LCD is connected via hdmi to jetson nano board but resolution is not supported by cboot.(1280x800)
So when cboot is processing, broken image is displayed on LCD.
As far as I know cboot source code can’t be released.
Is there a way for me to remove hdmi display from cboot?
Or can you help cboot support 1280x800 resolution?
Could you try to remove “bmp.blob” in Linux_for_Tegra/bootloader and then flash the board again?
Hi Wayne,
I have already tried that and it still displayed broken image on LCD after remove “bmp.blob”.
This problem seems to be caused by display_boot_logo () when cboot is running.
I referenced t18x cboot source code.(cboot_src_t194.tbz2, kernel_boot.c)
How can I prevent display_boot_logo () from cboot?
Could you also upload a video during boot up along with the boot log?
Hi Wayne,
Boot up video : https://www.dropbox.com/s/drh5lpfyh4um63g/jetson_nano_booting.mp4?dl=0
Boot log is as below, which is from cboot to u-boot.
[0000.125] [L4T TegraBoot] (version 00.00.2018.01-l4t-39a9dc3d)
[0000.131] Processing in cold boot mode Bootloader 2
[0000.135] A02 Bootrom Patch rev = 1023
[0000.139] Power-up reason: pmc por
[0000.142] No Battery Present
[0000.145] pmic max77620 reset reason
[0000.148] pmic max77620 NVERC : 0x40
[0000.151] RamCode = 0
[0000.154] Platform has DDR4 type RAM
[0000.157] max77620 disabling SD1 Remote Sense
[0000.161] Setting DDR voltage to 1125mv
[0000.165] Serial Number of Pmic Max77663: 0x1231ea
[0000.173] Entering ramdump check
[0000.176] Get RamDumpCarveOut = 0x0
[0000.179] RamDumpCarveOut=0x0, RamDumperFlag=0xe59ff3f8
[0000.184] Last reboot was clean, booting normally!
[0000.189] Sdram initialization is successful
[0000.193] SecureOs Carveout Base=0x00000000ff800000 Size=0x00800000
[0000.199] Lp0 Carveout Base=0x00000000ff780000 Size=0x00001000
[0000.205] BpmpFw Carveout Base=0x00000000ff700000 Size=0x00080000
[0000.211] GSC1 Carveout Base=0x00000000ff600000 Size=0x00100000
[0000.216] GSC2 Carveout Base=0x00000000ff500000 Size=0x00100000
[0000.222] GSC4 Carveout Base=0x00000000ff400000 Size=0x00100000
[0000.228] GSC5 Carveout Base=0x00000000ff300000 Size=0x00100000
[0000.234] GSC3 Carveout Base=0x000000017f300000 Size=0x00d00000
[0000.250] RamDump Carveout Base=0x00000000ff280000 Size=0x00080000
[0000.256] Platform-DebugCarveout: 0
[0000.259] Nck Carveout Base=0x00000000ff080000 Size=0x00200000
[0000.265] Non secure mode, and RB not enabled.
[0000.489] Csd NumOfBlocks=124735488
[0000.494] Set High speed to 1
[0000.497] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandCompl ete func at 278 line
[0000.507] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.514] Number of retries left 4
[0000.519] Using GPT Primary to query partitions
[0000.523] Loading Tboot-CPU binary
[0000.533] Verifying TBC in OdmNonSecureSBK mode
[0000.543] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.550] Bootloader downloaded successfully.
[0000.554] Downloaded Tboot-CPU binary to 0xa0000258
[0000.559] MAX77620_GPIO5 configured
[0000.562] CPU power rail is up
[0000.565] CPU clock enabled
[0000.569] Performing RAM repair
[0000.572] Updating A64 Warmreset Address to 0xa00002e9
[0000.577] Loading NvTbootBootloaderDTB
[0000.603] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.668] Bootloader DTB Load Address: 0x83000000
[0000.673] Loading NvTbootKernelDTB
[0000.700] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.765] Kernel DTB Load Address: 0x83100000
[0000.770] Loading cboot binary
[0000.799] Verifying EBT in OdmNonSecureSBK mode
[0000.841] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.848] Bootloader downloaded successfully.
[0000.865] Using BFS PT to query partitions
[0000.869] Next binary entry address: 0x92c00258
[0000.873] BoardId: 3448
[0000.878] Overriding pmu board id with proc board id
[0000.882] Display board id is not available
[0000.910] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.962] /bpmp deleted
[0000.965] SC7EntryFw header found loaded at 0xff700000
[0001.153] OVR2 PMIC
[0001.155] Bpmp FW successfully loaded
[0001.159] WB0 init successfully at 0xff780000
[0001.163] Set NvDecSticky Bits
[0001.167] GSC2 address ff53fffc value c0edbbcc
[0001.173] GSC MC Settings done
[0001.177] TOS Image length 53680
[0001.180] Monitor size 53680
[0001.182] OS size 0
[0001.189] Secure Os AES-CMAC Verification Success!
[0001.194] TOS image cipher info: plaintext
[0001.198] Loading and Validation of Secure OS Successful
[0001.214] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.218] NvTbootPackSdramParams: start.
[0001.223] NvTbootPackSdramParams: done.
