudisks2-0=2.8.4-1ubuntu2",
"libunbound8=1.9.4-2ubuntu1.4",
"libunistring2=0.9.10-2",
"libunity-protocol-private0=7.1.4+19.04.20190319-0ubuntu3",
"libunity-scopes-json-def-desktop=7.1.4+19.04.20190319-0ubuntu3",
"libunity9=7.1.4+19.04.20190319-0ubuntu3",
"libunwind8=1.2.1-9ubuntu0.1",
"libupower-glib3=0.99.11-1build2",
"libusb-1.0-0=2:1.0.23-2build1",
"libusb-1.0-0-dev=2:1.0.23-2build1",
"libusbmuxd6=2.0.1-2",
"libutempter0=1.1.6-4",
"libuuid1=2.34-0.1ubuntu9.4",
"libv4l-0=1.18.0-2build1",
"libv4lconvert0=1.18.0-2build1",
"libvisual-0.4-0=0.4.0-17",
"libvncclient1=0.9.12+dfsg-9ubuntu0.3",
"libvncserver1=0.9.12+dfsg-9ubuntu0.3",
"libvorbis0a=1.3.6-2ubuntu1",
"libvorbisenc2=1.3.6-2ubuntu1",
"libvorbisfile3=1.3.6-2ubuntu1",
"libvpx6=1.8.2-1ubuntu0.2",
"libvte-2.91-0=0.60.3-0ubuntu1~20.04",
"libvte-2.91-common=0.60.3-0ubuntu1~20.04",
"libvulkan1=1.2.131.2-1",
"libwacom-common=1.3-2ubuntu3",
"libwacom2=1.3-2ubuntu3",
"libwavpack1=5.2.0-1ubuntu0.1",
"libwayland-client0=1.18.0-1ubuntu0.1",
"libwayland-cursor0=1.18.0-1ubuntu0.1",
"libwayland-egl1=1.18.0-1ubuntu0.1",
"libwayland-server0=1.18.0-1ubuntu0.1",
"libwbclient0=2:4.15.13+dfsg-0ubuntu0.20.04.7",
"libwebkit2gtk-4.0-37=2.38.6-0ubuntu0.20.04.1",
"libwebp6=0.6.1-2ubuntu0.20.04.3",
"libwebpdemux2=0.6.1-2ubuntu0.20.04.3",
"libwebrtc-audio-processing1=0.3.1-0ubuntu3",
"libwhoopsie-preferences0=22",
"libpsie0=0.2.69ubuntu0.3",
"libwind0-heimdal=7.7.0+dfsg-1ubuntu1.4",
"libwoff1=1.0.2-1build2",
"libwrap0=7.6.q-30",
"libx11-6=2:1.6.9-2ubuntu1.6",
"libx11-data=2:1.6.9-2ubuntu1.6",
"libx11-dev=2:1.6.9-2ubuntu1.6",
"libx11-xcb1=2:1.6.9-2ubuntu1.6",
"libxau-dev=1:1.0.9-0ubuntu1",
"libxau6=1:1.0.9-0ubuntu1",
"libxaw7=2:1.0.13-1",
"libxcb-dri2-0=1.14-2",
"libxcb-dri3-0=1.14-2",
"libxcb-glx0=1.14-2",
"libxcb-icccm4=0.4.1-1.1",
"libxcb-image0=0.4.0-1build1",
"libxcb-keysyms1=0.4.0-1build1",
"libxcb-present0=1.14-2",
"libxcb-randr0=1.14-2",
"libxcb-render-util0=0.3.9-1build1",
"libxcb-render0=1.14-2",
"libxcb-res0=1.14-2",
"libxcb-shape0=1.14-2",
"libxcb-shm0=1.14-2",
"libxcb-sync1=1.14-2",
"libxcb-util1=0.4.0-0ubuntu3",
"libxcb-xfixes0=1.14-2",
"libxcb-xinerama0=1.14-2",
"libxcb-xinput0=1.14-2",
"libxcb-xkb1=1.14-2",
"libxcb1=1.14-2",
"libxcb1-dev=1.14-2",
"libxcomposite1=1:0.4.5-1",
"libxcursor1=1:1.2.0-2",
"libxdamage1=1:1.1.5-2",
"libxdmcp-dev=1:1.1.3-0ubuntu1",
"libxdmcp6=1:1.1.3-0ubuntu1",
"libxext-dev=2:1.3.4-0ubuntu1",
"libxext6=2:1.3.4-0ubuntu1",
"libxfixes-dev=1:5.0.3-2",
"libxfixes3=1:5.0.3-2",
