system
1
How do I change the MAC address for a
MCX4131A-GCAT? Trying to change it using FLINT results in a cryptic error. Using Ubuntu 20.04 with the newest MFT software installed.
The reason I need to change the MAC address is that somehow it became corrupted and it now shows as 0000001234.
Any help with this would be appreciated.
chenh1
2
Hi Charles,
Please follow the below guide and let me know if it helps.
https://docs.mellanox.com/pages/viewpage.action?pageId=32411642
Regards,
Chen
system
3
Thank you so much for your response. I’m sure I would have eventually stumbled upon the correct documents, but you link makes my job so much easier.
Chuck Renfroe
Hardware Technical Lead
(270) 801-3015
system
4
the command listed on the page you send me results in the following error:
For Example:
#flint -d /dev/mst/mt4117_pciconf0 -ocr hw set Flash0.WriteProtected=disabled
-W- Firmware flash cache access is enabled. Running in this mode may cause the firmware to hang.
-E- Command “Hw” requires at most 1 arguments, but 2 arguments were given
Any ideas what I’m doing wrong? Keep in mind I followed the example in the link you provided exactly.