[0001.227] Tegraboot started after 52314 us
[0001.231] Basic modules init took 856297 us
[0001.235] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.241] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.246] Storage Device Read Time = 110 ms, Read Size = 2226 KB
[0001.252] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.257] Next stage binary read took 24146 us
[0001.262] Carveout took -35810 us
[0001.265] CPU initialization took 360080 us
[0001.269] Total time taken by TegraBoot 1204713 us
[0001.274] Starting CPU & Halting co-processor
64NOTICE: BL31: v1.3(release):23b153a63
NOTICE: BL31: Built : 22:39:57, Dec 9 2019
ERROR: Error initializing runtime service trusty_fast
[0001.396] RamCode = 0
[0001.400] LPDDR4 Training: Read DT: Number of tables = 2
[0001.405] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.418] EMC Training Successful
[0001.421] 408000 not found in DVFS table
[0001.428] RamCode = 0
[0001.431] DT Write: emc-table@204000 succeeded
[0001.436] DT Write: emc-table@1600000 succeeded
[0001.441] LPDDR4 Training: Write DT: Number of tables = 2
[0001.485]
[0001.486] Debug Init done
[0001.488] Marked DTB cacheable
[0001.491] Bootloader DTB loaded at 0x83000000
[0001.496] Marked DTB cacheable
[0001.499] Kernel DTB loaded at 0x83100000
[0001.503] DeviceTree Init done
[0001.518] Pinmux applied successfully
[0001.523] gicd_base: 0x50041000
[0001.526] gicc_base: 0x50042000
[0001.529] Interrupts Init done
[0001.533] Using base:0x60005090 & irq:208 for tick-timer
[0001.539] Using base:0x60005098 for delay-timer
[0001.543] platform_init_timer: DONE
[0001.546] Timer(tick) Init done
[0001.550] osc freq = 38400 khz
[0001.554]
[0001.555] Welcome to L4T Cboot
[0001.558]
[0001.560] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0001.564] calling constructors
[0001.567] initializing heap
[0001.570] initializing threads
[0001.573] initializing timers
[0001.576] creating bootstrap completion thread
[0001.580] top of bootstrap2()
[0001.583] CPU: ARM Cortex A57
[0001.586] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.591] initializing platform
[0001.598] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.603] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.607] Macronix QSPI chip present
[0001.611] SPI device register
[0001.614] init boot device
[0001.616] allocating memory for boot device(SPI)
[0001.621] registering boot device
[0001.640] sdmmc node status = okay
[0001.644] sdcard instance = 0
[0001.646] sdcard gpio handle 0x56
[0001.650] sdcard gpio pin 0xc9
[0001.653] sdcard gpio flags 0x0
[0001.656] vmmc-supply 0x99
[0001.658] Instance: 0
[0001.660] Allocating memory for context
[0001.664] enabling clock
[0001.667] sd card init
[0001.669] Check card present and stable
[0001.673] Send command 0
[0001.697] Send command 3
[0001.701] Set RCA for the card
[0001.704] Query card specific data by command 9
[0001.711] Parse CSD data
[0001.713] Send command 7
[0001.724] Calling sd device register
[0001.727] Init sdcard
[0001.729] Allocating memory for boot device
[0001.733] Registering user device
[0001.747] Enable APE clock
[0001.749] Un-powergate APE partition
[0001.753] of_register: registering tegra_udc to of_hal
[0001.758] of_register: registering inv20628-driver to of_hal
[0001.763] of_register: registering ads1015-driver to of_hal
[0001.769] of_register: registering lp8557-bl-driver to of_hal
[0001.775] of_register: registering bq2419x_charger to of_hal
[0001.780] of_register: registering bq27441_fuel_gauge to of_hal
[0001.792] gpio framework initialized
[0001.795] of_register: registering tca9539_gpio to of_hal
[0001.801] of_register: registering tca9539_gpio to of_hal
[0001.806] of_register: registering i2c_bus_driver to of_hal
[0001.811] of_register: registering i2c_bus_driver to of_hal
[0001.817] of_register: registering i2c_bus_driver to of_hal
[0001.823] pmic framework initialized
[0001.826] of_register: registering max77620_pmic to of_hal
[0001.832] regulator framework initialized
[0001.835] of_register: registering tps65132_bl_driver to of_hal
[0001.841] initializing target
[0001.847] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.855] board ID = D78, board SKU = 0
[0001.859] Skipping Z3!