"libxfont2=1:2.0.3-1",
"libxft2=2.3.3-0ubuntu1",
"libxi-dev=2:1.7.10-0ubuntu1",
"libxi6=2:1.7.10-0ubuntu1",
"libxinerama1=2:1.1.4-2",
"libxkbcommon-x11-0=0.10.0-1",
"libxkbcommon0=0.10.0-1",
"libxkbfile1=1:1.1.0-1",
"libxklavier16=5.4-4",
"libxml2=2.9.10+dfsg-5ubuntu0.20.04.6",
"libxmu-dev=2:1.1.3-0ubuntu1",
"libxmu-headers=2:1.1.3-0ubuntu1",
"libxmu6=2:1.1.3-0ubuntu1",
"libxmuu1=2:1.1.3-0ubuntu1",
"libxpm4=1:3.5.12-1ubuntu0.20.04.2",
"libxrandr2=2:1.5.2-0ubuntu1",
"libxrender1=1:0.9.10-1",
"libxshmfence1=1.3-1",
"libxslt1.1=1.1.34-4ubuntu0.20.04.1",
"libxss1=1:1.2.3-1",
"libxt-dev=1:1.1.5-1",
"libxt6=1:1.1.5-1",
"libxtables12=1.8.4-3ubuntu2.1",
"libxtst6=2:1.2.3-1",
"libxv1=2:1.0.11-1",
"libxxf86vm1=1:1.1.4-1build1",
"libyaml-0-2=0.2.2-1",
"libzstd1=1.4.4+dfsg-3ubuntu0.1",
"linux-libc-dev=5.4.0-167.184",
"linux-sound-base=1.0.25+dfsg-0ubuntu5",
"login=1:4.8.1-1ubuntu5.20.04.4",
"logsave=1.45.5-2ubuntu1.1",
"lsb-base=11.1.0ubuntu2",
"lsb-release=11.1.0ubuntu2",
"lshw=02.18.85-0.3ubuntu2.20.04.1",
"lsof=4.93.2+dfsg-1ubuntu0.20.04.1",
"ltrace=0.7.3-6.1ubuntu1",
"make=4.2.1-1.2",
"mawk=1.3.4.20200120-2",
"mft=4.22.0-96",
"mime-support=3.64ubuntu1",
"mlnx-ethtool=5.18-1.58101",
"mlnx-fw-updater=5.8-1.0.1.1",
"mlnx-iproute2=5.19.0-1.58101",
"mlnx-tools=5.2.0-0.58101",
"mount=2.34-0.1ubuntu9.4",
"mstflint=4.16.1-2.58101",
"mutter=3.36.9-0ubuntu0.20.04.2",
"mutter-common=3.36.9-0ubuntu0.20.04.2",
"mysql-common=5.8+1.0.5ubuntu2",
"nautilus=1:3.36.3-0ubuntu1.20.04.2",
"nautilus-data=1:3.36.3-0ubuntu1.20.04.2",
"ncurses-base=6.2-0ubuntu2.1",
"ncurses-bin=6.2-0ubuntu2.1",
"ncurses-term=6.2-0ubuntu2.1",
"net-tools=1.60+git20180626.aebd88e-1ubuntu1",
"netbase=6.1",
"netcat=1.206-1ubuntu1",
"netcat-openbsd=1.206-1ubuntu1",
"nfs-common=1:1.3.4-2.5ubuntu3.5",
"ntfs-3g=1:2017.3.23AR.3-3ubuntu1.3",
"ntpdate=1:4.2.8p12+dfsg-3ubuntu4.20.04.1",
"nv-driveos-linux-aurix=6.0.10.0-1",
"nv-driveos-linux-core=6.0.10.0-1",
"nv-driveos-linux-firmware=6.0.10.0-1",
"nv-driveos-linux-headers=6.0.10.0-1",
"nv-driveos-linux-kernel-modules=6.0.10.0-1",
"nv-driveos-linux-libraries=6.0.10.0-1",
"nv-driveos-linux-oobe=6.0.10.0-1",
"nv-driveos-linux-samples=6.0.10.0-1",
"nv-driveos-linux-security=6.0.10.0-1",
"nv-driveos-linux-tools=6.0.10.0-1",
"nvidia-container-toolkit=1.10.0-1",
"nvidia-docker2=2.11.0-1",
"oem-config=20.04.15.19",
"oem-config-debconf=20.04.15.19",
"oem-config-gtk=20.04.15.19",
"ofed-scripts=5.8-OFED.5.8.1.0.1",
"openssh-client=1:8.2p1-4ubuntu0.9",
