I tried flashing the Jetson Orin Nano using the SDK Manager by using SD Card (128GB) and on Ubuntu 20.04 version but it failed to flash.
Here is the log details.
SDKM_logs_JetPack_6.0_(rev._2)_Linux_for_Jetson_Orin_Nano_modules_2024-07-10_10-37-52.zip (344.8 KB)
Before flashing I also properly set my jetson on Force recovery mode and connected it to the host PC (ubuntu 20.04) via a USB-C cable.
Help me with this
10:44:08.060 - Info: Failed to restart nfs-kernel-server.service: Unit proc-fs-nfsd.mount is masked.
Please make sure there is no firewall enabled on your host PC so the NFS server is not blocked.
My firewall is already Inactive.
sudo ufw status
Status: inactive
Check if this post helps:
systemd, nfs
Looks like some issues about the NFS server daemon.
system
Closed
July 24, 2024, 6:15am
5
