Hello! I have the following problems when I use the agx development kit to flash? How can I solve it?
Hi @czq99 ,
I’ve seen that error occur multiple times when the disk space in the host system is too small. From what I can see, you have 6.23GB available in your system, that could be the cause of the problem, maybe getting more space is needed.
This is because to flash, an image is first created in your host system which includes the Jetson filesystem, and other multiple files are generated in the process, and that can take around 28GB, that’s why I think you are gonna need some more space.
You can also check this post that discuss a similar problem: SDKManager show install error on File System and OS
Best regards,
Roberto Gutierrez,
Embedded Software Engineer
