Board: Jetson Orin Nano 8GB Developer Kit
Firmware: 36.4.3
Image: jetson-orin-nano-devkit-super-SD-image_JP6.2.1.zip
Setup: Out-of-the-box fresh board setup using an SD card. Both a display and serial console are connected.
Description of the Issue:
The board boots up but immediately drops into a recovery/emergency kernel boot instead of the standard target. It seems to hang during the oem-config phase.
On the connected display, an error dialog box appears indicating an unrecoverable error, and both the keyboard and mouse completely lock up.
Key Symptom & Observations:
Mismatch in root target: The kernel command line shows
root=/dev/initrdinstead of pointing to the SD card. -
Configuration checked: I verified
/mnt/boot/extlinux/extlinux.confon the SD card, and it correctly specifiesroot=/dev/mmcblk0p1. The bootloader appears to be ignoring or bypassing this file completely.
Boot Log Snippet:
Jetson System firmware version 36.4.3-gcid-38968081 date 2025-01-08T01:18:20+00:
00
ESC to enter Setup.
F11 to enter Boot Manager Menu.
Enter to continue boot.
......L4TLauncher: Attempting Recovery Boot
EFI stub: Booting Linux Kernel...
EFI stub: Using DTB from configuration table
EFI stub: Loaded initrd from LINUX_EFI_INITRD_MEDIA_GUID device path
EFI stub: Exiting boot services...
��debugfs initialized
��I/TC: Reserved shared memory is disabled
I/TC: Dynamic shared memory is enabled
I/TC: Normal World virtualization support is disabled
I/TC: Asynchronous notifications are disabled
��[ 0.000000] Booting Linux on physical CPU 0x0000000000 [0x410fd421]
[ 0.000000] Linux version 5.15.148-tegra (buildbrain@mobile-u64-6262-d8000) (aarch64-buildroot-linux-gnu-gcc.br_real (Buildroot 2022.08) 11.3.0, GNU ld (GNU Binutils) 2.38) #1 SMP PREEMPT Mon Jun 16 08:24:48 PDT 2025 ()
[ 0.000000] Machine model: NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super
[ 0.000000] efi: EFI v2.70 by EDK II
[ 0.000000] efi: RTPROP=0x26d82f198 TPMFinalLog=0x25e3f0000 SMBIOS=0xffff0000 SMBIOS 3.0=0x26d220000 MEMATTR=0x26718f018 ESRT=0x2671c0a18 TPMEventLog=0x25e408018 RNG=0x25a450018 MEMRESERVE=0x25e40af18
[ 0.000000] random: crng init done
[ 0.000000] secureboot: Secure boot disabled
[ 0.000000] esrt: Reserving ESRT space from 0x00000002671c0a18 to 0x00000002671c0a50.
[ 0.000000] Reserved memory: created CMA memory pool at 0x000000024a000000, size 256 MiB
[ 0.000000] OF: reserved mem: initialized node linux,cma, compatible id shared-dma-pool
[ 0.000000] NUMA: No NUMA configuration found
[ 0.000000] NUMA: Faking a node at [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] NUMA: NODE_DATA [mem 0x271305800-0x271307fff]
[ 0.000000] Zone ranges:
[ 0.000000] DMA [mem 0x0000000080000000-0x00000000ffffffff]
[ 0.000000] DMA32 empty
[ 0.000000] Normal [mem 0x0000000100000000-0x0000000277ffffff]
[ 0.000000] Movable zone start for each node
[ 0.000000] Early memory node ranges
[ 0.000000] node 0: [mem 0x0000000080000000-0x00000000bdffffff]
[ 0.000000] node 0: [mem 0x00000000c2000000-0x00000000fffdffff]
[ 0.000000] node 0: [mem 0x00000000fffe0000-0x00000000ffffffff]
[ 0.000000] node 0: [mem 0x0000000100000000-0x000000025e22cfff]
[ 0.000000] node 0: [mem 0x000000025e22d000-0x000000025e3fffff]
[ 0.000000] node 0: [mem 0x000000025e400000-0x000000025e40afff]
[ 0.000000] node 0: [mem 0x000000025e40b000-0x000000025e40bfff]
[ 0.000000] node 0: [mem 0x000000025e40c000-0x000000026b8effff]
[ 0.000000] node 0: [mem 0x000000026b8f0000-0x000000026d82ffff]
[ 0.000000] node 0: [mem 0x000000026d830000-0x0000000271dfffff]
[ 0.000000] node 0: [mem 0x0000000271e00000-0x0000000271ffffff]
[ 0.000000] node 0: [mem 0x0000000272000000-0x000000027259ffff]
[ 0.000000] node 0: [mem 0x0000000272f00000-0x0000000272ffffff]
[ 0.000000] node 0: [mem 0x0000000276000000-0x0000000277ffffff]
[ 0.000000] Initmem setup node 0 [mem 0x0000000080000000-0x0000000277ffffff]
[ 0.000000] On node 0, zone DMA: 16384 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 2400 pages in unavailable ranges
[ 0.000000] On node 0, zone Normal: 12288 pages in unavailable ranges
[ 0.000000] psci: probing for conduit method from DT.
[ 0.000000] psci: PSCIv1.1 detected in firmware.
