Flash Wirelessly ORIN NX 16GB
Hi, I am trying to find out if it is possible to flash ORIN NX 16Gb without the need of USB cable being connected to Orin NX. I have already flash it before.
If you are talking about “flash”, then it has to be on usb connection.
If you are talking about OTA update, then ethernet or wifi should be fine. Anything else that can ssh to device could be used here.
May I check what is the capabilities of OTA?
For OTA, please refer to the document - Software Packages and the Update Mechanism — Jetson Linux Developer Guide documentation (nvidia.com)
