Full factory reset (Solved)
I see the instructions on using the reset button to install modules via jetpack, but what are the instructions to do a full factory reset?
Greetings, Pim
Hi Pim, re-flashing your Jetson via recovery mode with JetPack will reset it to factory.
You can de-select packages from the JetPack component manager for those that you do not wish to have installed.
