run DriveInstall_5.0.5.0bL_SDK_b3.run
at Flash AutoCruise Device with Single Guest Linux progress at installing for a long time
I can login the px2 though ssh
the terminal log
1 xxx
2 xxx
3 root 29050 0.0 0.0 198512 4756 ? Ssl 10:55 0:00 /home/xxx/NVIDIA/Drive/5050bL_SDK/_installer/sudo_daemon - installer=29001 -d=/home/xxx/NVIDIA/Drive/5050bL_SDK/_installer/tmp
4 0
5 /home/xxx/NVIDIA/Drive/5050bL_SDK///_installer/run_command -c=“/home/xxx/NVIDIA/Drive/5050bL_SDK//_installer/configure_minicom ttyUSB2 xxx minirc.v4l_device.autocruise” -d=/home/xxx/NVIDIA/Drive/5050bL_SDK///_installer/tmp -l=/home/xxx/NVIDIA/Drive/ 5050bL_SDK///_installer/logs/configure_minicom_minirc.v4l_device.autocruise.log
6 The user xxx' is already a member of dialout’.
7 root 29050 0.0 0.0 198512 4768 ? Ssl 10:55 0:00 /home/xxx/NVIDIA/Drive/5050bL_SDK/_installer/sudo_daemon - installer=29001 -d=/home/xxx/NVIDIA/Drive/5050bL_SDK/_installer/tmp
8 0
9 /home/xxx/NVIDIA/Drive/5050bL_SDK///_installer/run_command -c=“/home/xxx/NVIDIA/Drive/5050bL_SDK//_installer/configure_minicom ttyUSB1 xxx minirc.drivepx2.aurix” -d=/home/xxx/NVIDIA/Drive/5050bL_SDK///_installer/tmp -l=/home/xxx/NVIDIA/Drive/5050bL_SDK/// _installer/logs/configure_minicom_minirc.drivepx2.aurix.log
10 The user xxx' is already a member of dialout’.
11 Lockfile is stale. Overriding it..
12
13 Welcome to minicom 2.7
14
15 OPTIONS: I18n
16 Compiled on Feb 7 2016, 13:37:27.
17 Port /dev/ttyUSB1, 10:53:14
18
19 Press CTRL-A Z for help on special keys
