E1208 07:12:27.101070 106 model_repository_manager.cc:996] Poll failed for model directory 'riva-trt-conformer-en-US-asr-streaming-am-streaming': failed to open text file for read /data/models/riva-trt-conformer-en-US-asr-streaming-am-streaming/config.pbtxt: No such file or directory
If you are using the default (found in riva_model_loc variable inside config.sh)
Please run docker volume rm riva-model-repo
and bash riva_clean.sh
And retry the setup again and let us know if you still face the issue
I’m also experiencing the same “ Health Ready check failed” when running riva_start.sh. When checking the docker logs I see that it can’t connect to any of the remote hosts. I’m following the embedded QuickStart guide on Xavier NX
