When use flash.sh, if Jetson L4T on developer computer (X86_64, Ubuntu 18.04) is never connected to target Jetson nano dev kit before, the command (line # 1036)
get_fuse_level fuselevel hwchipid bootauth;
will be stuck there. no error message, no time out.
comment out the line will solve the problem.
the bug will affect create-jetson-nano-sd-card-image.sh as well.
Hi sunxishan,
What’s JetPack version are you using?
Please share your flash and create sdcard image command.
hello sunxishan,
we cannot reproduce host machine stuck issue locally, we’re testing with below two pipelines on JetPack-4.2.2.
$ sudo ./flash.sh --no-flash jetson-nano-qspi-sd mmcblk0p1
$ sudo ./create-jetson-nano-sd-card-image.sh -o blob-1007.img -s 4096M -r 200
which JetPack release you’re working with,
may I also know what’s your testing commands,
thanks
the fuse setup may related to hardware so I list as much host info as I can:
host computer:
DELL XPS-8700
CPU Intel Core i7-4790
running Ubuntu X86_64 18.04 LTS with latest update
Dual hard drive:
/dev/sda 1.5T
/dev/sdb 150G
Linux OS loaded on /dev/sdb
install JetPack_4.2.2_Linux_GA_P3448
During installation, skip communication/firmware update with Jetson nano device (the host computer is in another room), installed all other packages.
then the command line trigger the problem:
sudo ./create-jetson-nano-sd-card-image.sh -o sd-blob.img -s 4G -r 200
tracing down the script in to create-jetson-nano-sd-card-image.sh the stuck point is
bash ./flashcmd.txt
run the command alone with flashcmd.txt contents:
sudo ./flash.sh --no-flash --no-systemimg p3448-0000-sd mmcblk0p1
tracing down the issue to the stuck point in flash.sh:
comment out the line, the issue is gone.
hello sunxishan,
could you please share what’s exactly those steps were done.
did you using SDKManager but skip all the installation process for just downloading the Jetson OS image?
hello sunxishan,
thanks for confirmation, I’m using the same steps as yours but cannot reproduce the issue locally.
since that commands parse board info, please workaround it for your temporary solutions.
thanks
Thanks jerry.
If it is not common issue i think it may be related to special hardware. Not worth digging more since we have workaround.