"openssh-server=1:8.2p1-4ubuntu0.9",
"openssh-sftp-server=1:8.2p1-4ubuntu0.9",
"openssl=1.1.1f-1ubuntu2.20",
"openvswitch-common=2.17.2-1.58101",
"os-prober=1.74ubuntu2",
"p11-kit=0.23.20-1ubuntu0.1",
"p11-kit-modules=0.23.20-1ubuntu0.1",
"parted=3.3-4ubuntu0.20.04.1",
"passwd=1:4.8.1-1ubuntu5.20.04.4",
"patch=2.7.6-6",
"pci.ids=0.0~2020.03.20-1",
"pciutils=1:3.6.4-1ubuntu0.20.04.1",
"perftest=4.5-0.18.gfcddfe0.58101",
"perl=5.30.0-9ubuntu0.4",
"perl-base=5.30.0-9ubuntu0.4",
"perl-modules-5.30=5.30.0-9ubuntu0.4",
"pinentry-curses=1.1.0-3build1",
"pinentry-gnome3=1.1.0-3build1",
"pmount=0.9.23-3build1",
"policycoreutils=3.0-1",
"policykit-1=0.105-26ubuntu1.3",
"procps=2:3.3.16-1ubuntu2.4",
"pulseaudio=1:13.99.1-1ubuntu3.13",
"pulseaudio-utils=1:13.99.1-1ubuntu3.13",
"python-apt-common=2.0.1ubuntu0.20.04.1",
"python-is-python3=3.8.2-4",
"python2=2.7.17-2ubuntu4",
"python2-minimal=2.7.17-2ubuntu4",
"python2.7=2.7.18-1~20.04.3",
"python2.7-minimal=2.7.18-1~20.04.3",
"python3=3.8.2-0ubuntu2",
"python3-apt=2.0.1ubuntu0.20.04.1",
"python3-aptdaemon=1.1.1+bzr982-0ubuntu32.3",
"python3-aptdaemon.gtk3widgets=1.1.1+bzr982-0ubuntu32.3",
"python3-cairo=1.16.2-2ubuntu2",
"python3-certifi=2019.11.28-1",
"python3-chardet=3.0.4-4build1",
"python3-crypto=2.6.1-13ubuntu2",
"python3-cups=1.9.73-3build1",
"python3-cupshelpers=1.5.12-0ubuntu1.1",
"python3-dbus=1.2.16-1build1",
"python3-debconf=1.5.73",
"python3-defer=1.0.6-2.1",
"python3-gi=3.36.0-1",
"python3-gi-cairo=3.36.0-1",
"python3-icu=2.4.2-0ubuntu3",
"python3-idna=2.8-1",
"python3-ldb=2:2.4.4-0ubuntu0.20.04.2",
"python3-libnvinfer=8.6.13.3-1+cuda11.4",
"python3-minimal=3.8.2-0ubuntu2",
"python3-openvswitch=2.17.2-1.58101",
"python3-pam=0.4.2-13.2ubuntu8",
"python3-pkg-resources=45.2.0-1ubuntu0.1",
"python3-pycryptodome=3.6.1-2build4",
"python3-requests=2.22.0-2ubuntu1.1",
"python3-six=1.14.0-2",
"python3-talloc=2.3.3-0ubuntu0.20.04.1",
"python3-urllib3=1.25.8-2ubuntu0.3",
"python3-yaml=5.3.1-1ubuntu0.1",
"python3.8=3.8.10-0ubuntu1~20.04.8",
"python3.8-minimal=3.8.10-0ubuntu1~20.04.8",
"qml-module-qtquick-layouts=5.12.8-0ubuntu1",
"qml-module-qtquick-window2=5.12.8-0ubuntu1",
"qml-module-qtquick2=5.12.8-0ubuntu1",
"rdate=1:1.10-2",
"rdma-core=58mlnx43-1.58101",
"rdmacm-utils=58mlnx43-1.58101",
"readline-common=8.0-4",
"rfkill=2.34-0.1ubuntu9.4",
"rng-tools=5-1ubuntu2",
"rpcbind=1.2.5-8",
"rsyslog=8.2001.0-1ubuntu1.3",
"runc=1.1.7-0ubuntu1~20.04.1",
"samba-libs=2:4.15.13+dfsg-0ubuntu0.20.04.7",
"sed=4.7-1",
