I recently purchased a Jetson Nano Developer Kit but have encountered a persisting problem. When I first boot up the nano, I’m presented with a terminal that fills with various error messages. Oftentimes, the nano will then reboot. This would continue to happen, with different error messages appearing until the initial setup screen loads. But even once that has appeared, the nano will sometimes reboot and I have to start all over again. I’ve already tried reflashing the sd card and using a different power source, but the problem has not gone away. How can I fix this?
Hi ajiteshsunder24,
What power supply are you using?
Are you connect with power jack (J25) or micro-USB (J28)?
I’m closing this topic due to there is no update from you for a period, assuming this issue was resolved.
If still need the support, please open a new topic. Thanks