[ 0.000000] psci: Using standard PSCI v0.2 function IDs
[ 0.000000] psci: Trusted OS migration not required
[ 0.000000] psci: SMC Calling Convention v1.2
[ 0.000000] percpu: Embedded 29 pages/cpu s80408 r8192 d30184 u118784
[ 0.000000] Detected PIPT I-cache on CPU0
[ 0.000000] CPU features: detected: Address authentication (architected algorithm)
[ 0.000000] CPU features: detected: GIC system register CPU interface
[ 0.000000] CPU features: detected: Virtualization Host Extensions
[ 0.000000] CPU featuins /l: dib/eted: ules/5dwa.14dirty bita/updaement
tes/drivers/.00net0] /etnet/re featuresaltek/ete68/d: 68.ctre-v
4
[ 0.000000] CPU features: detected: Spectre-BHB
[ 0.000000] CPU features: kernel page table isolation forced ON by KASLR
[ 0.000000] CPU features: detected: Kernel page table isolation (KPTI)
[ 0.000000] alternatives: patching kernel code
[ 0.000000] Built 1 zonelists, mobility grouping on. Total pages: 2001056
[ 0.000000] Policy zone: Normal
[ 0.000000] Kernel command line: root=/dev/initrd rw rootwait mminit_loglevel=4 console=ttyTCU0,115200 firmware_class.path=/etc/firmware fbcon=map:0 net.ifnames=0 bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000
[ 0.000000] Unknown kernel command line parameters "bl_prof_dataptr=2031616@0x271E10000 bl_prof_ro_ptr=65536@0x271E00000", will be passed to user space.
[ 0.000000] Dentry cache hash table entries: 1048576 (order: 11, 8388608 bytes, linear)
[ 0.000000] Inode-cache hash table entries: 524288 (order: 10, 4194304 bytes, linear)
[ 0.000000] mem auto-init: stack:off, heap alloc:off, heap free:off
[ 0.000000] software IO TLB: mapped [mem 0x00000000fbfe0000-0x00000000fffe0000] (64MB)
[ 0.000000] Memory: 7512460K/8133248K available (20160K kernel code, 4064K rwdata, 10056K rodata, 7680K init, 529K bss, 358644K reserved, 262144K cma-reserved)
[ 0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=6, Nodes=1
[ 0.000000] trace event string verifier disabled
[ 0.000000] rcu: Preemptible hierarchical RCU implementation.
[ 0.000000] rcu: RCU event tracing is enabled.
[ 0.000000] rcu: RCU restricting CPUs from NR_CPUS=256 to nr_cpu_ids=6.
[ 0.000000] Trampoline variant of Tasks RCU enabled.
[ 0.000000] Rude variant of Tasks RCU enabled.
[ 0.000000] Tracing variant of Tasks RCU enabled.
[ 0.000000] rcu: RCU calculated value of scheduler-enlistment delay is 25 jiffies.
[ 0.000000] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=6
[ 0.000000] NR_IRQS: 64, nr_irqs: 64, preallocated irqs: 0
[ 0.000000] GICv3: GIC: Using split EOI/Deactivate mode
[ 0.000000] GICv3: 960 SPIs implemented
[ 0.000000] GICv3: 0 Extended SPIs implemented
[ 0.000000] GICv3: Distributor has no Range Selector support
[ 0.000000] Root IRQ handler: gic_handle_irq
[ 0.000000] GICv3: 16 PPIs implemented
[ 0.000000] GICv3: CPU0: found redistributor 0 region 0:0x000000000f440000
[ 0.000000] arch_timer: cp15 timer(s) running at 31.25MHz (phys).
[ 0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 0.000001] sched_clock: 56 bits at 31MHz, resolution 32ns, wraps every 4398046511088ns
[ 0.000358] Console: colour dummy device 80x25
[ 0.000423] Calibrating delay loop (skipped), value calculated using timer frequency.. 62.50 BogoMIPS (lpj=125000)
[ 0.000431] pid_max: default: 32768 minimum: 301
[ 0.000469] LSM: Security Framework initializing
[ 0.000494] Yama: becoming mindful.
[ 0.000511] SELinux: Initializing.
[ 0.000594] Mount-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.000608] Mountpoint-cache hash table entries: 16384 (order: 5, 131072 bytes, linear)
[ 0.001719] rcu: Hierarchical SRCU implementation.
[ 0.003838] Tegra Revision: A01 SKU: 213 CPU Process: 0 SoC Process: 0
[ 0.004144] Remapping and enabling EFI services.
[ 0.004937] smp: Bringing up secondary CPUs ...
[ 0.005425] Detected PIPT I-cache on CPU1
[ 0.005464] GICv3: CPU1: found redistributor 100 region 0:0x000000000f460000
[ 0.005495] CPU1: Booted secondary processor 0x0000000100 [0x410fd421]
[ 0.005944] Detected PIPT I-cache on CPU2
[ 0.005955] GICv3: CPU2: found redistributor 200 region 0:0x000000000f480000
[ 0.005969] CPU2: Booted secondary processor 0x0000000200 [0x410fd421]
[ 0.006378] Detected PIPT I-cache on CPU3
[ 0.006387] GICv3: CPU3: found redistributor 300 region 0:0x000000000f4a0000
[ 0.006400] CPU3: Booted secondary processor 0x0000000300 [0x410fd421]
[ 0.008849] Detected PIPT I-cache on CPU4
[ 0.008876] GICv3: CPU4: found redistributor 10200 region 0:0x000000000f500000
[ 0.008904] CPU4: Booted secondary processor 0x0000010200 [0x410fd421]
[ 0.009391] Detected PIPT I-cache on CPU5
[ 0.009403] GICv3: CPU5: found redistributor 10300 region 0:0x000000000f520000
[ 0.009418] CPU5: Booted secondary processor 0x0000010300 [0x410fd421]
[ 0.009476] smp: Brought up 1 node, 6 CPUs
[ 0.009480] SMP: Total of 6 processors activated.
