Hi NVIDIA Dev Team,
I’m working on running the sample_path_perception (PathNet) sample using DriveWorks SDK 2.2 on an Ubuntu 18.04 x86_64 host machine with a dedicated NVIDIA RTX 3070 Ti GPU.
My Current Setup
Installed via SDK Manager (or manually from .deb and .tar packages):
- DriveWorks SDK:
2.2.3136 - DRIVE Software SDK:
5.1 - CUDA Toolkit:
10.2.19 - cuDNN:
7.5.1.14 - TensorRT:
5.1.4.2 - CMake:
3.22.6(manually installed, since 3.10 was too old for some build steps) - GCC:
7.5.0(close to required 7.4) - Ubuntu:
18.04
All DriveWorks samples including sample_hello_world are compiling and running fine.
I want to use the sample_path_perception application to run inference on offline .h264 videos using PathNet (ego-lane, adjacent lanes). I have the H264 videos ready and the sample builds correctly.
Error -
[01-04-2025 13:01:38] Platform: Detected Generic x86 Platform
[01-04-2025 13:01:38] TimeSource: monotonic epoch time offset is 1743490553847085
[01-04-2025 13:01:38] Platform: number of GPU devices detected 1
[01-04-2025 13:01:38] Platform: currently selected GPU device discrete ID 0
[01-04-2025 13:01:38] SDK: Resources mounted from .././data/
[01-04-2025 13:01:38] Initialize DriveWorks SDK v2.2.3136
[01-04-2025 13:01:38] Release build with GNU 7.4.0 from heads/buildbrain-branch-0-gca7b4b26e65
[01-04-2025 13:01:38] Initialize DriveWorks VisualizationSDK v2.2.3136
[01-04-2025 13:01:38] Initialize DriveWorksGL SDK v2.2.3136
[01-04-2025 13:01:38] GL-SDK: initialize OpenGL
[01-04-2025 13:01:38] SensorFactory::createSensor() → camera.virtual, debugView=false,detectionThreshold=0.5,fps=30,lookAheadDistance=1000000.0,offscreen=0,precision=fp32,profiling=1,rig=.././data/samples/pathDetection/rig.json,roi.height=800,roi.width=1920,roi.x=0,roi.y=400,temporalSmoothingFactor=0.1,useCudaGraph=0,video=.././data/samples/pathDetect
[01-04-2025 13:01:38] CameraNVCUVID: no seek table found at .././data/samples/pathDetection/video_paths.h264.seek, seeking is not available.
SimpleCamera: Camera image: 1920x1208
[PathDetectorApp]: Camera image with 1208x1920 at 30 FPS
[01-04-2025 13:01:38] Loading rig file: .././data/samples/pathDetection/rig.json
[01-04-2025 13:01:38] PathNet: Running in FP32 mode.
[01-04-2025 13:01:38] PathNet: Running from model: gv1xx-discrete/pathnet/pathnet_v1_fov60/fp32/pathnet.dnn
[01-04-2025 13:01:38] PathNet: Running from metadata: gv1xx-discrete/pathnet/pathnet_v1_fov60/fp32/pathnet_metadata.json
[01-04-2025 13:01:38] PathNet: Running from trt_json: gv1xx-discrete/pathnet/pathnet_v1_fov60/fp32/tensorrt_metadata.json
[01-04-2025 13:01:38] FileHeader: file header created with development build (patch = -1), assumingcompatibility
[01-04-2025 13:01:38] The engine plan file is generated on an incompatible device, expecting compute 8.6 got compute 7.0, please rebuild.
What I Need Help With
- How can I rebuild the
.enginefile for PathNet (DriveWorks 2.2) on x86 host with compute capability 8.6?
