Help Recovering Jetson Orin NX 16G (reComputer J4012)
Hi all,
I’m working with a Jetson Orin NX Developer Kit mounted on the Seeed Studio reComputer J4012 carrier board. The system won’t boot into the OS, and I’m trying to find a recovery method that doesn’t require shorting the recovery pins or making hardware modifications.
Current Situation:
  • I can access the UEFI boot menu and UEFI shell, but it’s not booting into Ubuntu or any OS.
  • The board doesn’t seem to have a built-in reset or recovery button.
  • I know I could short the FC REC and GND pins to force recovery mode, but I’d prefer not to do any physical work on the board if I can avoid it.
What I’m Considering:
  • Creating a bootable USB stick from my PC with the JetPack image and trying to boot from USB on the Orin NX.
  • My goal is to either repair the existing installation or flash a clean OS without having to use recovery mode through hardware pins.
What I Need Help With:
  • Can I boot directly from USB on this board and reinstall JetPack without entering recovery mode?
  • Are there any other options I’m missing that are purely software-based?
Any advice would be appreciated! Thanks in advance.
Tony
Actual flash mandates recovery mode. Jetsons do not have a BIOS, thus they cannot self-flash. They do have the equivalent using software, but writing that requires the Jetson to be in recovery mode. That mode turns the Jetson into a custom USB device, and it is the flash software which has the driver for the custom USB device. No recovery mode implies no custom USB device.