[ 0.009483] CPU features: detected: 32-bit EL0 Support
[ 0.009485] CPU features: detected: Data cache clean to the PoU not required for I/D coherence
[ 0.009487] CPU features: detected: Common not Private translations
[ 0.009488] CPU features: detected: CRC32 instructions
[ 0.009489] CPU features: detected: Data cache clean to Point of Persistence
[ 0.009491] CPU features: detected: Generic authentication (architected algorithm)
[ 0.009492] CPU features: detected: RCpc load-acquire (LDAPR)
[ 0.009493] CPU features: detected: LSE atomic instructions
[ 0.009494] CPU features: detected: Privileged Access Never
[ 0.009495] CPU features: detected: RAS Extension Support
[ 0.009497] CPU features: detected: Speculative Store Bypassing Safe (SSBS)
[ 0.043908] CPU: All CPU(s) started at EL2
[ 0.047135] devtmpfs: initialized
[ 0.065974] KASLR enabled
[ 0.066164] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 7645041785100000 ns
[ 0.066190] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.071224] pinctrl core: initialized pinctrl subsystem
[ 0.072255] SMBIOS 3.6.0 present.
[ 0.072272] DMI: NVIDIA NVIDIA Jetson Orin Nano Engineering Reference Developer Kit Super/Jetson, BIOS 36.4.3-gcid-38968081 01/08/2025
[ 0.072862] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.074713] DMA: preallocated 1024 KiB GFP_KERNEL pool for atomic allocations
[ 0.074849] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.074937] DMA: preallocated 1024 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.075057] audit: initializing netlink subsys (disabled)
[ 0.075203] audit: type=2000 audit(0.072:1): state=initialized audit_enabled=0 res=1
[ 0.077089] thermal_sys: Registered thermal governor 'step_wise'
[ 0.077092] thermal_sys: Registered thermal governor 'user_space'
[ 0.077093] thermal_sys: Registered thermal governor 'power_allocator'
[ 0.080565] cpuidle: using governor menu
[ 0.080817] hw-breakpoint: found 6 breakpoint and 4 watchpoint registers.
[ 0.080925] ASID allocator initialised with 32768 entries
[ 0.082832] Serial: AMBA PL011 UART driver
[ 0.093589] 31d0000.serial: ttyAMA0 at MMIO 0x31d0000 (irq = 117, base_baud = 0) is a SBSA
[ 0.105043] platform bpmp: Fixing up cyclic dependency with 2c60000.external-memory-controller
[ 0.114527] HugeTLB registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.114533] HugeTLB registered 32.0 MiB page size, pre-allocated 0 pages
[ 0.114536] HugeTLB registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.114537] HugeTLB registered 64.0 KiB page size, pre-allocated 0 pages
[ 0.115475] cryptd: max_cpu_qlen set to 1000
[ 0.117275] ACPI: Interpreter disabled.
[ 0.118649] VDD_1V8_AO: supplied by VDD_5V0_SYS
[ 0.118872] VDD_3V3_AO: supplied by VDD_5V0_SYS
[ 0.119153] VDD_AV10_HUB: supplied by VDD_5V0_SYS
[ 0.119635] iommu: Default domain type: Translated
[ 0.119641] iommu: DMA domain TLB invalidation policy: strict mode
[ 0.119985] SCSI subsystem initialized
[ 0.120227] vgaarb: loaded
[ 0.120455] usbcore: registered new interface driver usbfs
[ 0.120483] usbcore: registered new interface driver hub
[ 0.120500] usbcore: registered new device driver usb
[ 0.120941] pps_core: LinuxPPS API ver. 1 registered
[ 0.120946] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[ 0.120954] PTP clock support registered
[ 0.121028] EDAC MC: Ver: 3.0.0
[ 0.122374] Registered efivars operations
[ 0.122984] FPGA manager framework
[ 0.123082] Advanced Linux Sound Architecture Driver Initialized.
[ 0.123700] Bluetooth: Core ver 2.22
[ 0.123731] NET: Registered PF_BLUETOOTH protocol family
[ 0.123736] Bluetooth: HCI device and connection manager initialized
[ 0.123748] Bluetooth: HCI socket layer initialized
[ 0.123756] Bluetooth: L2CAP socket layer initialized
[ 0.123770] Bluetooth: SCO socket layer initialized
[ 0.124254] clocksource: Switched to clocksource arch_sys_counter
[ 0.158887] VFS: Disk quotas dquot_6.6.0
[ 0.158953] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.159194] pnp: PnP ACPI: disabled
[ 0.162511] NET: Registered PF_INET protocol family
[ 0.162826] IP idents hash table entries: 131072 (order: 8, 1048576 bytes, linear)
[ 0.164387] tcp_listen_portaddr_hash hash table entries: 4096 (order: 4, 65536 bytes, linear)
[ 0.164480] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.164491] TCP established hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.164586] TCP bind hash table entries: 65536 (order: 8, 1048576 bytes, linear)
[ 0.165987] TCP: Hash tables configured (established 65536 bind 65536)
[ 0.166169] UDP hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.166198] UDP-Lite hash table entries: 4096 (order: 5, 131072 bytes, linear)
[ 0.166406] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.166890] RPC: Registered named UNIX socket transport module.
[ 0.166894] RPC: Registered udp transport module.
[ 0.166895] RPC: Registered tcp transport module.
