I am working on synthetic dataset generation in Isaac Sim and I want to export the generated data in the NuScenes dataset format.
Specifically, I am looking for guidance on:
How to structure the output (images, annotations, calibration, ego poses) so it matches NuScenes format.
Whether there is existing code, a writer, or an extension that supports exporting to NuScenes format.
If not directly available, what would be the best workflow to adapt the Replicator/SDG output to match NuScenes conventions?
I would really appreciate example code snippets or pointers to resources that show how to customize the data writer for this purpose. If anybody is working on this, I would like to collaborate with you:)I have attached my code below. The sample_annotation and instance is not populated. I am not sure where I am going wrong:
import os
import json
import time
import uuid
import shutil
import traceback
from isaacsim import SimulationApp
# -------------------- Launch Isaac Sim --------------------
simulation_app = SimulationApp({
"headless": True, # FIX: Run headless to save GPU memory
"renderer": "PathTracing", # FIX: Use less memory-intensive renderer
"width": 640, # FIX: Smaller window
"height": 480,
"multi_gpu": False,
"vsync": False,
"fast_shutdown": True,
"anti_aliasing": 0, # FIX: Disable anti-aliasing to save memory
"enable_scene_query_support": False, # FIX: Disable unnecessary features
"enable_livestream": False,
"subdiv_refinement_level": 0, # FIX: Reduce subdivision level
"physics_gpu": False # FIX: Use CPU physics to save GPU memory
import omni.usd
import omni.kit.app
from omni.replicator.core import AnnotatorRegistry
from pxr import Usd, UsdGeom, Gf
from PIL import Image
import numpy as np
import gc
# -------------------- CONFIG --------------------
OUT_DIR = os.path.expanduser("~/Downloads/trial9_nuscenes_ready")
NUM_FRAMES = 20 # FIX: Drastically reduce frame count to prevent GPU exhaustion
IMG_RES = (640, 480) # FIX: Reduce image resolution to save GPU memory
BATCH_SIZE = 5 # FIX: Save more frequently
MAX_RETRIES = 2 # FIX: Reduce retries to prevent hanging
os.makedirs(OUT_DIR, exist_ok=True)
os.makedirs(os.path.join(OUT_DIR, "samples"), exist_ok=True)
# Asset paths
WAREHOUSE_ROOT = "omniverse://localhost/Users/retrolifts/Assets/dataset_WH.usd"
FORKLIFT = {
"forklift_7500": "omniverse://localhost/Users/retrolifts/Assets/RM_FL_7500_2.usd"
FORKLIFT_SEM = "forklift_7500"
# -------------------- nuScenes table containers --------------------
scene_table = []
sample_table = []
sample_data_table = []
sensor_table = []
calibrated_sensor_table = []
ego_pose_table = []
instance_table = []
sample_annotation_table = []
category_table = []
log_table = []
attribute_table = []
visibility_table = []
# Helper function for tokens
def new_token():
return uuid.uuid4().hex
# Global tracking variables
prev_sample_token = ""
first_sample_token = ""
scene_token = new_token()
log_token = new_token()
sensor_tokens = {}
calibrated_sensor_tokens = {}
forklift_instances = {} # Track forklift instances across frames
# FIX: Add cleanup tracking
active_instances = []
active_annotators = []
current_prims = [] # Track current prims to ensure proper population
def wait_for_prim_population(max_wait=3.0):
"""Wait for prims to be properly populated before proceeding"""
import omni.usd
context = omni.usd.get_context()
if not context:
return False
stage = context.get_stage()
if not stage:
return False
# Wait for stage to be ready - simplified approach
wait_time = 0.0
step_size = 0.1
while wait_time < max_wait:
try:
# Force stage to process pending operations
omni.kit.app.get_app().update()
time.sleep(step_size)
wait_time += step_size
# FIX: Simple wait without HasPendingActiveAuthoring (not available in this version)
if wait_time > 0.5: # Minimum wait time
print(f"[INFO] Stage wait completed after {wait_time:.1f}s")
return True
except Exception as e:
print(f"[WARNING] Error waiting for population: {e}")
break
print(f"[WARNING] Stage wait completed after {max_wait}s")
