Hardware Platform: DRIVE AGX Xavier™ Developer Kit
Software Version: DRIVE Software 10.0
Host Machine Version: native Ubuntu 18.04
SDK Manager Version: 1.3.1.7110
When trying to flash my machine with the SDK Manager, I receive the following error:
/dev/ttyUSB3 not found on host. Please make sure no /dev/ttyUSB* files exist on host first then connect target board to host. Once connected, /dev/ttyUSB3 can be found.
I checked the Flashing Technical Bulletin (https://developer.nvidia.com/DRIVE/secure/docs/NVIDIA_DRIVE_AGX_Developer_Kit_Flashing_Technical_Bulletin_10.0.pdf) and found a possibly related issue under point 2.2. I checked my linux kernel version but it is 5.3.0-40 and not one of the described versions. I still tried the suggested workaround but my error persists with linux kernel version 4.15.0-88, which is listed as a version that provides resolution.
