1 Monitor Gsync Compatible
1 3070 Ti - For Gaming - Connected to the monitor
2 3060 Ti - For Mining
If I connect only 1 GPU, G-Sync works perfectly without any configuration.
If I connect more than 1 GPU, G-Sync just does not work and the setting does not shows up on NVIDIA X Server Settings.
This is due to a limitation with X11 not the nvidia driver, hopefully on wayland nvidia will get vrr working. But it is not possible to have gsync or freesync working on X11
Thanks for the suggestion. I made it work on openSUSE. But now I have another problem:
If I set only the main GPU, GSYNC works fine. But if I set the other two (to be able to set the Coolbits and OC) GSYNC stops working.
This is my current xorg.conf file:
