Software Version
DRIVE OS Linux 5.2.6
DRIVE OS Linux 5.2.6 and DriveWorks 4.0
DRIVE OS Linux 5.2.0
other DRIVE OS version
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.7.0.8846
other
Host Machine Version
native Ubuntu 18.04
other
Hello there,
I’m trying to install Yocto Linux SDK onto a Drive AGX Xavier. I followed the steps described here to install Foundation and the Linux SDK inside a ~/myDRIVEInstallation directory. Everything seems to be going successful here.
Then I bind it using:
make -f Makefile.bind PCT=linux BOARD=e3550b03-t194a
and try to flash it onto the target using:
./tools/host/flashtools/bootburn_t19x/bootburn.sh -b e3550b03-t194a -B qspi -x /dev/ttyUSB3
where I get the following error:
s_ERROR_TOOL_NVIMAGEGEN
:[E]: QbCreateKernImage_T19x : 704: Error FileNotFound (0x19)
:[E]: Error: File /home/host/myDRIVEInstallation/drive-t186ref-linux/kernel/yocto-tegra-initramfs-rootfs.img not found
:[E]: QbFindAndCreateImages : 1105: Error FileNotFound (0x19)
:[E]: Image Creation Failed for PartitionId 4
:[E]: QbCreatePartition : 1678: Error FileNotFound (0x19)
:[E]: failed to find and create images
:[E]: nvimagegen : 929: Error FileNotFound (0x19)
:[E]: Creating Partition images failed
:[E]: QbFindAndCreateImages : 1256: Error (Unknown) (0xff00)
:[E]: Failed to exectute nvimagegen
:[E]: QbCreatePartition : 1678: Error (Unknown) (0xff00)
:[E]: nvimagegen : 929: Error (Unknown) (0xff00)
Exception 53 raised in bootburn_active
File "./bootburn.py", line 139, in bootburn_active
bootburnLib.CreateFlashImages(targetConfig.f_FlashCfg)
File "/home/host/myDRIVEInstallation/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x_py/bootburn_lib.py", line 2491, in CreateFlashImages
self.GenerateImage(configFiles, l_Operation, p_TempDumpPath)
File "/home/host/myDRIVEInstallation/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x_py/bootburn_lib.py", line 2252, in GenerateImage
AbnormalTermination("s_ERROR_TOOL_NVIMAGEGEN", nverror.NvError_NvImagegen)
File "/home/host/myDRIVEInstallation/drive-t186ref-foundation/tools/host/flashtools/bootburn_t19x_py/flashtools_nverror.py", line 249, in AbnormalTermination
raise OSError(errorCode)
OSError: 53
Indeed, the file /home/host/myDRIVEInstallation/drive-t186ref-linux/kernel/yocto-tegra-initramfs-rootfs.img
does not exist so I assume that something went wrong with the build process.
Am I missing something here?
I also attached the complete output of the binding and flashing process. command_line_output (110.4 KB)
Any advise is much appreciated. Thank you very much!
