Reset NX module to factory state
As the title suggests, is there a way for developers to reset the NX module to the factory state?In other words, the status of the module just obtained from the dealer for production.
If so, what tools are needed?What are the general operating steps?
Thanks&BR
hello Zz.W,
please check Jetson Xavier NX Developer Kit User Guide.
you may use 12-pin button header, [J12] .
please use pin-9 and pin-10 to put the developer kit into Force Recovery Mode if they are connected when it is powered on.
thanks
Hello Jerry,
Thank you for your reply. I believe the button header you are talking about is [J14]. I’m not very familiar with Flash Script Usage on Jetson, Can you tell me which Command line switch, or a combination, will accomplish the goal? I’m not really sure.
hello Zz.W,
had you refer to NX Developer Kit User Guide?
there’s instruction for you to put device enter forced-recovery mode.
thanks
hello Jerry,
Yep. Of course. I know about RCM, but I think I’m imagining something more complicated. Thank you for your reply.
BR