"selinux-utils=3.0-1build2",
"sensible-utils=0.0.12+nmu1",
"session-migration=0.3.5",
"shared-mime-info=1.15-1",
"smartmontools=7.1-1build1",
"sockperf=3.10-0.git5ebd327da983.58101",
"sound-theme-freedesktop=0.8-2ubuntu1",
"strace=5.5-3ubuntu1",
"sudo=1.8.31-1ubuntu1.5",
"system-config-printer=1.5.12-0ubuntu1.1",
"system-config-printer-common=1.5.12-0ubuntu1.1",
"systemd=245.4-4ubuntu3.22",
"systemd-sysv=245.4-4ubuntu3.22",
"systemd-timesyncd=245.4-4ubuntu3.22",
"sysvinit-utils=2.96-2.1ubuntu1",
"tar=1.30+dfsg-7ubuntu0.20.04.3",
"tasksel=3.34ubuntu16",
"tasksel-data=3.34ubuntu16",
"tcl=8.6.9+1",
"tcl8.6=8.6.10+dfsg-1",
"tcpdump=4.9.3-4ubuntu0.2",
"tk=8.6.9+1",
"tk8.6=8.6.10-1",
"tracker=2.3.6-0ubuntu1",
"tracker-extract=2.3.3-2ubuntu0.20.04.1",
"tracker-miner-fs=2.3.3-2ubuntu0.20.04.1",
"tzdata=2023c-0ubuntu0.20.04.2",
"ubiquity=20.04.15.19",
"ubiquity-casper=1.445.3",
"ubiquity-frontend-debconf=20.04.15.19",
"ubiquity-frontend-gtk=20.04.15.19",
"ubiquity-ubuntu-artwork=20.04.15.19",
"ubuntu-keyring=2020.02.11.4",
"ubuntu-mono=19.04-0ubuntu3",
"ubuntu-session=3.36.0-2ubuntu1",
"ubuntu-wallpapers=20.04.2-0ubuntu1",
"ubuntu-wallpapers-focal=20.04.2-0ubuntu1",
"ucf=3.0038+nmu1",
"udev=245.4-4ubuntu3.22",
"udisks2=2.8.4-1ubuntu2",
"unzip=6.0-25ubuntu1.1",
"upower=0.99.11-1build2",
"usb.ids=2020.03.19-1",
"usbutils=1:012-2",
"util-linux=2.34-0.1ubuntu9.4",
"vim=2:8.1.2269-1ubuntu5.20",
"vim-common=2:8.1.2269-1ubuntu5.20",
"vim-runtime=2:8.1.2269-1ubuntu5.20",
"wget=1.20.3-1ubuntu2",
"whiptail=0.52.21-4ubuntu2",
"whois=5.5.6",
"whoopsie-preferences=22",
"wireless-tools=30~pre9-13ubuntu1",
"wpasupplicant=2:2.9-1ubuntu4.3",
"x11-common=1:7.7+19ubuntu14",
"x11-xkb-utils=7.7+5",
"x11-xserver-utils=7.7+8",
"x11proto-core-dev=2019.2-1ubuntu1",
"x11proto-dev=2019.2-1ubuntu1",
"x11proto-input-dev=2019.2-1ubuntu1",
"x11proto-xext-dev=2019.2-1ubuntu1",
"x11vnc=0.9.16-3",
"xbitmaps=1.1.1-2",
"xdg-dbus-proxy=0.1.2-1",
"xdg-utils=1.1.3-2ubuntu1.20.04.2",
"xkb-data=2.29-2",
"xorg-sgml-doctools=1:1.11-1",
"xserver-common=2:1.20.13-1ubuntu1~20.04.9",
"xserver-xorg-core=2:1.20.13-1ubuntu1~20.04.9",
"xserver-xorg-input-evdev=1:2.10.6-1",
"xserver-xorg-legacy=2:1.20.13-1ubuntu1~20.04.9",
"xserver-xorg-video-dummy=1:0.3.8-1build3",
"xterm=353-1ubuntu1.20.04.2",
"xtrans-dev=1.4.0-1",
"xwayland=2:1.20.13-1ubuntu1~20.04.9",
"xxd=2:8.1.2269-1ubuntu5.20",
"xz-utils=5.2.4-1ubuntu1.1",
"yaru-theme-gnome-shell=20.04.11.1",
"zenity=3.32.0-5",
"zenity-common=3.32.0-5",
