Houdini omni_save Python error
Continuing the discussion from Information about the Houdini Omniverse Connector:
@wildsk.1990
I’m getting this error …
(Traceback (most recent call last):
File “omni_save”, line 3, in
File “D:/Projects/Nvidia Omniverse/Library/houdini-connector-100.0.0/houdini/python3.7libs\homni\utils.py”, line 341, in save_helper
if hou.hipFile.isNewFile():
AttributeError: ‘hipFile’ object has no attribute ‘isNewFile’)
Windows 10 64bit. Houdini 19.0.383. Python 3.
@wildsk.1990
Can you please write the steps you took to get that error? Any screenshots you can provide or the log files?
It happens when i click Save Hip. But the Copy Files works.
@wildsk.1990
Thank you for the details. We found the cause, it’s a Houdini version compatibility issue with the hou.hipFile.isNewFile() function.
We use a function that was added in Houdini 19.0.398. Please upgrade to Houdini 19.0.398 or newer to avoid this error.
Thank you.
