How compile the kernel,DTS and update them into the target?
Software Version
[*] DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
[*] Linux
QNX
other
Hardware Platform
[*] other
SDK Manager Version
1.9.1.10844
[*] other
Host Machine Version
[*] native Ubuntu Linux 20.04 Host installed with SDK Manager
other
Hi sir
when I modify the kernel code and the dts in the /drive-linux/kernel/,how to compile them and flash them into the target?
Dear @sunjiandong,
Does Compiling the Kernel (NVIDIA DRIVE OS Linux) | NVIDIA Docs helps?
Hi
In the Doc, I can see it will use Bootburn tool to flash. So how to use the Bootburn to flash kernel and dtb separately?
Dear @sunjiandong,
Did you check Bootburn Usage | NVIDIA Docs
Hi sir,
So I can’t flash kernel image separately. It only flash all images together,
And our HW is p3710,which dts should be used?
Dear @sunjiandong,
After updating the Image and tegra234-p3710-0010-a01-linux-driveav-gos.dtb by(If you want to update device tree) following the “Compiling the Kernel” section guideline, -u parameter of bootburn can be used to flash single partition for kernel and dtb separately (should be -u A_1_kernel and -u A_1_kernel-dtb)