[ 0.166895] RPC: Registered tcp NFSv4.1 backchannel transport module.
[ 0.166914] PCI: CLS 0 bytes, default 64
[ 0.167145] Unpacking initramfs...
[ 0.173553] hw perfevents: enabled with armv8_cortex_a78 PMU driver, 7 counters available
[ 0.173864] kvm [1]: IPA Size Limit: 48 bits
[ 0.173901] kvm [1]: GICv3: no GICV resource entry
[ 0.173908] kvm [1]: disabling GICv2 emulation
[ 0.173923] kvm [1]: GIC system register CPU interface enabled
[ 0.173993] kvm [1]: vgic interrupt IRQ9
[ 0.174143] kvm [1]: VHE mode initialized successfully
[ 0.177679] Initialise system trusted keyrings
[ 0.177724] Key type blacklist registered
[ 0.177851] workingset: timestamp_bits=42 max_order=21 bucket_order=0
[ 0.181619] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[ 0.182084] NFS: Registering the id_resolver key type
[ 0.182124] Key type id_resolver registered
[ 0.182128] Key type id_legacy registered
[ 0.182173] nfs4filelayout_init: NFSv4 File Layout Driver Registering...
[ 0.182190] nfs4flexfilelayout_init: NFSv4 Flexfile Layout Driver Registering...
[ 0.182219] ntfs: driver 2.1.32 [Flags: R/O].
[ 0.182418] 9p: Installing v9fs 9p2000 file system support
[ 0.183090] integrity: Platform Keyring initialized
[ 0.196121] Key type asymmetric registered
[ 0.196128] Asymmetric key parser 'x509' registered
[ 0.196216] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 245)
[ 0.196224] io scheduler mq-deadline registered
[ 0.196231] io scheduler kyber registered
[ 0.207388] EINJ: ACPI disabled.
[ 0.219461] Serial: 8250/16550mod /lib/module4 port.15s, .14IRQa/kernel/aridrienas/pd
teg 0.22phy3] gra194 (H)SCu.k) driver initialized
[ 0.221661] msm_serial: driver initialized
ins 0 /lib/module3] printk.148-tonsoleernel/drityTCU0s/pnabconledtror/dwc/[ e-t.22330a194.ko arm
mu 8000000.iommu: probing hardware configuration...
[ 0.223311] arm-smmu 8000000.iommu: SMMUv2 with:
[ 0.223319] arm-smmu 8000000.iommu: stage 1 translation
[ 0.223322] arm-smmu 8000000.iommu: stage 2 translation
[ 0.223322] arm-smmu 8000000.iommu: nested translation
[ 0.223329] arm-smmu 8000000.iommu: stream matching with 128 register groups
[ 0.223332] arm-smmu 8000000.iommu: 128 context banks (0 stage-2 only)
[ 0.223346] arm-smmu 8000000.iommu: Supported page sizes: 0x61311000
[ 0.223349] arm-smmu 8000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.223350] arm-smmu 8000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.224405] arm-smmu 10000000.iommu: probing hardware configuration...
[ 0.224408] arm-smmu 10000000.iommu: SMMUv2 with:
[ 0.224410] arm-smmu 10000000.iommu: stage 1 translation
[ 0.224412] arm-smmu 10000000.iommu: stage 2 translation
[ 0.224413] arm-smmu 10000000.iommu: nested translation
[ 0.224416] arm-smmu 10000000.iommu: stream matching with 128 register groups
[ 0.224419] arm-smmu 10000000.iommu: 128 context banks (0 stage-2 only)
[ 0.224432] arm-smmu 10000000.iommu: Supported page sizes: 0x61311000
[ 0.224434] arm-smmu 10000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.224435] arm-smmu 10000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.224832] arm-smmu 12000000.iommu: probing hardware configuration...
[ 0.224835] arm-smmu 12000000.iommu: SMMUv2 with:
[ 0.224836] arm-smmu 12000000.iommu: stage 1 translation
[ 0.224837] arm-smmu 12000000.iommu: stage 2 translation
[ 0.224838] arm-smmu 12000000.iommu: nested translation
[ 0.224841] arm-smmu 12000000.iommu: stream matching with 128 register groups
[ 0.224844] arm-smmu 12000000.iommu: 128 context banks (0 stage-2 only)
[ 0.224848] arm-smmu 12000000.iommu: Supported page sizes: 0x61311000
[ 0.224849] arm-smmu 12000000.iommu: Stage-1: 48-bit VA -> 48-bit IPA
[ 0.224851] arm-smmu 12000000.iommu: Stage-2: 48-bit IPA -> 48-bit PA
[ 0.232333] loop: module loaded
[ 0.233196] megasas: 07.717.02.00-rc1
[ 0.237242] tun: Universal TUN/TAP device driver, 1.6
[ 0.237824] thunder_xcv, ver 1.0
[ 0.237849] thunder_bgx, ver 1.0
[ 0.237882] nicpf, ver 1.0
[ 0.238759] hclge is initializing
[ 0.238788] hns3: Hisilicon Ethernet Network Driver for Hip08 Family - version
[ 0.238796] hns3: Copyright (c) 2017 Huawei Corporation.
[ 0.238881] e1000: Intel(R) PRO/1000 Network Driver
[ 0.238889] e1000: Copyright (c) 1999-2006 Intel Corporation.
[ 0.238916] e1000e: Intel(R) PRO/1000 Network Driver
[ 0.238920] e1000e: Copyright(c) 1999 - 2015 Intel Corporation.
