Fast fps on half-transparency material
Operating System:
Windows
Kit Version:
106 (Kit App Template)
Kit Template:
USD Composer
GPU Hardware:
40 series
RTX4090
GPU Driver:
Other
560.94
Work Flow:
I listed my working environment above.
We attempt to display some of the devices within a building and indicate their location.
We are using a normal OmniPBR material and have changed some figures to try to make it look a bit more “half-transparency” to let people “see through” the building and locate those devices.
But we are getting petty slow FPS at the moment, wonder if there is any material can tweak as “half-transparency” with a faster FPS.
Thanks in advance.
Douglas
Yes that looks pretty demanding. That is a lot of transparency. There are several factors:
  1. The GPU
  2. The viewport resolution
  3. The amount of transparent geometry
  4. The amount of reflection and refraction bounces you have set up in the Render Settings
  5. The exact settings in the Material.
My advice is to turn off a lot of extra settings in the Render Settings. So turn of all secondary lighting, like GI and AO, turn off Reflections and Refractions, turn off anything you can.
It is a tough scene for sure. I can see what you are trying to achieve, but in this case, it just results in a lot of transparent elements.
Just curious but if you turn off all of this transparency, do you get great FPS again ?
Hi Richard,
Big thanks for your prompt reply. Yes, getting faster FPS once turn off those settings you mention.
BTW, can we still have a kind of “cheap version” of “just half transparent” material instead? No need for fancy reflection/refraction, and just “half transparent” so we can proceed to placing those indicators into the building to let people see those devices. Simi-like the attached pics.
Many thanks.
Douglas
You will have to just experiment and see what works for you versus the FPS.
Thanks will have a trial.
