GeForce RTX 3050 Ti Mobile on Linux mint Vanessa. Video stutters every few seconds on performance mode
This occurs even when just hovering the mouse with no apps open. There is no problem when it’s on on-demand mode where GPU usage is 0. Might have something to with fan speed?
Thank you.
nvidia-bug-report.log.gz (286.8 KB)
Xorg logs report nvidia issues
65.339] (EE) NVIDIA(GPU-0): WAIT (2, 8, 0x8000, 0x0003e1b8, 0x0003e1c0)
while dmesg reports issues coming from the pcie bus where the amd gpu is connected to
[   81.327208] pcieport 0000:00:08.1: PME: Spurious native interrupt!
Please check for a bios update. If that doesnt’t help, try upgrading the kernel using the liquorix ppa and maybe try setting kernel parameter pcie_aspm=off
None of the methods you have mentioned works. Probably have something to to with my machine not being a desktop or a driver bug or something.
Thanks nevertheless.
seeing you are on a ryzen and have tpm enabled from what i can tell from that nvidia bugreport log. you will eventually suffer from https://www.amd.com/en/support/kb/faq/pa-410 depending on what uses your tpm or not. and ive yet to see an actual laptop vendor patch this. so i would disable it in bios if you can. obviously comes at the consequences of not having an tpm if you used it for encryption or similiar.