"zip=3.0-11build1",
"zlib1g=1:1.2.11.dfsg-2ubuntu1.5"
"ImageSize": "12884901888",
"Users": {
"nvidia": {
"UID": "1000",
"Username": "nvidia",
"Password": "nvidia"
"gdm": {
"UID": "110",
"Username": "gdm",
"Shell": "/bin/false",
"Home": "/var/lib/gdm3"
"Groups": {
"render": {
"Groupname": "render",
"GID": "108"
"weston-launch": {
"Groupname": "weston-launch",
"GID": "1010"
"debug": {
"Groupname": "debug",
"GID": "1011"
"nvtimesync": {
"Groupname": "nvtimesync",
"GID": "1012"
"tzvault": {
"Groupname": "tzvault",
"GID": "1013"
"uss": {
"Groupname": "uss",
"GID": "1014"
"nvfsicom": {
"Groupname": "nvfsicom",
"GID": "1015"
"nvepl": {
"Groupname": "nvepl",
"GID": "1016"
"Memberships": {
"nvidia": [
"adm",
"audio",
"cdrom",
"dialout",
"dip",
"floppy",
"plugdev",
"sudo",
"video",
"weston-launch",
"nvtimesync",
"render",
"gdm",
"uss",
"nvfsicom",
"nvepl"
"gdm": [
"gdm",
"video"
"Hostname": null,
"FilesystemInclude": [],
"FSMountPointConfg": null,
"DigestMetadataConfig": null
I also tried connecting to using vnc however, im gettting this white terminal for benchdev2 instead of GUI
benchdev2@tegra-ubuntu:~$ sudo x11vnc -create
24/04/2024 13:58:58 x11vnc version: 0.9.16 lastmod: 2019-01-05 pid: 3957
24/04/2024 13:58:58
24/04/2024 13:58:58 wait_for_client: WAIT:cmd=FINDCREATEDISPLAY-Xvfb
24/04/2024 13:58:58
24/04/2024 13:58:58 initialize_screen: fb_depth/fb_bpp/fb_Bpl 24/32/2560
24/04/2024 13:58:58
24/04/2024 13:58:58 Autoprobing TCP port
24/04/2024 13:58:58 Autoprobing selected TCP port 5900
24/04/2024 13:58:58 Autoprobing TCP6 port
24/04/2024 13:58:58 Autoprobing selected TCP6 port 5900
24/04/2024 13:58:58 listen6: bind: Address already in use
24/04/2024 13:58:58 Not listening on IPv6 interface.
24/04/2024 13:58:58
The VNC desktop is: tegra-ubuntu:0
PORT=5900
24/04/2024 13:59:02 Got connection from client 192.168.1.110
24/04/2024 13:59:02 other clients:
24/04/2024 13:59:02 Normal socket connection
24/04/2024 13:59:02 incr accepted_client=1 for 192.168.1.110:36422 sock=5
24/04/2024 13:59:02 wait_for_client: got client
24/04/2024 13:59:02 Client Protocol Version 3.8
24/04/2024 13:59:02 Protocol version sent 3.8, using 3.8
24/04/2024 13:59:02 client progressed=1 in 1/5 0.001185 s
24/04/2024 13:59:02 client_set_net: 192.168.1.110 0.1107
24/04/2024 13:59:02 wait_for_client: running: env X11VNC_SKIP_DISPLAY='' /bin/sh /tmp/x11vnc-find_display.tWluwn
xauth: file /root/.Xauthority does not exist
24/04/2024 13:59:02 wait_for_client: find display cmd failed.
