I am trying to evaluate the ‘GL_OVR_Multiview
’ extension on a rtx3000
I wrote a small program that render points arranged in a cube to the left side and the right side of a window.
I do it by using two methods:
The first one - Rendering the cube to the left side and then rendering it to the right side (sequential).
The seconds method – Rendering the points only once while using the ‘GL_OVR_Multiview’ extension for sending the drawing to both sides of the window.
In both methods I measure the average rendering time over some frames.
(Just to clear things up, I render without waiting to the vertical sync, swap interval = 0(
To my surprise, I get a quite similar rendering time for both methods.
I would expect (according to NVIDIA papers on the subject) that the rendering time in the second method would be reduced by at least 30% comparing to the
rendering time of the first method.
Are my conclusions correct? Did I do something wrong in my program? Wrong board setup or missing setup?
Your help we be highly appreciated,
Yossi
Source.zip (6.9 KB)
Shaders.zip (1.7 KB)