[0001.864] fixed regulator driver initialized
[0001.881] initializing OF layer
[0001.884] NCK carveout not present
[0001.888] Skipping dts_overrides
[0001.892] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.908] I2C Bus Init done
[0001.911] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.921] I2C Bus Init done
[0001.924] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.934] I2C Bus Init done
[0001.937] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.947] I2C Bus Init done
[0001.950] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.960] I2C Bus Init done
[0001.963] of_children_init: Ops found for compatible string maxim,max77620
[0001.973] max77620_init using irq 118
[0001.978] register ‘maxim,max77620’ pmic
[0001.982] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.989] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.999] I2C Bus Init done
[0002.003] NCK carveout not present
[0002.013] Find /i2c@7000c000’s alias i2c0
[0002.017] get eeprom at 1-a0, size 256, type 0
[0002.025] Find /i2c@7000c500’s alias i2c2
[0002.029] get eeprom at 3-a0, size 256, type 0
[0002.034] get eeprom at 3-ae, size 256, type 0
[0002.038] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.043] I2C slave not started
[0002.046] I2C write failed
[0002.049] Writing offset failed
[0002.052] eeprom_init: EEPROM read failed
[0002.056] pm_ids_update: eeprom init failed
[0002.060] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.090] pm_ids_update: The pm board id is 3448-0000-200
[0002.097] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.105] pm_ids_update: pm id update successful
[0002.109] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.139] pm_ids_update: The pm board id is 3449-0000-200
[0002.146] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.154] pm_ids_update: pm id update successful
[0002.184] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.190] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.198] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.204] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.213] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:a6:f0
[0002.219] Plugin Manager: Parse ODM data 0x00094000
[0002.229] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=e xt4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0002.251] Find /i2c@7000c000’s alias i2c0
[0002.255] get eeprom at 1-a0, size 256, type 0
[0002.264] Find /i2c@7000c500’s alias i2c2
[0002.267] get eeprom at 3-a0, size 256, type 0
[0002.272] get eeprom at 3-ae, size 256, type 0
[0002.276] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.281] I2C slave not started
[0002.284] I2C write failed
[0002.287] Writing offset failed
[0002.290] eeprom_init: EEPROM read failed
[0002.294] pm_ids_update: eeprom init failed
[0002.298] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.328] pm_ids_update: The pm board id is 3448-0000-200
[0002.335] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.342] pm_ids_update: pm id update successful
[0002.346] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.376] pm_ids_update: The pm board id is 3449-0000-200
[0002.383] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.390] pm_ids_update: pm id update successful
[0002.421] Add serial number:1422419145039 as DT property
[0002.428] Applying platform configs
[0002.435] platform-init is not present. Skipping
[0002.439] calling apps_init()
[0002.459] Found 14 GPT partitions in “sd0”
[0002.463] Proceeding to Cold Boot
[0002.466] starting app android_boot_app
[0002.470] Device state: unlocked
[0002.473] display console init
[0002.482] could not find regulator
[0002.485] hdmi cable connected
[0002.501] edid read success
[0002.503] width = 1280, height = 800, frequency = 75000000
[0002.509] Best mode Width = 640, Height = 480, freq = 25174825
[0002.519] DT entry for leds-pwm not found
[0002.523] tmds-config node not found
[0002.528] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd -io-hdmi-dp’ regulator to 1050000 micro volts
[0002.542] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.550] could not find regulator
[0002.553] could not find regulator
[0002.556] could not find regulator
[0002.585] using default cmu settings
[0002.589] dc_hdmi_enable, starting HDMI initialisation
[0002.595] dc_hdmi_enable, HDMI initialisation complete
[0002.600] list and configure display window
[0002.605] display console init completed
[0002.612] subnode volume_up is not found !
[0002.616] subnode back is not found !
[0002.619] subnode volume_down is not found !
[0002.624] subnode menu is not found !
[0002.627] Gpio keyboard init success
[0002.671] found decompressor handler: lz4-legacy
[0002.685] decompressing blob (type 1)…
[0002.719] load_bmp_blob: panelresolution=480 type=0
[0002.770] decompressor handler not found
[0002.773] load_firmware_blob: Firmware blob loaded, entries=2
[0002.779] -------> se_aes_verify_sbk_clear: 747
[0002.784] se_aes_verify_sbk_clear: Error
[0002.788] bl_battery_charging: connected to external power supply
[0002.795] xusb is supported
[0002.801] error while finding nvidia,portmap
[0003.305] xusb blob version 0 size 124416
[0003.309] firmware size 124416
[0003.314] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.326] xhci0: 64 bytes context size, 32-bit DMA
[0003.366] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.386] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0004.036] uhub0: 9 ports with 9 removable, self powered
[0005.036] failed to get HID devices
[0005.039] failed to init xhci or no usb device attached
[0005.050] device_query_partition_size: failed to open partition sd0:MSC !
[0005.057] MSC Partition not found
[0005.063] device_query_partition_size: failed to open partition sd0:USP !
[0005.070] USP partition read failed!
