When I export the hairworks apx file in maya , it gives me the error that 566 out of 1280 fur strands share mesh vertices with other lines. I groomed the guild curves in xgen. So the curves were placed on the poly faces not the points. So please help me. Is there anyway to figure it out, and allowed the guild curves on the face can be exported correctly. I need your help. Thank you so much!
Related topics
| hairworks, warning: 2691 out of 3470 fur strands share mesh vertices with other lines. They will not | 6 | 2947 | November 9, 2018 | |
| Hairworks MAYA 2014 "fur stand share mesh vertices with other lines" problem | 0 | 613 | February 6, 2018 | |
| Hairworks Export Error | 3 | 2067 | May 23, 2018 | |
| hairworks export wont work | 3 | 1939 | July 17, 2015 | |
| HairWorks APX import Issue | 10 | 1247 | July 5, 2019 | |
| ERROR : Hair asset descriptor is not valid. Failed to open hair file("hairside.apx") | 1 | 684 | January 16, 2019 | |
| hair works does not import apx. | 0 | 719 | September 28, 2017 | |
| HairWorks Viewer - ERROR: hair asset does not have growth mesh face | 3 | 2063 | August 28, 2019 | |
| 1754 out of 1763 fur strands share mesh vertices with other lines. | 3 | 2686 | September 9, 2015 | |
| Hairworks Import Error | 2 | 1469 | February 9, 2017 |
