Isaac Sim Version
5.0.0
Operating System
Windows 11
GPU Information
- Model: RTX A3000
- Driver Version: 573.73
Topic Description
Detailed Description
I am trying to command my robot to different waypoints using the Test Lula Widget.
After trying to import with URDF and fail. I took the base .USD from https://omniverse-content-production.s3-us-west-2.amazonaws.com/Assets/Isaac/5.0/Isaac/Robots/UniversalRobots/ur3e/configuration/
And loaded it in Blender, I defined the URDF using Phobos and exported it.
Upon loading into Isaac Sim, I have successfully loaded it as an articulation with Lula Robot Description Editor despite getting this error:
2025-10-13T14:33:47Z [17,716,658ms] [Error] [omni.physx.tensors.plugin] Pattern ‘/World/UR3E/root_joint’ did not match any rigid bodies
2025-10-13T14:33:47Z [17,716,659ms] [Error] [omni.physx.tensors.plugin] Provided pattern list did not match any articulations
And generated the corresponding .yaml and .xrdf files.
Then moving on to the Lula Test Widget I have faced the following errors:
2025-10-13T14:33:47Z [17,716,715ms] [Error] [omni.kit.app._impl] [py stderr]: AttributeError: ‘NoneType’ object has no attribute ‘is_homogeneous’
Steps to Reproduce
Load URDF
Press Play to find error: 2025-10-13T14:33:47Z [17,716,658ms] [Error] [omni.physx.tensors.plugin] Pattern ‘/World/UR3E/root_joint’ did not match any rigid bodies
Go to Lula Test Widget, and load the attached .YAML as well to find next error.
And subsequent:
2025-10-13T14:35:50Z [17,840,166ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2025-10-13T14:35:50Z [17,840,166ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.robot_setup.xrdf_editor/isaacsim/robot_setup/xrdf_editor/extension.py”, line 571, in _on_physics_step
2025-10-13T14:35:50Z [17,840,167ms] [Error] [omni.kit.app._impl] [py stderr]: self.articulation.initialize()
2025-10-13T14:35:50Z [17,840,167ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/single_articulation.py”, line 320, in initialize
2025-10-13T14:35:50Z [17,840,167ms] [Error] [omni.kit.app._impl] [py stderr]: self._articulation_view.initialize(physics_sim_view=physics_sim_view)
2025-10-13T14:35:50Z [17,840,168ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 5148, in initialize
2025-10-13T14:35:50Z [17,840,169ms] [Error] [omni.kit.app._impl] [py stderr]: self._on_physics_ready(None)
2025-10-13T14:35:50Z [17,840,169ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 5154, in _on_physics_ready
2025-10-13T14:35:50Z [17,840,171ms] [Error] [omni.kit.app._impl] [py stderr]: self._physics_view = simulation_view.create_articulation_view(
2025-10-13T14:35:50Z [17,840,171ms] [Error] [omni.kit.app._impl] [py stderr]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-13T14:35:50Z [17,840,172ms] [Error] [omni.kit.app._impl] [py stderr]: AttributeError: ‘NoneType’ object has no attribute ‘create_articulation_view’
2025-10-13T14:36:23Z [17,872,726ms] [Warning] [isaacsim.robot_motion.lula_test_widget.controllers] Failed to compute Inverse Kinematics
Error Messages
2025-10-13T14:33:47Z [17,716,594ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2025-10-13T14:33:47Z [17,716,595ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.robot_setup.xrdf_editor/isaacsim/robot_setup/xrdf_editor/extension.py”, line 571, in _on_physics_step
2025-10-13T14:33:47Z [17,716,616ms] [Error] [omni.kit.app._impl] [py stderr]: self.articulation.initialize()
2025-10-13T14:33:47Z [17,716,617ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/single_articulation.py”, line 320, in initialize
2025-10-13T14:33:47Z [17,716,618ms] [Error] [omni.kit.app._impl] [py stderr]: self._articulation_view.initialize(physics_sim_view=physics_sim_view)
2025-10-13T14:33:47Z [17,716,618ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 5148, in initialize
2025-10-13T14:33:47Z [17,716,647ms] [Error] [omni.kit.app._impl] [py stderr]: self._on_physics_ready(None)
2025-10-13T14:33:47Z [17,716,648ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 5154, in _on_physics_ready
2025-10-13T14:33:47Z [17,716,650ms] [Error] [omni.kit.app._impl] [py stderr]: self._physics_view = simulation_view.create_articulation_view(
2025-10-13T14:33:47Z [17,716,651ms] [Error] [omni.kit.app._impl] [py stderr]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-13T14:33:47Z [17,716,652ms] [Error] [omni.kit.app._impl] [py stderr]: AttributeError: ‘NoneType’ object has no attribute ‘create_articulation_view’
2025-10-13T14:33:47Z [17,716,660ms] [Error] [omni.kit.app._impl] [py stderr]: Traceback (most recent call last):
2025-10-13T14:33:47Z [17,716,660ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.robot_setup.xrdf_editor/isaacsim/robot_setup/xrdf_editor/extension.py”, line 571, in _on_physics_step
2025-10-13T14:33:47Z [17,716,660ms] [Error] [omni.kit.app._impl] [py stderr]: self.articulation.initialize()
2025-10-13T14:33:47Z [17,716,661ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/single_articulation.py”, line 320, in initialize
2025-10-13T14:33:47Z [17,716,661ms] [Error] [omni.kit.app._impl] [py stderr]: self._articulation_view.initialize(physics_sim_view=physics_sim_view)
2025-10-13T14:33:47Z [17,716,663ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 5148, in initialize
2025-10-13T14:33:47Z [17,716,664ms] [Error] [omni.kit.app._impl] [py stderr]: self._on_physics_ready(None)
2025-10-13T14:33:47Z [17,716,665ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/exts/isaacsim.core.prims/isaacsim/core/prims/impl/articulation.py”, line 5159, in _on_physics_ready
2025-10-13T14:33:47Z [17,716,667ms] [Error] [omni.kit.app._impl] [py stderr]: assert self._physics_view.is_homogeneous
2025-10-13T14:33:47Z [17,716,667ms] [Error] [omni.kit.app._impl] [py stderr]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^^
2025-10-13T14:33:47Z [17,716,667ms] [Error] [omni.kit.app._impl] [py stderr]: File “c:/isaacsim/extscache/omni.physics.tensors-107.3.18+107.3.1.wx64.r.cp311.u353/omni/physics/tensors/impl/api.py”, line 704, in is_homogeneous
2025-10-13T14:33:47Z [17,716,713ms] [Error] [omni.kit.app._impl] [py stderr]: return self._backend.is_homogeneous
2025-10-13T14:33:47Z [17,716,714ms] [Error] [omni.kit.app._impl] [py stderr]: ^^^^^^^^^^^^^^^^^^^^^^^^^^^^
Screenshots or Videos
Additional Information
What I’ve Tried
Changed the collision meshes and the spheres, tried loading different URDFs
Related Issues
(If you’re aware of any related issues or forum posts, please link them here)
Additional Context
NVIDIA_ERROR.zip (2.4 KB)
(Add any other context about the problem here)