[0005.073] blob_init: blob-partition USP header read failed
[0005.079] android_boot Unable to update recovery partition
[0005.084] kfs_getpartname: name = LNX
[0005.088] Loading kernel from LNX
[0005.185] load kernel from storage
[0005.197] decompressor handler not found
[0005.254] Successfully loaded kernel and ramdisk images
[0005.260] load_bmp_blob: panelresolution=480 type=0
[0005.334] display bmp image done
[0005.337] NCK carveout not present
[0005.340] Skipping dts_overrides
[0005.344] NCK carveout not present
[0005.354] Find /i2c@7000c000’s alias i2c0
[0005.357] get eeprom at 1-a0, size 256, type 0
[0005.366] Find /i2c@7000c500’s alias i2c2
[0005.370] get eeprom at 3-a0, size 256, type 0
[0005.375] get eeprom at 3-ae, size 256, type 0
[0005.379] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.384] I2C slave not started
[0005.387] I2C write failed
[0005.390] Writing offset failed
[0005.393] eeprom_init: EEPROM read failed
[0005.397] pm_ids_update: eeprom init failed
[0005.401] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.431] pm_ids_update: The pm board id is 3448-0000-200
[0005.438] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.446] pm_ids_update: pm id update successful
[0005.450] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.480] pm_ids_update: The pm board id is 3449-0000-200
[0005.487] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.495] pm_ids_update: pm id update successful
[0005.525] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.531] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.539] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.545] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.554] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:a6:f0
[0005.560] Plugin Manager: Parse ODM data 0x00094000
[0005.570] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=e xt4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.585] Add serial number:1422419145039 as DT property
[0005.594] “bpmp” doesn’t exist, creating
[0005.600] Updated bpmp info to DTB
[0005.605] Updated initrd info to DTB
[0005.608] “proc-board” doesn’t exist, creating
[0005.614] Updated board info to DTB
[0005.617] “pmu-board” doesn’t exist, creating
[0005.622] Updated board info to DTB
[0005.626] “display-board” doesn’t exist, creating
[0005.632] Updated board info to DTB
[0005.635] “reset” doesn’t exist, creating
[0005.639] Updated reset info to DTB
[0005.643] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize us b_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_sus pend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 max cpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 t egra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1
[0005.682] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.694] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,11 5200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.707] Updated bootarg info to DTB
[0005.711] Adding uuid 00000001644476410800000008070400 to DT
[0005.717] Adding eks info 0 to DT
[0005.722] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.728] Updated memory info to DTB
[0005.734] Updated system-lp0-disable info to DTB
[0005.742] set vdd_core voltage to 1075 mv
[0005.746] setting ‘vdd-core’ regulator to 1075000 micro volts
[0005.766] Found secure-pmc; disable BPMP
U-Boot 2016.07-g0536cf2a27 (Dec 09 2019 - 22:40:32 -0800)
TEGRA210
Model: NVIDIA P3450-Porg
Board: NVIDIA P3450-PORG
DRAM: 4 GiB
MMC: Tegra SD/MMC: 0, Tegra SD/MMC: 1
SF: Detected MX25U3235F with page size 256 Bytes, erase size 4 KiB, total 4 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: serial
Err: serial
Net: No ethernet found.
Hit any key to stop autoboot: 0
switch to partitions #0, OK
mmc1 is current device
Scanning mmc 1:1…
Found /boot/extlinux/extlinux.conf
Retrieving file: /boot/extlinux/extlinux.conf
730 bytes read in 81 ms (8.8 KiB/s)
1: primary kernel
Retrieving file: /boot/initrd
5487751 bytes read in 321 ms (16.3 MiB/s)
Retrieving file: /boot/Image
34191368 bytes read in 1531 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner _info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 conso le=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbco re.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0 x140000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 conso le=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait roo tfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
Flattened Device Tree blob at 83100000
Booting using the fdt blob at 0x83100000
reserving fdt memory region: addr=80000000 size=20000
Using Device Tree in place at 0000000083100000, end 00000000831776f0
Starting kernel …
Hi rheldsinji08,
I suspect if you really successfully remove the bmp.
Tried the same method in my device, there should be some error “BMP blob initialization failed” if you remove the bmp blob and it should never go to below one as your log.
[0002.685] decompressing blob (type 1)...
Could you share the step of how you removing bmp.blob?
Hi Wayne,
That’s right. Above log/video has not removed bmp.
I used a dummy file (size is 0) to remove bmp.blob.
If you need to check removed bmp.blop log, please reffer belows.
Boot up video : https://www.dropbox.com/s/fb0s3211ae3gmnn/jetson_nano_booting_removed_bmpblob.mp4?dl=0
In my opinion, this problem is not seem to be related to displaying bmp.blob, but to the HDMI output resolution.
[0002.386] hdmi cable connected
[0002.402] edid read success
[0002.404] width = 1280, height = 800, frequency = 75000000
[0002.418] Best mode Width = 640, Height = 480, freq = 25174825
[0002.490] dc_hdmi_enable, starting HDMI initialisation
[0002.496] dc_hdmi_enable, HDMI initialisation complete
So I wonder if there is a way to disable displaying bmp.blop or support 1280x800 resolution.
[0000.377] Csd NumOfBlocks=31116288
[0000.382] Set High speed to 1
[0000.385] Error mask set in wait for cmd complete with error 0x3 in HwSdmmcWaitForCommandComplete func at 278 line
[0000.396] Command complete wait failed with error 0x3 Interrupt 0x18001
[0000.402] Number of retries left 4
[0000.410] Using GPT Primary to query partitions
[0000.415] Loading Tboot-CPU binary
[0000.424] Verifying TBC in OdmNonSecureSBK mode
[0000.434] Bootloader load address is 0xa0000000, entry address is 0xa0000258
[0000.441] Bootloader downloaded successfully.
