please help me I started jetson nano for the first time I have followed the tutorial correctly to do the installation the first time but the problem appears I used bellenaEtcher for the installation
if there are any peripherals connected to your device, like camera or USB dongles, please remove all of them and reset to try again.
If it still does not work, please try flashing with scripts provided in our BSP, and you can skip the OEM configuration by creating user accounts in advance:
(This has to be done under the Linux_for_Tegra BSP folder on a Linux PC.)
sudo ./tools/l4t_create_default_user.sh -u <username> -p <password>
sudo ./flash.sh jetson-nano-devkit mmcblk0p1