[ 0.238940] igb: Intel(R) Gigabit Ethernet Network Driver
[ 0.238945] igb: Copyright (c) 2007-2014 Intel Corporation.
[ 0.238957] igbvf: Intel(R) Gigabit Virtual Function Network Driver
[ 0.238963] igbvf: Copyright (c) 2009 - 2012 Intel Corporation.
[ 0.239202] sky2: driver version 1.30
[ 0.239911] VFIO - User Level meta-driver version: 0.3
[ 0.241593] ehci_hcd: USB 2.0 'Enhanced' Host Controller (EHCI) Driver
[ 0.241604] ehci-pci: EHCI PCI platform driver
[ 0.241631] ehci-platform: EHCI generic platform driver
[ 0.241718] ehci-orion: EHCI orion driver
[ 0.241786] ehci-exynos: EHCI Exynos driver
[ 0.241857] ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
[ 0.241881] ohci-pci: OHCI PCI platform driver
[ 0.241907] ohci-platform: OHCI generic platform driver
[ 0.241985] ohci-exynos: OHCI Exynos driver
[ 0.242438] usbcore: registered new interface driver usb-storage
[ 0.244284] i2c_dev: i2c /dev entries driver
[ 0.245629] pps pps0: new PPS source ktimer
[ 0.245639] pps pps0: ktimer PPS source registered
[ 0.245649] pps_ldisc: PPS line discipline registered
[ 0.247821] device-mapper: ioctl: 4.45.0-ioctl (2021-03-22) initialised: dm-devel@redhat.com
[ 0.249661] sdhci: Secure Digital Host Controller Interface driver
[ 0.249667] sdhci: Copyright(c) Pierre Ossman
[ 0.250134] Synopsys Designware Multimedia Card Interface Driver
[ 0.250765] sdhci-pltfm: SDHCI platform and OF driver helper
[ 0.251889] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.252817] SMCCC: SOC_ID: ID = jep106:036b:0234 Revision = 0x00000401
[ 0.253353] tegra-bpmp bpmp: Adding to iommu group 0
[ 0.254681] tegra-bpmp bpmp: firmware: e941463f35523d12ee54-da583751bbf
[ 0.526960] Freeing initrd memory: 20464K
[ 2.324969] clocksource: tsc: mask: 0xffffffffffffff max_cycles: 0xe6a171046, max_idle_ns: 881590405314 ns
[ 2.324993] clocksource: osc: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 49772407460 ns
[ 2.324997] clocksource: usec: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275 ns
[ 2.325245] hid: raw HID events driver (C) Jiri Kosina
[ 2.325685] usbcore: registered new interface driver usbhid
[ 2.325691] usbhid: USB HID core driver
[ 2.329531] optee: probing for conduit method.
[ 2.329588] optee: revision 4.2 (d78bc5fa)
[ 2.388989] optee: dynamic shared memory is enabled
[ 2.389260] optee: initialized driver
[ 2.391887] usbcore: registered new interface driver snd-usb-audio
[ 2.393385] NET: Registered PF_PACKET protocol family
[ 2.394109] Bluetooth: RFCOMM TTY layer initialized
[ 2.394152] Bluetooth: RFCOMM socket layer initialized
[ 2.394175] Bluetooth: RFCOMM ver 1.11
[ 2.394416] 9pnet: Installing 9P2000 support
[ 2.394523] Key type dns_resolver registered
[ 2.395381] printk: console [ttyTCU0]: printing thread started
[ 2.395444] Loading compiled-in X.509 certificates
[ 2.396709] Loaded X.509 cert 'Build time autogenerated kernel key: 7f1e7893f24e1cf3b68affc169b61dbde0fdceaa'
[ 2.428694] tegra-gpcdma 2600000.dma-controller: Adding to iommu group 1
[ 2.430733] tegra-gpcdma 2600000.dma-controller: GPC DMA driver register 31 channels
[ 2.432861] serial-tegra 3100000.serial: RX in PIO mode
[ 2.432869] serial-tegra 3100000.serial: TX in PIO mode
[ 2.432988] 3100000.serial: ttyTHS1 at MMIO 0x3100000 (irq = 112, base_baud = 0) is a TEGRA_UART
[ 2.434400] 3140000.serial: ttyTHS2 at MMIO 0x3140000 (irq = 113, base_baud = 0) is a TEGRA_UART
[ 2.436938] tegra_rtc c2a0000.rtc: registered as rtc1
[ 2.436949] tegra_rtc c2a0000.rtc: Tegra internal Real Time Clock
[ 2.437494] tegra-i2c 3160000.i2c: Adding to iommu group 1
[ 2.443885] tegra-i2c 3180000.i2c: Adding to iommu group 1
[ 2.447309] tegra-i2c 31b0000.i2c: Adding to iommu group 1
[ 2.451462] tegra-i2c c240000.i2c: Adding to iommu group 1
[ 2.453974] i2c 1-0025: Fixing up cyclic dependency with 3520000.padctl
[ 2.454900] tegra-i2c c250000.i2c: Adding to iommu group 1
[ 2.475017] cpufreq: cpufreq_online: CPU4: Running at unlisted initial frequency: 1785000 KHz, changing to: 1728000 KHz
[ 2.477744] tegra-xusb 3610000.usb: Adding to iommu group 2
[ 2.492341] tegra-xusb 3610000.usb: Firmware timestamp: 2023-02-10 03:48:10 UTC
[ 2.492348] tegra-xusb 3610000.usb: xHCI Host Controller
[ 2.492359] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 1
[ 2.493108] tegra-xusb 3610000.usb: hcc params 0x0180ff05 hci version 0x120 quirks 0x0000000000010810
[ 2.493128] tegra-xusb 3610000.usb: irq 124, io mem 0x03610000
[ 2.493247] tegra-xusb 3610000.usb: xHCI Host Controller
[ 2.493250] tegra-xusb 3610000.usb: new USB bus registered, assigned bus number 2
[ 2.493254] tegra-xusb 3610000.usb: Host supports USB 3.1 Enhanced SuperSpeed
[ 2.493697] hub 1-0:1.0: USB hub found
[ 2.493713] hub 1-0:1.0: 4 ports detected
[ 2.493991] hub 2-0:1.0: USB hub found
[ 2.494003] hub 2-0:1.0: 4 ports detected
[ 2.495486] sdhci-tegra 3400000.mmc: Adding to iommu group 3
[ 2.496330] irq: IRQ228: trimming hierarchy from :bus@0:pmc@c360000
[ 2.496384] irq: IRQ229: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 2.496447] input: gpio-keys as /devices/platform/gpio-keys/input/input0
[ 2.535497] ALSA device list:
[ 2.535500] No soundcards found.