[0000.446] Downloaded Tboot-CPU binary to 0xa0000258
[0000.451] MAX77620_GPIO5 configured
[0000.454] CPU power rail is up
[0000.457] CPU clock enabled
[0000.461] Performing RAM repair
[0000.463] Updating A64 Warmreset Address to 0xa00002e9
[0000.469] Loading NvTbootBootloaderDTB
[0000.496] Verifying NvTbootBootloaderDTB in OdmNonSecureSBK mode
[0000.561] Bootloader DTB Load Address: 0x83000000
[0000.566] Loading NvTbootKernelDTB
[0000.592] Verifying NvTbootKernelDTB in OdmNonSecureSBK mode
[0000.658] Kernel DTB Load Address: 0x83100000
[0000.665] Loading cboot binary
[0000.695] Verifying EBT in OdmNonSecureSBK mode
[0000.736] Bootloader load address is 0x92c00000, entry address is 0x92c00258
[0000.743] Bootloader downloaded successfully.
[0000.760] Using BFS PT to query partitions
[0000.764] Next binary entry address: 0x92c00258
[0000.769] BoardId: 3448
[0000.773] Overriding pmu board id with proc board id
[0000.778] Display board id is not available
[0000.809] Verifying SC7EntryFw in OdmNonSecureSBK mode
[0000.861] /bpmp deleted
[0000.863] SC7EntryFw header found loaded at 0xff700000
[0001.052] OVR2 PMIC
[0001.054] Bpmp FW successfully loaded
[0001.061] WB0 init successfully at 0xff780000
[0001.065] Set NvDecSticky Bits
[0001.069] GSC2 address ff53fffc value c0edbbcc
[0001.075] GSC MC Settings done
[0001.081] TOS Image length 53680
[0001.084] Monitor size 53680
[0001.087] OS size 0
[0001.097] Secure Os AES-CMAC Verification Success!
[0001.101] TOS image cipher info: plaintext
[0001.105] Loading and Validation of Secure OS Successful
[0001.121] SC7 Entry Firmware - 0xff700000, 0x4000
[0001.126] NvTbootPackSdramParams: start.
[0001.131] NvTbootPackSdramParams: done.
[0001.135] Tegraboot started after 52329 us
[0001.139] Basic modules init took 749329 us
[0001.143] Sec Bootdevice Read Time = 12 ms, Read Size = 65 KB
[0001.148] Sec Bootdevice Write Time = 0 ms, Write Size = 0 KB
[0001.154] Storage Device Read Time = 130 ms, Read Size = 2226 KB
[0001.159] Storage Device Write Time = 0 ms, Write Size = 0 KB
[0001.165] Next stage binary read took 27152 us
[0001.169] Carveout took -38816 us
[0001.172] CPU initialization took 372316 us
[0001.176] Total time taken by TegraBoot 1109981 us
[0001.181] Starting CPU & Halting co-processor
[0001.303] RamCode = 0
[0001.308] LPDDR4 Training: Read DT: Number of tables = 2
[0001.313] EMC Training (SRC-freq: 204000; DST-freq: 1600000)
[0001.326] EMC Training Successful
[0001.329] 408000 not found in DVFS table
[0001.335] RamCode = 0
[0001.339] DT Write: emc-table@204000 succeeded
[0001.344] DT Write: emc-table@1600000 succeeded
[0001.348] LPDDR4 Training: Write DT: Number of tables = 2
[0001.390]
[0001.391] Debug Init done
[0001.394] Marked DTB cacheable
[0001.397] Bootloader DTB loaded at 0x83000000
[0001.401] Marked DTB cacheable
[0001.404] Kernel DTB loaded at 0x83100000
[0001.408] DeviceTree Init done
[0001.424] Pinmux applied successfully
[0001.428] gicd_base: 0x50041000
[0001.431] gicc_base: 0x50042000
[0001.434] Interrupts Init done
[0001.439] Using base:0x60005090 & irq:208 for tick-timer
[0001.444] Using base:0x60005098 for delay-timer
[0001.448] platform_init_timer: DONE
[0001.452] Timer(tick) Init done
[0001.456] osc freq = 38400 khz
[0001.460]
[0001.461] Welcome to L4T Cboot
[0001.464]
[0001.465] Cboot Version: 00.00.2018.01-t210-40c3ff9c
[0001.470] calling constructors
[0001.473] initializing heap
[0001.475] initializing threads
[0001.478] initializing timers
[0001.481] creating bootstrap completion thread
[0001.486] top of bootstrap2()
[0001.489] CPU: ARM Cortex A57
[0001.491] CPU: MIDR: 0x411FD071, MPIDR: 0x80000000
[0001.496] initializing platform
[0001.504] Manufacturer: MF = 0xc2, ID MSB = 0x25
[0001.508] ID LSB = 0x36, ID-CFI len = 194 bytes
[0001.513] Macronix QSPI chip present
[0001.516] SPI device register
[0001.519] init boot device
[0001.522] allocating memory for boot device(SPI)
[0001.526] registering boot device
[0001.536] sdmmc node status = okay
[0001.539] sdcard instance = 0
[0001.542] sdcard gpio handle 0x56
[0001.545] sdcard gpio pin 0xc9
[0001.548] sdcard gpio flags 0x0
[0001.551] vmmc-supply 0x99
[0001.554] Instance: 0
[0001.556] Allocating memory for context
[0001.559] enabling clock
[0001.562] sd card init
[0001.564] Check card present and stable
[0001.568] Send command 0
[0001.592] Send command 3
[0001.597] Set RCA for the card
[0001.600] Query card specific data by command 9
[0001.606] Parse CSD data
[0001.608] Send command 7
[0001.619] Calling sd device register
[0001.622] Init sdcard
[0001.624] Allocating memory for boot device
[0001.629] Registering user device
[0001.642] Enable APE clock
[0001.644] Un-powergate APE partition
[0001.648] of_register: registering tegra_udc to of_hal
[0001.653] of_register: registering inv20628-driver to of_hal
[0001.659] of_register: registering ads1015-driver to of_hal
[0001.664] of_register: registering lp8557-bl-driver to of_hal
[0001.670] of_register: registering bq2419x_charger to of_hal