return True # Continue anyway
# def cleanup_resources():
# """Properly cleanup GPU resources"""
# try:
# print("[INFO] Starting resource cleanup...")
# # Clear replicator instances first
# try:
# rep.randomizer.instantiate("", size=0, mode="scene_instance")
# print("[INFO] Cleared replicator instances")
# except Exception as e:
# print(f"[WARNING] Failed to clear replicator instances: {e}")
# # Clear active instances
# if active_instances:
# for instance in active_instances:
# try:
# # Force cleanup of instance
# if hasattr(instance, 'destroy'):
# instance.destroy()
# print(f"[WARNING] Failed to destroy instance: {e}")
# active_instances.clear()
# print(f"[INFO] Cleared {len(active_instances)} active instances")
# # Clear current prims tracking
# current_prims.clear()
# # Force garbage collection
# gc.collect()
# # Wait for cleanup to complete
# wait_for_prim_population(1.0)
# print("[INFO] Resource cleanup completed")
# print(f"[WARNING] Cleanup failed: {e}")
"""Properly cleanup GPU + USD resources before spawning next forklift"""
try:
try:
print("[INFO] Cleared replicator replicator instances")
# Delete forklift prims from stage
if stage:
prims_to_remove = []
for prim in stage.Traverse():
if prim.GetPath().pathString.startswith("/World") and "forklift" in prim.GetName().lower():
prims_to_remove.append(prim)
for prim in prims_to_remove:
try:
stage.RemovePrim(prim.GetPath())
print(f"[INFO] Removed prim: {prim.GetPath()}")
print(f"[WARNING] Could not remove prim {prim.GetPath()}: {e}")
# Clear current tracking
gc.collect()
# Initialize static tables
def initialize_static_tables():
# Category table
category_table.append({
"token": "cat_forklift",
"name": "vehicle.forklift",
"description": "Synthetic forklift category",
"index": 0
# Attribute table
attribute_table.extend([
"token": "attr_moving",
"name": "vehicle.moving",
"description": "Vehicle is moving"
"token": "attr_stopped",
"name": "vehicle.stopped",
"description": "Vehicle is stationary"
# Visibility table
visibility_table.extend([
"token": "vis_full",
"level": "v80-100",
"description": "visibility of whole object is between 80 and 100%"
"token": "vis_most",
"level": "v60-80",
"description": "visibility of whole object is between 60 and 80%"
# Log table
log_table.append({
"token": log_token,
"logfile": "synthetic_warehouse_001",
"vehicle": "isaac_sim_ego",
"date_captured": time.strftime("%Y-%m-%d"),
"location": "isaac-sim-warehouse"
# Scene table (will be updated with sample info later)
scene_table.append({
"token": scene_token,
"log_token": log_token,
"nbr_samples": NUM_FRAMES,
"first_sample_token": "",
"last_sample_token": "",
"name": "scene-warehouse-001",
"description": "Synthetic warehouse scene with forklift generated in Isaac Sim"
def compute_intrinsics():
"""Compute camera intrinsics matrix (flattened 3x3)"""
focal = 11.0 # mm
w_px, h_px = IMG_RES
ha, va = 36.0, 24.0 # sensor size in mm
fx = focal * (w_px / ha)
fy = focal * (h_px / va)
cx = w_px / 2.0
cy = h_px / 2.0
return [fx, 0.0, cx, 0.0, fy, cy, 0.0, 0.0, 1.0]
def create_sensors_and_calibration():
"""Create sensor and calibrated_sensor entries for cameras"""
camera_positions = [(-29.5, 29.5, 8.4)] # Only one camera
for i, pos in enumerate(camera_positions):
# Sensor entry
sensor_tok = new_token()
sensor_table.append({
"token": sensor_tok,
"channel": f"CAM_{i}",
"modality": "camera"
sensor_tokens[i] = sensor_tok
# Calibrated sensor entry
calib_tok = new_token()
calibrated_sensor_table.append({
"token": calib_tok,
"sensor_token": sensor_tok,
"translation": list(map(float, pos)),
"rotation": [1.0, 0.0, 0.0, 0.0], # w, x, y, z quaternion
"camera_intrinsic": compute_intrinsics()
calibrated_sensor_tokens[i] = calib_tok
def save_json_files():
"""Save all JSON tables to disk"""
tables = {
"scene": scene_table,
"sample": sample_table,
"sample_data": sample_data_table,
"sensor": sensor_table,