[ 2.536696] sdhci-tegra 3400000.mmc: Got CD GPIO
[ 2.582796] irq: IRQ230: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 2.583102] mmc0: SDHCI controller on 3400000.mmc [3400000.mmc] using ADMA 64-bit
[ 2.584196] Freeing unused kernel memory: 7680K
[ 2.584288] Run /init as init process
[ 2.604223] Root device found: initrd
[ 2.620020] r8168: loading out-of-tree module taints kernel.
[ 2.622184] Mount initrd as rootfs and enter recovery mode
[ 2.832250] usb 1-2: new high-speed USB device number 2 using tegra-xusb
[ 3.007299] hub 1-2:1.0: USB hub found
[ 3.008816] hub 1-2:1.0: 4 ports detected
[ 3.089567] mmc0: new ultra high speed SDR104 SDXC card at address d555
[ 3.090013] mmcblk0: mmc0:d555 SA128 119 GiB
[ 3.095044] GPT:Primary header thinks Alt. header is not at the end of the disk.
[ 3.095046] GPT:47044607 != 249999359
[ 3.095049] GPT:Alternate GPT header not at the end of the disk.
[ 3.095049] GPT:47044607 != 249999359
[ 3.095051] GPT: Use GNU Parted to correct GPT errors.
[ 3.095064] mmcblk0: p1 p2 p3 p4 p5 p6 p7 p8 p9 p10 p11 p12 p13 p14 p15
[ 3.125243] usb 2-1: new SuperSpeed Plus Gen 2x1 USB device number 2 using tegra-xusb
[ 3.179570] hub 2-1:1.0: USB hub found
[ 3.182117] hub 2-1:1.0: 4 ports detected
[ 3.284422] usb 1-3: new full-speed USB device number 3 using tegra-xusb
[ 3.654233] tegra194-pcie 140a0000.pcie: Adding to iommu group 4
[ 3.760893] tegra194-pcie 140a0000.pcie: host bridge /bus@0/pcie@140a0000 ranges:
[ 3.760914] tegra194-pcie 140a0000.pcie: MEM 0x3240000000..0x3527ffffff -> 0x3240000000
[ 3.760921] tegra194-pcie 140a0000.pcie: MEM 0x3528000000..0x352fffffff -> 0x0040000000
[ 3.760924] tegra194-pcie 140a0000.pcie: IO 0x002a100000..0x002a1fffff -> 0x002a100000
[ 3.761298] tegra194-pcie 140a0000.pcie: iATU unroll: enabled
[ 3.761300] tegra194-pcie 140a0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 3.868267] tegra194-pcie 140a0000.pcie: Link up
[ 3.869750] tegra194-pcie 140a0000.pcie: Link up
[ 3.869800] tegra194-pcie 140a0000.pcie: PCI host bridge to bus 0008:00
[ 3.869804] pci_bus 0008:00: root bus resource [io 0x0000-0xfffff] (bus address [0x2a100000-0x2a1fffff])
[ 3.869807] pci_bus 0008:00: root bus resource [mem 0x3528000000-0x352fffffff] (bus address [0x40000000-0x47ffffff])
[ 3.869810] pci_bus 0008:00: root bus resource [bus 00-ff]
[ 3.869811] pci_bus 0008:00: root bus resource [mem 0x3240000000-0x3527ffffff pref]
[ 3.869858] pci 0008:00:00.0: [10de:229c] type 01 class 0x060400
[ 3.870018] pci 0008:00:00.0: PME# supported from D0 D3hot
[ 3.873269] pci 0008:01:00.0: [10ec:8168] type 00 class 0x020000
[ 3.873426] pci 0008:01:00.0: reg 0x10: initial BAR value 0x00000000 invalid
[ 3.873429] pci 0008:01:00.0: reg 0x10: [io size 0x0100]
[ 3.873611] pci 0008:01:00.0: reg 0x18: [mem 0x00000000-0x00000fff 64bit]
[ 3.873728] pci 0008:01:00.0: reg 0x20: [mem 0x00000000-0x00003fff 64bit]
[ 3.874716] pci 0008:01:00.0: supports D1 D2
[ 3.874718] pci 0008:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 3.887043] pci 0008:00:00.0: BAR 14: assigned [mem 0x3528000000-0x35280fffff]
[ 3.887047] pci 0008:00:00.0: BAR 13: assigned [io 0x1000-0x1fff]
[ 3.887050] pci 0008:01:00.0: BAR 4: assigned [mem 0x3528000000-0x3528003fff 64bit]
[ 3.887143] pci 0008:01:00.0: BAR 2: assigned [mem 0x3528004000-0x3528004fff 64bit]
[ 3.887235] pci 0008:01:00.0: BAR 0: assigned [io 0x1000-0x10ff]
[ 3.887263] pci 0008:00:00.0: PCI bridge to [bus 01-ff]
[ 3.887266] pci 0008:00:00.0: bridge window [io 0x1000-0x1fff]
[ 3.887270] pci 0008:00:00.0: bridge window [mem 0x3528000000-0x35280fffff]
[ 3.887363] pcieport 0008:00:00.0: Adding to iommu group 4
[ 3.887448] pcieport 0008:00:00.0: PME: Signaling with IRQ 189
[ 3.887985] pcieport 0008:00:00.0: AER: enabled with IRQ 189
[ 3.888165] r8168 0008:01:00.0: Adding to iommu group 4
[ 3.888223] r8168 Gigabit Ethernet driver 8.053.00-NAPI loaded
[ 3.888293] r8168 0008:01:00.0: enabling device (0000 -> 0003)
[ 3.905399] r8168: This product is covered by one or more of the following patents: US6,570,884, US6,115,776, and US6,327,625.