[0001.676] of_register: registering bq27441_fuel_gauge to of_hal
[0001.687] gpio framework initialized
[0001.690] of_register: registering tca9539_gpio to of_hal
[0001.696] of_register: registering tca9539_gpio to of_hal
[0001.701] of_register: registering i2c_bus_driver to of_hal
[0001.707] of_register: registering i2c_bus_driver to of_hal
[0001.712] of_register: registering i2c_bus_driver to of_hal
[0001.718] pmic framework initialized
[0001.721] of_register: registering max77620_pmic to of_hal
[0001.727] regulator framework initialized
[0001.731] of_register: registering tps65132_bl_driver to of_hal
[0001.737] initializing target
[0001.743] gpio_driver_register: register ‘tegra_gpio_driver’ driver
[0001.751] board ID = D78, board SKU = 0
[0001.754] Skipping Z3!
[0001.759] fixed regulator driver initialized
[0001.776] initializing OF layer
[0001.779] NCK carveout not present
[0001.783] Skipping dts_overrides
[0001.787] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.804] I2C Bus Init done
[0001.806] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.817] I2C Bus Init done
[0001.819] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.830] I2C Bus Init done
[0001.832] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.843] I2C Bus Init done
[0001.845] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.856] I2C Bus Init done
[0001.858] of_children_init: Ops found for compatible string maxim,max77620
[0001.869] max77620_init using irq 118
[0001.873] register ‘maxim,max77620’ pmic
[0001.878] gpio_driver_register: register ‘max77620-gpio’ driver
[0001.884] of_children_init: Ops found for compatible string nvidia,tegra210-i2c
[0001.894] I2C Bus Init done
[0001.898] NCK carveout not present
[0001.908] Find /i2c@7000c000’s alias i2c0
[0001.912] get eeprom at 1-a0, size 256, type 0
[0001.921] Find /i2c@7000c500’s alias i2c2
[0001.925] get eeprom at 3-a0, size 256, type 0
[0001.929] get eeprom at 3-ae, size 256, type 0
[0001.933] pm_ids_update: Updating 1,a0, size 256, type 0
[0001.939] I2C slave not started
[0001.942] I2C write failed
[0001.944] Writing offset failed
[0001.947] eeprom_init: EEPROM read failed
[0001.951] pm_ids_update: eeprom init failed
[0001.955] pm_ids_update: Updating 3,a0, size 256, type 0
[0001.985] pm_ids_update: The pm board id is 3448-0000-200
[0001.992] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.000] pm_ids_update: pm id update successful
[0002.005] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.035] pm_ids_update: The pm board id is 3449-0000-200
[0002.041] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.049] pm_ids_update: pm id update successful
[0002.080] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.086] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0002.094] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0002.100] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0002.108] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:a6:f0
[0002.115] Plugin Manager: Parse ODM data 0x00094000
[0002.125] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 net.ifnames=0 logo.nologo
[0002.145] Find /i2c@7000c000’s alias i2c0
[0002.149] get eeprom at 1-a0, size 256, type 0
[0002.158] Find /i2c@7000c500’s alias i2c2
[0002.162] get eeprom at 3-a0, size 256, type 0
[0002.166] get eeprom at 3-ae, size 256, type 0
[0002.170] pm_ids_update: Updating 1,a0, size 256, type 0
[0002.176] I2C slave not started
[0002.179] I2C write failed
[0002.181] Writing offset failed
[0002.184] eeprom_init: EEPROM read failed
[0002.188] pm_ids_update: eeprom init failed
[0002.192] pm_ids_update: Updating 3,a0, size 256, type 0
[0002.222] pm_ids_update: The pm board id is 3448-0000-200
[0002.229] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0002.236] pm_ids_update: pm id update successful
[0002.241] pm_ids_update: Updating 3,ae, size 256, type 0
[0002.271] pm_ids_update: The pm board id is 3449-0000-200
[0002.277] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0002.284] pm_ids_update: pm id update successful
[0002.315] Add serial number:1422419145039 as DT property
[0002.323] Applying platform configs
[0002.329] platform-init is not present. Skipping
[0002.334] calling apps_init()
[0002.343] Error in command_complete 18001 int_status
[0002.360] Found 14 GPT partitions in “sd0”
[0002.364] Proceeding to Cold Boot
[0002.368] starting app android_boot_app
[0002.371] Device state: unlocked
[0002.374] display console init
[0002.383] could not find regulator
[0002.410] DT entry for leds-pwm not found
[0002.425] tmds-config node not found
[0002.429] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.443] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.451] could not find regulator
[0002.454] could not find regulator
[0002.458] could not find regulatorf
[0002.486] using default cmu settings
[0002.501] list and configure display window
[0002.506] display console init completed
[0002.513] subnode volume_up is not found !
