I have read several blogs/announcements that GPU work graphs (shader model 6.8) is supported on RTX 30 series. The RTX 3090 keeps failing in debug on any SM above 6.6. I shouldn’t have to enable windows developer mode for shader model 6.7 like I would for 6.8 should I ? latest stable DXC. latest stable Agility SDK. GDK PUBLIC.
Related topics
| RTX3060 don't support coda toolkit, cuda driver? | 3 | 1369 | March 26, 2021 | |
| How to fix the error: "The graphics card does not support Shader Model 3.0."? | 1 | 1406 | October 18, 2023 | |
| "Shader Debugger is not available" on NSight 5.0.015294, Win 10 and GTX980 | 3 | 1755 | March 9, 2016 | |
| Graphics card for shader debugging HLSL Directx11 | 2 | 2516 | June 22, 2016 | |
| Trying To Find Reason Why RTX 3060 Can't Use CUDA in Software | 9 | 8620 | August 2, 2022 | |
| Why nsight is not supported Geforce GTX 970M? | 0 | 849 | November 14, 2016 | |
| Unable to perform shader debugging or use pixel history when running locally | 3 | 1417 | January 4, 2016 | |
| GTX 660 debugering .glsl failed.I need help. | 0 | 551 | May 29, 2018 | |
| Rtx 3060 supported cuda setup? | 2 | 4092 | June 25, 2021 | |
| RTX3060 along side Quadro P1000 for machine learning in MS Windows 11 | 4 | 1761 | July 26, 2023 |