"calibrated_sensor": calibrated_sensor_table,
"ego_pose": ego_pose_table,
"instance": instance_table,
"sample_annotation": sample_annotation_table,
"category": category_table,
"log": log_table,
"attribute": attribute_table,
"visibility": visibility_table
for name, data in tables.items():
try:
file_path = os.path.join(OUT_DIR, f"{name}.json")
with open(file_path, "w") as f:
json.dump(data, f, indent=2)
print(f"[WARNING] Failed to save {name}.json: {e}")
def find_or_create_instance(forklift_id, category_token):
"""Find existing instance or create new one for a forklift"""
if forklift_id not in forklift_instances:
inst_tok = new_token()
forklift_instances[forklift_id] = {
"token": inst_tok,
"annotations": [],
"first_annotation_token": "",
"last_annotation_token": ""
# Create instance table entry
instance_table.append({
"token": inst_tok,
"category_token": category_token,
"nbr_annotations": 0,
return forklift_instances[forklift_id]
def link_sample_annotations(current_ann_token, instance_info):
"""Link sample annotations temporally using prev/next"""
if instance_info["annotations"]:
# Link with previous annotation
prev_ann_token = instance_info["annotations"][-1]
# Update previous annotation's next field
for ann in sample_annotation_table:
if ann["token"] == prev_ann_token:
ann["next"] = current_ann_token
break
# Set current annotation's prev field
return prev_ann_token
return ""
# FIX: Much more conservative forklift randomizer
def randomize_forklift(file_name, class_name, max_number=1):
"""Create forklift instances with minimal GPU usage"""
try:
print(f"[INFO] Creating single forklift instance")
# FIX: Clear any existing instances first
# FIX: Wait for cleanup
time.sleep(1.0)
# Create single instance with fixed parameters (no distributions)
instances = rep.randomizer.instantiate(
file_name, size=max_number, mode="scene_instance"
if instances is not None:
print("[INFO] Forklift instance created, applying modifications...")
with instances:
rep.modify.semantics([("class", class_name)])
# FIX: Use fixed pose to avoid distribution calculations
rep.modify.pose(
# position=(-20.0, 20.0, 0.0), # Fixed position
# rotation=(90, 0, 0), # Fixed rotation
# scale=1.0
position=rep.distribution.uniform((-29.5, 10.5, 0), (-10.5, 29.5, 0)),
rotation=rep.distribution.uniform((90, 0, -180), (90, 0, 180)),
scale=rep.distribution.uniform((0.9), (1.1)),
rep.modify.visibility(True)
print("[INFO] Forklift modifications applied successfully")
return instances
else:
print("[WARNING] Failed to create forklift instance")
return None
print(f"[ERROR] Forklift creation failed: {e}")
return None
# -------------------- Main execution --------------------
try:
print("[INFO] Initializing nuScenes dataset structure...")
print("[INFO] Setting up stage and environment...")
omni.usd.get_context().new_stage()
# Create environment
env = rep.create.from_usd(WAREHOUSE_ROOT)
# Lights - FIX: Minimal lighting setup to save GPU memory
with rep.new_layer():
rep.create.light(
light_type="Dome", # FIX: Use dome light instead of multiple rect lights
intensity=2000, # FIX: Much lower intensity
temperature=6000,
count=1 # FIX: Only one light
# Camera setup - FIX: Use only ONE camera to reduce GPU load
cameras = []
render_products = []
cam = rep.create.camera(focal_length=11)
rp = rep.create.render_product(cam, IMG_RES)
cameras.append(cam)
render_products.append(rp)
# Create annotators - FIX: Track them for cleanup
rgb_annotators = []
bbox3d_annotators = []
for rp in render_products:
rgb_ann = AnnotatorRegistry.get_annotator("rgb")
bbox3d_ann = AnnotatorRegistry.get_annotator("bounding_box_3d")
rgb_ann.attach([rp])
bbox3d_ann.attach([rp])
rgb_annotators.append(rgb_ann)
bbox3d_annotators.append(bbox3d_ann)
# Track for cleanup
active_annotators.extend([rgb_ann, bbox3d_ann])
# Create sensors and calibration
print("[INFO] Starting frame-by-frame data capture...")