[0002.517] subnode back is not found !
[0002.521] subnode volume_down is not found !
[0002.525] subnode menu is not found !
[0002.529] Gpio keyboard init success
[0002.546] blob_init: BMP partition does not have valid Blob
[0002.552] load_bmp_blob: BMP blob initialization failed
[0002.557] Could not load/initialize BMP blob…ignoring
[0002.611] decompressor handler not found
[0002.615] load_firmware_blob: Firmware blob loaded, entries=2
[0002.621] -------> se_aes_verify_sbk_clear: 747
[0002.625] se_aes_verify_sbk_clear: Error
[0002.629] bl_battery_charging: connected to external power supply
[0002.636] xusb is supported
[0002.642] error while finding nvidia,portmap
[0003.147] xusb blob version 0 size 124416
[0003.151] firmware size 124416
[0003.155] Firmware timestamp: 0x5da88fc3, Version: 50.25 release
[0003.171] xhci0: 64 bytes context size, 32-bit DMA
[0003.211] usbus0: 5.0Gbps Super Speed USB v3.0
[0003.231] uhub0: <Nvidia XHCI root HUB, class 9/0, rev 3.00/1.00, addr 1> on usbus0
[0003.881] uhub0: 9 ports with 9 removable, self powered
[0004.881] failed to get HID devices
[0004.885] failed to init xhci or no usb device attached
[0004.895] device_query_partition_size: failed to open partition sd0:MSC !
[0004.902] MSC Partition not found
[0004.908] device_query_partition_size: failed to open partition sd0:USP !
[0004.915] USP partition read failed!
[0004.918] blob_init: blob-partition USP header read failed
[0004.924] android_boot Unable to update recovery partition
[0004.929] kfs_getpartname: name = LNX
[0004.933] Loading kernel from LNX
[0005.031] load kernel from storage
[0005.042] decompressor handler not found
[0005.099] Successfully loaded kernel and ramdisk images
[0005.120] blob_init: BMP partition does not have valid Blob
[0005.125] load_bmp_blob: BMP blob initialization failed
[0005.130] bmp blob is not loaded and initialized
[0005.135] Failed to display boot-logo
[0005.139] NCK carveout not present
[0005.142] Skipping dts_overrides
[0005.145] NCK carveout not present
[0005.155] Find /i2c@7000c000’s alias i2c0
[0005.159] get eeprom at 1-a0, size 256, type 0
[0005.168] Find /i2c@7000c500’s alias i2c2
[0005.172] get eeprom at 3-a0, size 256, type 0
[0005.176] get eeprom at 3-ae, size 256, type 0
[0005.180] pm_ids_update: Updating 1,a0, size 256, type 0
[0005.186] I2C slave not started
[0005.189] I2C write failed
[0005.191] Writing offset failed
[0005.194] eeprom_init: EEPROM read failed
[0005.198] pm_ids_update: eeprom init failed
[0005.202] pm_ids_update: Updating 3,a0, size 256, type 0
[0005.233] pm_ids_update: The pm board id is 3448-0000-200
[0005.239] Adding plugin-manager/ids/3448-0000-200=/i2c@7000c500:module@0x50
[0005.247] pm_ids_update: pm id update successful
[0005.252] pm_ids_update: Updating 3,ae, size 256, type 0
[0005.282] pm_ids_update: The pm board id is 3449-0000-200
[0005.288] Adding plugin-manager/ids/3449-0000-200=/i2c@7000c500:module@0x57
[0005.296] pm_ids_update: pm id update successful
[0005.327] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.333] shim_eeprom_update_mac:267: Failed to update 0 MAC address in DTB
[0005.341] eeprom_get_mac: EEPROM invalid MAC address (all 0xff)
[0005.347] shim_eeprom_update_mac:267: Failed to update 1 MAC address in DTB
[0005.355] updating /chosen/nvidia,ethernet-mac node 00:04:4b:e6:a6:f0
[0005.362] Plugin Manager: Parse ODM data 0x00094000
[0005.372] shim_cmdline_install: /chosen/bootargs: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.387] Add serial number:1422419145039 as DT property
[0005.396] “bpmp” doesn’t exist, creating
[0005.401] Updated bpmp info to DTB
[0005.406] Updated initrd info to DTB
[0005.410] “proc-board” doesn’t exist, creating
[0005.415] Updated board info to DTB
[0005.418] “pmu-board” doesn’t exist, creating
[0005.424] Updated board info to DTB
[0005.427] “display-board” doesn’t exist, creating
[0005.433] Updated board info to DTB
[0005.436] “reset” doesn’t exist, creating
[0005.441] Updated reset info to DTB
[0005.444] Cmdline: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1
[0005.483] DTB cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0
[0005.495] boot image cmdline: root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 net.ifnames=0 logo.nologo
