Greetings,
I have problems to flash the TK1 Pro with Android according this https://github.com/NVIDIA/android-manifest guidance. My problem is that the jetson_flash.cfg cannot be found, also not manual.
I have to mention that the
cd $TOP
and
cd $OUT
did not work properly so i had to search for the shell files
envsetup.sh
and
nvflash
manually.
The last one can be found here:
jtk1-android-l-open-source/device/nvidia/platform/ardbeg/flash
In this directory I have additionally fastboot.bin, Android.mk and PM375_Hynix_2GB_… which I also tried but didn’t work.
Here the commands I used and the outputs:
~/jtk1-android-l-open-source/device/nvidia/platform/ardbeg/flash$ sudo ./nvflash --bct flash_pm358_792.cfg --setbct --configfile PM375_Hynix_2GB_H5TC4G63AFR_RDA_924MHz.cfg --dtbfile tegra124-jetson_tk1-pm375-000-c00-00.dtb --create --bl fastboot.bin --odmdata 0x6009C000 --go
Output:
Nvflash 4.13.0000 started
syntax error (8): SDRAM
nvflash configuration file error: success
~/jtk1-android-l-open-source/device/nvidia/platform/ardbeg/flash$ sudo ./nvflash --bct flash_pm358_792.cfg --setbct --configfile jetson_flash.cfg --dtbfile tegra124-jetson_tk1-pm375-000-c00-00.dtb --create --bl fastboot.bin --odmdata 0x6009C000 --go
Output:
nvflash configuration file error: file not found
I also tried this one, which I found somewhere (just tried it because it is named similiar):
jtk1-android-l-open-source/device/nvidia/platform/ardbeg/jetson_android_fastboot_nvtboot_dtb_emmc_full.cfg
~/jtk1-android-l-open-source/device/nvidia/platform/ardbeg/flash$ sudo ./nvflash --bct flash_pm358_792.cfg --setbct --configfile /home/philip/jtk1-android-l-open-source/device/nvidia/platform/ardbeg/jetson_android_fastboot_nvtboot_dtb_emmc_full.cfg --dtbfile tegra124-jetson_tk1-pm375-000-c00-00.dtb --create --bl fastboot.bin --odmdata 0x6009C000 --go
Output:
BR_CID: 0x340010017420a1811c00000018fe03c0
rcm version 0X400001
Common cfg check failed
Skipping BoardID read at miniloader level
System Information:
chip name: unknown
chip id: 0x40 major: 1 minor: 1
chip sku: 0x0
chip uid: 0x000000017420a1811c00000018fe03c0
macrovision: disabled
hdcp: disabled
jtag: disabled
sbk burned: false
board id: 0
warranty fuse: 0
dk burned: false
boot device: unknown
operating mode: 3
device config strap: 0
device config fuse: 0
sdram config strap: 0
RCM communication completed
Cfg file open failed
failed executing command 4 NvError 0x30013
setbct failed NvError 0x0
command failure/warning: bootloader download failed
My system is Ubuntu 16.04 LTS
Does anyone know what configfile I have to use and where to get it?
Or any other Idea?