24/04/2024 13:59:02 wait_for_client: FINDCREATEDISPLAY cmd: /bin/sh /tmp/x11vnc-find_display.tWluwn Xvfb
trying N=20 ...
redir_daemon=
/usr/bin/xauth: file /root/.Xauthority does not exist
/usr/bin/Xvfb :20 -screen 0 1280x1024x24 -cc 4 -nolisten tcp -auth /tmp/.xas401832363.duqdgj
/usr/bin/nohup: appending output to 'nohup.out'
24/04/2024 13:59:06 Using X display :20
24/04/2024 13:59:06 rootwin: 0x50e reswin: 0x400001 dpy: 0xea6d9140
24/04/2024 13:59:06
24/04/2024 13:59:06 ------------------ USEFUL INFORMATION ------------------
24/04/2024 13:59:06 X DAMAGE available on display, using it for polling hints.
24/04/2024 13:59:06 To disable this behavior use: '-noxdamage'
24/04/2024 13:59:06
24/04/2024 13:59:06 Most compositing window managers like 'compiz' or 'beryl'
24/04/2024 13:59:06 cause X DAMAGE to fail, and so you may not see any screen
24/04/2024 13:59:06 updates via VNC. Either disable 'compiz' (recommended) or
24/04/2024 13:59:06 supply the x11vnc '-noxdamage' command line option.
24/04/2024 13:59:06
24/04/2024 13:59:06 Wireframing: -wireframe mode is in effect for window moves.
24/04/2024 13:59:06 If this yields undesired behavior (poor response, painting
24/04/2024 13:59:06 errors, etc) it may be disabled:
24/04/2024 13:59:06 - use '-nowf' to disable wireframing completely.
24/04/2024 13:59:06 - use '-nowcr' to disable the Copy Rectangle after the
24/04/2024 13:59:06 moved window is released in the new position.
24/04/2024 13:59:06 Also see the -help entry for tuning parameters.
24/04/2024 13:59:06 You can press 3 Alt_L's (Left "Alt" key) in a row to
24/04/2024 13:59:06 repaint the screen, also see the -fixscreen option for
24/04/2024 13:59:06 periodic repaints.
24/04/2024 13:59:06
24/04/2024 13:59:06 XFIXES available on display, resetting cursor mode
24/04/2024 13:59:06 to: '-cursor most'.
24/04/2024 13:59:06 to disable this behavior use: '-cursor arrow'
24/04/2024 13:59:06 or '-noxfixes'.
24/04/2024 13:59:06 using XFIXES for cursor drawing.
24/04/2024 13:59:06 GrabServer control via XTEST.
24/04/2024 13:59:06
24/04/2024 13:59:06 Scroll Detection: -scrollcopyrect mode is in effect to
24/04/2024 13:59:06 use RECORD extension to try to detect scrolling windows
24/04/2024 13:59:06 (induced by either user keystroke or mouse input).
24/04/2024 13:59:06 errors, etc) it may be disabled via: '-noscr'
24/04/2024 13:59:06
24/04/2024 13:59:06 XKEYBOARD: number of keysyms per keycode 7 is greater
24/04/2024 13:59:06 than 4 and 51 keysyms are mapped above 4.
24/04/2024 13:59:06 Automatically switching to -xkb mode.
24/04/2024 13:59:06 If this makes the key mapping worse you can
24/04/2024 13:59:06 disable it with the "-noxkb" option.
24/04/2024 13:59:06 Also, remember "-remap DEAD" for accenting characters.
24/04/2024 13:59:06
24/04/2024 13:59:06 X FBPM extension not supported.
Xlib: extension "DPMS" missing on display ":20".
24/04/2024 13:59:06 X display is not capable of DPMS.
24/04/2024 13:59:06 --------------------------------------------------------
24/04/2024 13:59:06
24/04/2024 13:59:06 Default visual ID: 0x21
24/04/2024 13:59:06 Read initial data from X display into framebuffer.
