@SivaRamaKrishnaNV
Thanks for the reply. It seems the DriveNet or Path Perception only can use live camera on the Pegasus hardware. So on the Host x86, can’t right?
From Path Perception Sample code:
int main(int argc, const char** argv)
// define all arguments used by the application
ProgramArguments args(argc, argv,
#ifdef VIBRANTE
ProgramArguments::Option_t("camera-type", "ar0231-rccb-bae-sf3324", "camera gmsl type (see sample_sensors_info for all available camera types on this platform)"),
ProgramArguments::Option_t("camera-group", "a", "input port"),
ProgramArguments::Option_t("camera-index", "0", "camera index within the camera-group 0-3"),
ProgramArguments::Option_t("slave", "0", "activate slave mode for Tegra B"),
ProgramArguments::Option_t("input-type", "video", "input type either video or camera"),
#endif
ProgramArguments::Option_t("video", (dw_samples::DataPath::get() + "/samples/pathDetection/video_paths.h264").c_str(), "path to video"),
ProgramArguments::Option_t("rig", (dw_samples::DataPath::get() + "/samples/pathDetection/rig.json").c_str(), "path to rig file"),
ProgramArguments::Option_t("fps", "30", "Frames per second that the video is played at."),
ProgramArguments::Option_t("detectionThreshold", "0.5", "PathNet detection threshold"),
ProgramArguments::Option_t("temporalSmoothingFactor", "0.1", "PathNet temporal smoothing factor"),
ProgramArguments::Option_t("roi.x", "0", "PathDetection roi top left x coordinate."),
ProgramArguments::Option_t("roi.y", "400", "PathDetection roi top left y coordinate."),
ProgramArguments::Option_t("roi.width", "1920", "PathDetection roi width."),
ProgramArguments::Option_t("roi.height", "800", "PathDetection roi height."),
ProgramArguments::Option_t("horizonHeight", "600", "y coordinate of the flat world horizon."),
ProgramArguments::Option_t("windowWidth", "1600", "output window width."),
ProgramArguments::Option_t("debugView", "true", "Debug view showing path fishbones."),
ProgramArguments::Option_t("showForks", "true", "Show the forking paths."),
ProgramArguments::Option_t("enableFovea", "false", "Enable fovea mode."),
ProgramArguments::Option_t("enableFoveaInTopView", "false", "In fovea mode, render fovea paths in top view instead of full resolution paths."),
ProgramArguments::Option_t("precision", "int8", "network precision, from {int8, fp16, fp32}."),
ProgramArguments::Option_t("customModelPath", "", "Custom model path. Folder should contain pathnet.dnn, pathnet_metadata.json and tensorrt_metadata.json"),
ProgramArguments::Option_t("useCudaGraph", "0", "switch to use Cuda Graph for infer")},
"PathDetection sample which detects paths.");
PathDetectorApp app(args);
int32_t width = std::stoi(args.get("windowWidth"));
app.initializeWindow("Path Detector Sample", width, width / 2, false);
return app.run();