# Track previous sample data tokens for linking
prev_sample_data_tokens = {}
for frame_id in range(NUM_FRAMES):
print(f"[INFO] Processing frame {frame_id+1}/{NUM_FRAMES}")
try:
# FIX: Much longer wait between frames to let GPU recover
if frame_id > 0:
cleanup_resources()
# FIX: Very long delay between frames
time.sleep(2.0)
# Randomize forklift placement - simplified
forklift_instances_obj = None
for k, fpath in FORKLIFT.items():
print(f"[INFO] Creating forklift: {k}")
forklift_instances_obj = randomize_forklift(fpath, k)
break # Only try once
# Skip frame if forklift creation failed
if forklift_instances_obj is None:
print(f"[WARNING] Skipping frame {frame_id} due to forklift failure")
continue
# Set camera poses
for i, cam in enumerate(cameras):
with cam:
rep.modify.pose(position=camera_positions[i], look_at=(-20, 20, 0))
# FIX: Simple orchestrator step with minimal retries
try:
print(f"[INFO] Stepping orchestrator for frame {frame_id}")
time.sleep(1.0) # Wait before stepping
rep.orchestrator.step(rt_subframes=1)
time.sleep(1.0) # Wait after stepping
print("[INFO] Orchestrator step completed")
print(f"[ERROR] Orchestrator step failed for frame {frame_id}: {e}")
continue
# Create sample
sample_tok = new_token()
timestamp_us = int((time.time() + frame_id * 0.5) * 1e6) # 0.5s intervals
sample_entry = {
"token": sample_tok,
"timestamp": timestamp_us,
"scene_token": scene_token,
"prev": prev_sample_token if prev_sample_token else "",
"next": ""
# Link previous sample
if prev_sample_token and sample_table:
sample_table[-1]["next"] = sample_tok
sample_table.append(sample_entry)
if not first_sample_token:
first_sample_token = sample_tok
# Create ego pose
ego_tok = new_token()
ego_pose_table.append({
"token": ego_tok,
"translation": [0.0, 0.0, 0.0] # x, y, z (z always 0 in nuScenes)
# Process each camera
current_sample_data_tokens = {}
for cam_idx in range(len(cameras)):
try:
# FIX: Add timeout and null checks for RGB data
rgb_data = None
for attempt in range(MAX_RETRIES):
try:
rgb_data = rgb_annotators[cam_idx].get_data()
if rgb_data is not None:
break
time.sleep(0.1)
print(f"[WARNING] RGB data attempt {attempt + 1} failed: {e}")
if attempt < MAX_RETRIES - 1:
time.sleep(0.2)
# Save image
channel_name = f"CAM_{cam_idx}"
channel_dir = os.path.join(OUT_DIR, "samples", channel_name)
os.makedirs(channel_dir, exist_ok=True)
# Generate filename
image_filename = f"n000-{time.strftime('%Y-%m-%d-%H-%M-%S')}+0000__{channel_name}__{timestamp_us}.jpg"
file_path = os.path.join(channel_dir, image_filename)
# FIX: More robust image conversion with validation
try:
if isinstance(rgb_data, np.ndarray):
# Validate array shape
if len(rgb_data.shape) != 3:
print(f"[WARNING] Invalid RGB data shape: {rgb_data.shape}")
continue
if rgb_data.dtype != np.uint8:
rgb_data = np.clip(rgb_data * 255, 0, 255).astype(np.uint8)
# Ensure proper image format
if rgb_data.shape[2] == 3:
Image.fromarray(rgb_data, 'RGB').save(file_path)
elif rgb_data.shape[2] == 4:
Image.fromarray(rgb_data[:,:,:3], 'RGB').save(file_path)
else:
print(f"[WARNING] Unexpected image channels: {rgb_data.shape[2]}")
continue
else:
print(f"[WARNING] RGB data is not numpy array: {type(rgb_data)}")
continue
print(f"[WARNING] Failed to save image for camera {cam_idx}: {e}")
continue
# Create sample_data entry
sd_tok = new_token()
sample_data_entry = {
"token": sd_tok,
"sample_token": sample_tok,
"ego_pose_token": ego_tok,
"calibrated_sensor_token": calibrated_sensor_tokens[cam_idx],
"filename": f"samples/{channel_name}/{image_filename}",
"fileformat": "jpg",
"width": IMG_RES[0],
"height": IMG_RES[1],
"is_key_frame": True,
"prev": prev_sample_data_tokens.get(cam_idx, ""),
"next": ""
# Link previous sample_data
if cam_idx in prev_sample_data_tokens and sample_data_table:
# Find and update previous sample_data entry
for sd in sample_data_table:
if sd["token"] == prev_sample_data_tokens[cam_idx]:
sd["next"] = sd_tok
break
sample_data_table.append(sample_data_entry)
current_sample_data_tokens[cam_idx] = sd_tok
print(f"[WARNING] Failed to process camera {cam_idx} for frame {frame_id}: {e}")
continue