24/04/2024 13:59:06 initialize_screen: fb_depth/fb_bpp/fb_Bpl 24/32/5120
24/04/2024 13:59:06 rfbNewFramebuffer(0xea6c7100, 0x0, 1280, 1024, 8, 1, 4)
24/04/2024 13:59:06 Pixel format for client 192.168.1.110:
24/04/2024 13:59:06 32 bpp, depth 24, little endian
24/04/2024 13:59:06 true colour: max r 255 g 255 b 255, shift r 16 g 8 b 0
24/04/2024 13:59:06
24/04/2024 13:59:06 X display :20 is 32bpp depth=24 true color
24/04/2024 13:59:06
24/04/2024 13:59:06 calling setTranslateFunction()...
24/04/2024 13:59:06 no translation needed
24/04/2024 13:59:06 done.
24/04/2024 13:59:06 TS_REDIR is empty, restarting...
24/04/2024 13:59:06
24/04/2024 13:59:06 Xinerama is present and active (e.g. multi-head).
24/04/2024 13:59:06 Xinerama: number of sub-screens: 1
24/04/2024 13:59:06 Xinerama: no blackouts needed (only one sub-screen)
24/04/2024 13:59:06
24/04/2024 13:59:06 fb read rate: 1548 MB/sec
24/04/2024 13:59:06 fast read: reset -wait ms to: 10
24/04/2024 13:59:06 fast read: reset -defer ms to: 10
24/04/2024 13:59:06 The X server says there are 10 mouse buttons.
24/04/2024 13:59:06 screen setup finished.
24/04/2024 13:59:06
24/04/2024 13:59:06 WARNING: You are running x11vnc WITHOUT a password. See
24/04/2024 13:59:06 WARNING: the warning message printed above for more info.
24/04/2024 13:59:06
PORT=5900
Have you tried the x11vnc '-ncache' VNC client-side pixel caching feature yet?
The scheme stores pixel data offscreen on the VNC viewer side for faster
retrieval. It should work with any VNC viewer. Try it by running:
x11vnc -ncache 10 ...
One can also add -ncache_cr for smooth 'copyrect' window motion.
More info: http://www.karlrunge.com/x11vnc/faq.html#faq-client-caching
24/04/2024 13:59:06 rfbProcessClientSecurityType: executing handler for type 1
24/04/2024 13:59:06 rfbProcessClientSecurityType: returning securityResult for client rfb version >= 3.8
24/04/2024 13:59:06 Battling with something for -norepeat!! (1 resets left)
24/04/2024 13:59:06 Disabled X server key autorepeat.
24/04/2024 13:59:06 to force back on run: 'xset r on' (2 times)
24/04/2024 13:59:06 created xdamage object: 0x40002c
24/04/2024 13:59:06 Using compression level 1 for client 192.168.1.110
24/04/2024 13:59:06 Enabling X-style cursor updates for client 192.168.1.110
24/04/2024 13:59:06 Enabling full-color cursor updates for client 192.168.1.110
24/04/2024 13:59:06 Enabling cursor position updates for client 192.168.1.110
24/04/2024 13:59:06 Enabling KeyboardLedState protocol extension for client 192.168.1.110
24/04/2024 13:59:06 Enabling NewFBSize protocol extension for client 192.168.1.110
24/04/2024 13:59:06 Enabling SupportedMessages protocol extension for client 192.168.1.110
24/04/2024 13:59:06 Enabling SupportedEncodings protocol extension for client 192.168.1.110
24/04/2024 13:59:06 Enabling ServerIdentity protocol extension for client 192.168.1.110
24/04/2024 13:59:06 Using zlib encoding for client 192.168.1.110
24/04/2024 13:59:08 copy_tiles: allocating first_line at size 41
24/04/2024 13:59:13 client 1 network rate 3699.2 KB/sec (78575.4 eff KB/sec)
24/04/2024 13:59:13 client 1 latency: 0.9 ms
24/04/2024 13:59:13 dt1: 0.0012, dt2: 0.0026 dt3: 0.0009 bytes: 12299
24/04/2024 13:59:13 link_rate: LR_LAN - 1 ms, 3699 KB/s
