Flash img file error. Something went wrong. If it is a compressed image, check the that the archive is not corrupted
i have encounter a error when trying to flash img file to the sd card using balena etcher. This is the error and log file.
I’d be happy to help you troubleshoot the issue with flashing the img file to the SD card using Balena Etcher on your Jetson Orin Nano.
Firstly, I’d like to clarify that the instructions provided in the context are for flashing an SD card for the Jetson Orin Nano Developer Kit, and it’s recommended to use Etcher for Linux. However, since you’re using Windows, I’ll provide instructions for Windows as well.
To troubleshoot the issue, let’s go through the steps:
  1. Formatting the SD card: Before flashing the img file, ensure that the SD card is properly formatted. You can use the SD Memory Card Formatter for Windows to format the card. Select the “Quick format” option and leave the “Volume label” blank.
  2. Using Etcher: Download and install Etcher for Windows. Launch Etcher and select the SD card drive. Then, select the img file you want to flash to the SD card. Make sure the img file is compatible with your Jetson Orin Nano Developer Kit.
  3. Error logs: You’ve provided two error logs, Capture 2 and Capture 8. Unfortunately, I couldn’t find any specific information about these errors in the provided context. However, I can suggest some general troubleshooting steps:
    • Check the SD card for any physical damage or corruption.
    • Ensure that the SD card is properly seated in the SD card slot.
    • Try using a different SD card or a different USB port.
    • Check the img file for any corruption or issues. You can try re-downloading the img file or verifying its integrity using a checksum tool.
  4. Alternative methods: If you’re still experiencing issues with Etcher, you can try using the Linux dd command to flash the img file to the SD card. This method is also recommended in the context.
To use the dd command, you’ll need to:
* Boot your Jetson Orin Nano Developer Kit into Linux.
* Insert the SD card into the SD card slot.
* Open a terminal and navigate to the directory where the img file is located.
* Use the `dd` command to flash the img file to the SD card. The command should be in the format: `sudo dd bs=4M if=<img_file> of=/dev/<sd_card_device>`
Replace <img_file> with the path to your img file, and <sd_card_device> with the device name of your SD card (e.g., /dev/sdb).
Comparison with other Jetson modules: The context provides instructions for flashing SD cards for different Jetson modules, including the Jetson Xavier NX and Jetson Orin NX. While the general steps are similar, the specific instructions and requirements may vary depending on the module. Ensure that you’re using the correct instructions and img file for your Jetson Orin Nano Developer Kit.
In summary, to resolve the issue with flashing the img file to the SD card using Balena Etcher on your Jetson Orin Nano, try the following:
  • Format the SD card using the SD Memory Card Formatter for Windows.
  • Use Etcher for Windows to flash the img file to the SD card.
  • Check the error logs and try troubleshooting steps such as checking the SD card for physical damage or corruption.
  • Consider using alternative methods such as the Linux dd command.
  • Ensure that you’re using the correct instructions and img file for your Jetson Orin Nano Developer Kit.
How do you download the sd card image?
Do you download the image from JetPack SDK | NVIDIA Developer ?
