Failed to start OpenBSD Secure Shell Server
Hello everyone I was trying to boot up my jetson AGX orin for the first time and it does not take me to the linux interface Instead I get stuck at this screen with failed messages for Failed to start OpenBSD secure shell server. I believe the agx orin comes with a preinstalled linux interface or do I have to boot it myself
It would be helpful If I could get help with this.
Here are some suggestions for the common issues:
1. Performance
Please run the below command before benchmarking deep learning use case:
$ sudo nvpmodel -m 0
$ sudo jetson_clocks
2. Installation
Installation guide of deep learning frameworks on Jetson:
3. Tutorial
Startup deep learning tutorial:
4. Report issue
If these suggestions don’t help and you want to report an issue to us, please attach the model, command/step, and the customized app (if any) with us to reproduce locally.
Thank you for your quick attention to this matter unfortunately that did not answer my question. Im having more problems with the first boot in my agx orin. I cannot run any commands on it since I’m not logged in and when I power it on it gets stuck in the following screen
Do you use the default rootfs on AGX Orin developer kit? It seems like you don’t use the default rootfs which has Ubuntu desktop. Suggest re-flash the system to Jetpack 6.1 and check again.