[ 3.907443] r8168 Copyright (C) 2024 Realtek NIC software team <nicfae@realtek.com>
[ 3.907443] This program comes with ABSOLUTELY NO WARRANTY; for details, please see <http://www.gnu.org/licenses/>.
[ 3.907443] This is free software, and you are welcome to redistribute it under certain conditions; see <http://www.gnu.org/licenses/>.
[ 3.907554] tegra194-pcie 14100000.pcie: Adding to iommu group 5
[ 3.908313] irq: IRQ232: trimming hierarchy from :bus@0:interrupt-controller@f400000-1
[ 3.909300] tegra194-pcie 14100000.pcie: host bridge /bus@0/pcie@14100000 ranges:
[ 3.909312] tegra194-pcie 14100000.pcie: MEM 0x2080000000..0x20a7ffffff -> 0x2080000000
[ 3.909317] tegra194-pcie 14100000.pcie: MEM 0x20a8000000..0x20afffffff -> 0x0040000000
[ 3.909321] tegra194-pcie 14100000.pcie: IO 0x0030100000..0x00301fffff -> 0x0030100000
[ 3.909593] tegra194-pcie 14100000.pcie: iATU unroll: enabled
[ 3.909594] tegra194-pcie 14100000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 4.016246] tegra194-pcie 14100000.pcie: Link up
[ 4.017583] tegra194-pcie 14100000.pcie: Link up
[ 4.017622] tegra194-pcie 14100000.pcie: PCI host bridge to bus 0001:00
[ 4.017625] pci_bus 0001:00: root bus resource [io 0x100000-0x1fffff] (bus address [0x30100000-0x301fffff])
[ 4.017628] pci_bus 0001:00: root bus resource [mem 0x20a8000000-0x20afffffff] (bus address [0x40000000-0x47ffffff])
[ 4.017630] pci_bus 0001:00: root bus resource [bus 00-ff]
[ 4.017631] pci_bus 0001:00: root bus resource [mem 0x2080000000-0x20a7ffffff pref]
[ 4.017675] pci 0001:00:00.0: [10de:229e] type 01 class 0x060400
[ 4.017842] pci 0001:00:00.0: PME# supported from D0 D3hot
[ 4.020891] pci 0001:01:00.0: [10ec:c822] type 00 class 0x028000
[ 4.021064] pci 0001:01:00.0: reg 0x10: [io 0x100000-0x1000ff]
[ 4.021265] pci 0001:01:00.0: reg 0x18: [mem 0x20a8000000-0x20a800ffff 64bit]
[ 4.022300] pci 0001:01:00.0: supports D1 D2
[ 4.022302] pci 0001:01:00.0: PME# supported from D0 D1 D2 D3hot D3cold
[ 4.035014] pci 0001:00:00.0: BAR 14: assigned [mem 0x20a8000000-0x20a80fffff]
[ 4.035017] pci 0001:00:00.0: BAR 13: assigned [io 0x100000-0x100fff]
[ 4.035026] pci 0001:01:00.0: BAR 2: assigned [mem 0x20a8000000-0x20a800ffff 64bit]
[ 4.035129] pci 0001:01:00.0: BAR 0: assigned [io 0x100000-0x1000ff]
[ 4.035162] pci 0001:00:00.0: PCI bridge to [bus 01-ff]
[ 4.035165] pci 0001:00:00.0: bridge window [io 0x100000-0x100fff]
[ 4.035169] pci 0001:00:00.0: bridge window [mem 0x20a8000000-0x20a80fffff]
[ 4.035245] pcieport 0001:00:00.0: Adding to iommu group 5
[ 4.035319] pcieport 0001:00:00.0: PME: Signaling with IRQ 191
[ 4.035865] pcieport 0001:00:00.0: AER: enabled with IRQ 191
[ 4.036127] tegra194-pcie 14160000.pcie: Adding to iommu group 6
[ 4.037658] tegra194-pcie 14160000.pcie: host bridge /bus@0/pcie@14160000 ranges:
[ 4.037670] tegra194-pcie 14160000.pcie: MEM 0x2140000000..0x2427ffffff -> 0x2140000000
[ 4.037676] tegra194-pcie 14160000.pcie: MEM 0x2428000000..0x242fffffff -> 0x0040000000
[ 4.037679] tegra194-pcie 14160000.pcie: IO 0x0036100000..0x00361fffff -> 0x0036100000
[ 4.037976] tegra194-pcie 14160000.pcie: iATU unroll: enabled
[ 4.037978] tegra194-pcie 14160000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 5.136265] tegra194-pcie 14160000.pcie: Phy link never came up
[ 6.138075] tegra194-pcie 14160000.pcie: Phy link never came up
[ 6.138134] tegra194-pcie 14160000.pcie: PCI host bridge to bus 0004:00
[ 6.138137] pci_bus 0004:00: root bus resource [io 0x200000-0x2fffff] (bus address [0x36100000-0x361fffff])
[ 6.138140] pci_bus 0004:00: root bus resource [mem 0x2428000000-0x242fffffff] (bus address [0x40000000-0x47ffffff])
