Gripper's pickers are passing through the target cube
Operating System
Ubuntu 22.04
GPU
NVIDIA GeForce RTX 5070
IsaacSim
5.0.0
Hello, I have problem that gripper picker 1 and 2 (you could said it as gripper finger) cannot grip the target cube as they are passing through. From my experiment, the root cause is both pickers passing through to any object, not only targeted cube. The robot model is imported from URDF file.
What I have done to solve this problem are:
  1. set rigid body enabled for both pickers and targeted cube.
  2. adding a new cube in the picker as its new body and set rigid body enabled
however, all of these solution are still not working as expected. I want both pickers can grip the targeted cube very well.
I have put the usd file in here. The usd file is isaac_manipulator/simulation.usd
isaac_manipulator.zip (5.6 MB)
Thank you
The pickers name are World/movensys_manipulator/picker_1 and World/movensys_manipulator/picker_2
Hi @salazar88, can you share a video of how these interpenetrations happen? I tried it myself and did not see interpenetrations, but I only moved the target boxes to collide with the picker. I also removed the background as it seemed like a heavy mesh that was slowing my simulation. You might want to look into simplifying the background or removing its collider.
Hello!
We noticed that this topic hasn’t received any recent updates from anyone reporting this issue, so we are closing it for now to help keep the forum organized.
If you are still experiencing this issue or have related questions, please create a GitHub Discussion or Issue in the Isaac Sim repository and include a link to this topic along with updated details. Mentioning or linking to this original topic provides helpful context and makes it easier for others to assist you.
Best regards,