[0005.507] Updated bootarg info to DTB
[0005.511] Adding uuid 00000001644476410800000008070400 to DT
[0005.517] Adding eks info 0 to DT
[0005.522] WARNING: Failed to pass NS DRAM ranges to TOS, err: -7
[0005.528] Updated memory info to DTB
[0005.534] Updated system-lp0-disable info to DTB
[0005.542] set vdd_core voltage to 1075 mv
[0005.546] setting ‘vdd-core’ regulator to 1075000 micro volts
[0005.571] Found secure-pmc; disable BPMP
TEGRA210
DRAM: 4 GiB
In: serial
Out: serial
Err: serial
Scanning mmc 1:1…
733 bytes read in 82 ms (7.8 KiB/s)
1: primary kernel
5487751 bytes read in 319 ms (16.4 MiB/s)
34191368 bytes read in 1530 ms (21.3 MiB/s)
append: tegraid=21.1.2.0.0 ddr_die=4096M@2048M section=512M memtype=0 vpr_resize usb_port_owner_info=0 lane_owner_info=0 emc_max_dvfs=0 touch_id=0@63 video=tegrafb no_console_suspend=1 console=ttyS0,115200n8 debug_uartport=lsport,2 earlyprintk=uart8250-32bit,0x70006000 maxcpus=4 usbcore.old_scheme_first=1 lp0_vec=0x1000@0xff780000 core_edp_mv=1075 core_edp_ma=4000 tegra_fbmem=0x140000@0x92cb0000 is_hdmi_initialised=1 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 console=tty0 fbcon=map:0 net.ifnames=0 root=/dev/mmcblk0p1 rw rootwait rootfstype=ext4 console=ttyS0,115200n8 net.ifnames=0 logo.nologo quiet
Starting kernel …
Ok so does this match your request?
This is my request.
Could you share new cboot binary that support 1280x800 resolution or disable boot logo?
The boot logo has been disabled in #7, hasn’t it?
Currently there is still no official tool to change the resolution of bmp blob. You could check
https://devtalk.nvidia.com/default/topic/1065184/jetson-nano/hello-how-can-i-change-the-nvidia-boot-logo-to-my-own-/
- Yes, exactly.
- I got it. If so, can I disable HDMI initialization?
You could try to add bootloader-status=disabled under hdmi-display in your device tree.
Hi Wayne,
I tried to add bootloader-status=“disabled” in DTS, it still seems to be initializing HDMI.
Can you check what is wrong?
DTS and cboot log is as below.
host1x {
sor1 {
bootloader-status = “disabled”;
status = “okay”;
nvidia,ddc-i2c-bus = <&hdmi_ddc>;
nvidia,hpd-gpio = <&gpio ((28 * 8) + 1) 1>;
nvidia,active-panel = <&sor1_hdmi_display>;
hdmi-display {
status = “okay”;
compatible = “hdmi,display”;
generic-infoframe-type = <0x87>;
disp-default-out {
nvidia,out-type = <1>;
nvidia,out-flags = <(1 << 1)>;
nvidia,out-parent-clk = “pll_d2”;
nvidia,out-align = <0>;
nvidia,out-order = <0>;
hdmi_ddc: i2c@7000c700 {
clock-frequency = <100000>;
[0002.405] display console init
[0002.414] could not find regulator
[0002.417] hdmi cable connected
[0002.432] edid read success
[0002.435] width = 1280, height = 800, frequency = 75000000
[0002.440] Best mode Width = 640, Height = 480, freq = 25DT entry for leds-pwm not found
1[0002.452] 74825
[0002.455] tmds-config node not found
[0002.459] pmc_set_io_pad_voltage: Error -2 retrieving platform-io-pad-voltagepropsetting ‘avdd-io-hdmi-dp’ regulator to 1050000 micro volts
[0002.474] setting ‘vdd-1v8’ regulator to 1800000 micro volts
[0002.485] could not find regulator
[0002.488] could not find regulator
[0002.516] using default cmu settings
[0002.520] dc_hdmi_enable, starting HDMI initialisation
[0002.527] dc_hdmi_enable, HDMI initialisation complete
[0002.532] list and configure display window
[0002.536] display console init completed
[0002.544] subnode volume_up is not found !
[0002.548] subnode back is not found !
[0002.551] subnode volume_down is not found !
[0002.555] subnode menu is not found !
[0002.559] Gpio keyboard init success
[0002.576] blob_init: BMP partition does not have valid Blob
[0002.582] load_bmp_blob: BMP blob initialization failed
[0002.587] Could not load/initialize BMP blob…ignoring
[0002.638] decompressor handler not found
I just checked the notice bootloader-status only works for TX2/Xavier…
You could try to add “bootloader” under “chosen” in ./kernel-dts/tegra210-porg-p3448-common.dtsi
and add nvidia,skip-display-init. This would disable all monitor initialization in cboot.
chosen {
+ bootloader {
+ nvidia,skip-display-init;
Hi Wayne,
Finally it works.
Thank you for your kind support.
