I see FX 4600 in the “CUDA-Enabled GPU Products” list, but not in the “Products Supported” list on the Windows driver download page.
Will CUDA run on a Dell workstation with dual displays and FX4600 cards? Can the two cards 1) work in tandem, or 2) work independently?
Hi, From the main driver download page, for Quadro FX cards, select Quadro Performance Driver for Download Type.
For Windows XP, as an example, it will take you here: [url=“http://www.nvidia.com/object/winxp_169.61.html”]http://www.nvidia.com/object/winxp_169.61.html[/url] and supports the FX4600.
CUDA will work fine using 2 of these cards just the same as any CUDA-capable multi-GPU solutions. The programmer can explicitly directly them independently. There are multi-GPU source code examples in the CUDA SDK