[ 6.138143] pci_bus 0004:00: root bus resource [bus 00-ff]
[ 6.138145] pci_bus 0004:00: root bus resource [mem 0x2140000000-0x2427ffffff pref]
[ 6.138191] pci 0004:00:00.0: [10de:229c] type 01 class 0x060400
[ 6.138358] pci 0004:00:00.0: PME# supported from D0 D3hot
[ 6.143878] pci 0004:00:00.0: PCI bridge to [bus 01-ff]
[ 6.143963] pcieport 0004:00:00.0: Adding to iommu group 6
[ 6.144044] pcieport 0004:00:00.0: PME: Signaling with IRQ 193
[ 6.145308] pcieport 0004:00:00.0: AER: enabled with IRQ 193
[ 6.145599] pci_bus 0004:01: busn_res: [bus 01-ff] is released
[ 6.145685] pci 0004:00:00.0: Removing from iommu group 6
[ 6.145696] pci_bus 0004:00: busn_res: [bus 00-ff] is released
[ 6.146618] tegra194-pcie 141e0000.pcie: Adding to iommu group 7
[ 6.147737] tegra194-pcie 141e0000.pcie: host bridge /bus@0/pcie@141e0000 ranges:
[ 6.147749] tegra194-pcie 141e0000.pcie: MEM 0x3000000000..0x3227ffffff -> 0x3000000000
[ 6.147756] tegra194-pcie 141e0000.pcie: MEM 0x3228000000..0x322fffffff -> 0x0040000000
[ 6.147760] tegra194-pcie 141e0000.pcie: IO 0x003e100000..0x003e1fffff -> 0x003e100000
[ 6.148064] tegra194-pcie 141e0000.pcie: iATU unroll: enabled
[ 6.148067] tegra194-pcie 141e0000.pcie: Detected iATU regions: 8 outbound, 2 inbound
[ 7.258050] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.259863] tegra194-pcie 141e0000.pcie: Phy link never came up
[ 8.259911] tegra194-pcie 141e0000.pcie: PCI host bridge to bus 0007:00
[ 8.259914] pci_bus 0007:00: root bus resource [io 0x300000-0x3fffff] (bus address [0x3e100000-0x3e1fffff])
[ 8.259917] pci_bus 0007:00: root bus resource [mem 0x3228000000-0x322fffffff] (bus address [0x40000000-0x47ffffff])
[ 8.259920] pci_bus 0007:00: root bus resource [bus 00-ff]
[ 8.259924] pci_bus 0007:00: root bus resource [mem 0x3000000000-0x3227ffffff pref]
[ 8.259966] pci 0007:00:00.0: [10de:229a] type 01 class 0x060400
[ 8.260112] pci 0007:00:00.0: PME# supported from D0 D3hot
[ 8.265614] pci 0007:00:00.0: PCI bridge to [bus 01-ff]
[ 8.265697] pcieport 0007:00:00.0: Adding to iommu group 7
[ 8.265774] pcieport 0007:00:00.0: PME: Signaling with IRQ 195
[ 8.266322] pcieport 0007:00:00.0: AER: enabled with IRQ 195
[ 8.266557] pci_bus 0007:01: busn_res: [bus 01-ff] is released
[ 8.266631] pci 0007:00:00.0: Removing from iommu group 7
[ 8.266641] pci_bus 0007:00: busn_res: [bus 00-ff] is released
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme-core.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/nvme/host/nvme.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/thermal/tegra/tegra-bpmp-thermal.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/pwm/pwm-tegra.ko
insmod /lib/modules/5.15.148-tegra/kernel/drivers/hwmon/pwm-fan.ko
Checking whether device /dev/mmcblk?p1 exist
Looking for OTA work directory on the device(s): /d[ mmcblk.305828] Finding OTA work dir on external storage devices
[ 8.311037] mount /dev/mmcblk0p1 /mnt
[ 8.351094] EXT4-fs (mmcblk0p1): mounted filesystem with ordered data mode. Opts: (null). Quota mode: none.
[ 8.352816] is_boot_part_for_disk_enc /dev/mmcblk0p1 /mnt
[ 8.360449] Set rootfs=/dev/mmcblk0p1
[ 8.361710] Set dm_crypt=
[ 8.363487] OTA task runner nv_ota_run_tasks.sh is not found
bash: cannot set terminal process group (-1): Inappropriate ioctl for device
bash: no job control in this shell
bash-5.1# cat /proc/cmdline
bash-5.1# %
Has anyone run into L4TLauncher forcing a Recovery Boot out of the box on JetPack 6.2.1 images? Any pointers on why UEFI/L4TLauncher is bypassing extlinux.conf on the SD card would be greatly appreciated.