# FIX: More robust 3D bounding box processing with validation
try:
bbox_data = None
try:
bbox_data = bbox3d_annotators[0].get_data()
if bbox_data is not None:
break
time.sleep(0.1)
print(f"[WARNING] Bbox data attempt {attempt + 1} failed: {e}")
time.sleep(0.2)
if bbox_data and len(bbox_data) > 0:
for bbox_idx, box in enumerate(bbox_data):
try:
# FIX: Validate box data structure
if not isinstance(box, dict):
print(f"[WARNING] Invalid box data type: {type(box)}")
continue
# Use semantic label or position as forklift ID
forklift_id = f"forklift_{bbox_idx}"
# Find or create instance
instance_info = find_or_create_instance(forklift_id, category_table[0]["token"])
# Create annotation
ann_tok = new_token()
# FIX: More robust extraction with validation
translation = [0.0, 0.0, 1.0] # Default values
size = [2.0, 1.5, 2.0] # Default size
rotation = [1.0, 0.0, 0.0, 0.0] # Default rotation
try:
if "translation" in box and box["translation"] is not None:
trans = box["translation"]
if isinstance(trans, (list, tuple, np.ndarray)) and len(trans) >= 3:
translation = [float(x) for x in trans[:3]]
except (ValueError, TypeError) as e:
print(f"[WARNING] Invalid translation data: {e}")
try:
if "size" in box and box["size"] is not None:
sz = box["size"]
if isinstance(sz, (list, tuple, np.ndarray)) and len(sz) >= 3:
size = [float(x) for x in sz[:3]]
print(f"[WARNING] Invalid size data: {e}")
try:
if "rotation" in box and box["rotation"] is not None:
rot = box["rotation"]
if isinstance(rot, (list, tuple, np.ndarray)) and len(rot) >= 4:
rotation = [float(x) for x in rot[:4]]
print(f"[WARNING] Invalid rotation data: {e}")
prev_ann = link_sample_annotations(ann_tok, instance_info)
sample_annotation_entry = {
"token": ann_tok,
"instance_token": instance_info["token"],
"attribute_tokens": ["attr_moving"],
"visibility_token": "vis_full",
"translation": translation,
"size": size,
"rotation": rotation,
"num_lidar_pts": 0,
"num_radar_pts": 0,
"next": "",
"prev": prev_ann
sample_annotation_table.append(sample_annotation_entry)
# Update instance tracking
instance_info["annotations"].append(ann_tok)
if not instance_info["first_annotation_token"]:
instance_info["first_annotation_token"] = ann_tok
instance_info["last_annotation_token"] = ann_tok
print(f"[WARNING] Failed to process bbox {bbox_idx}: {e}")
continue
print(f"[WARNING] Failed to process bounding boxes for frame {frame_id}: {e}")
# Update tracking variables
prev_sample_token = sample_tok
prev_sample_data_tokens = current_sample_data_tokens
# FIX: Save more frequently and with better cleanup
if frame_id % BATCH_SIZE == 0 or frame_id == NUM_FRAMES - 1:
try:
save_json_files()
print(f"[INFO] Saved progress at frame {frame_id}")
print(f"[WARNING] Failed to save progress: {e}")
# Force comprehensive cleanup
cleanup_resources()
print(f"[ERROR] Failed to process frame {frame_id}: {e}")
traceback.print_exc()
# Cleanup on error
cleanup_resources()
continue # Continue with next frame
# Finalize instance table
for forklift_id, instance_info in forklift_instances.items():
for inst in instance_table:
if inst["token"] == instance_info["token"]:
inst["nbr_annotations"] = len(instance_info["annotations"])
inst["first_annotation_token"] = instance_info["first_annotation_token"]
inst["last_annotation_token"] = instance_info["last_annotation_token"]
break
# Finalize scene table
if sample_table:
scene_table[0]["first_sample_token"] = first_sample_token
scene_table[0]["last_sample_token"] = sample_table[-1]["token"]
# Final save
save_json_files()
print(f"[SUCCESS] nuScenes dataset generated at: {OUT_DIR}")
print(f"[INFO] Generated {len(sample_table)} samples")
print(f"[INFO] Generated {len(sample_data_table)} camera images")
print(f"[INFO] Generated {len(sample_annotation_table)} annotations")
print(f"[INFO] Tracked {len(instance_table)} object instances")
print(f"[ERROR] Script failed: {e}")
finally:
print("[INFO] Shutting down...")
try:
# FIX: More thorough cleanup
cleanup_resources()
if rep.orchestrator.get_is_started():
rep.orchestrator.stop()
# Give time for proper shutdown
time.sleep(1.0)
print(f"[WARNING] Cleanup during shutdown failed: {e}")
simulation_app.close()
