I have tried installing with both the .deb and the .run file.
I cannot find the file physically that would run this application. Nor can I find a .desktop shortcut. Searching in gnome for “Nsight” or “Nvidia” or “Graphics” reveals nothing.
Assuming this is the default path, then in the following directory there would be an executable called ‘ngfx-ui’ that you can run to start the Nsight Graphics GUI.
/home/mike/nvidia/NVIDIA-Nsight-Graphics-2022.2/host/linux-desktop-nomad-x64
For beginners it is a bit tricky really. I was also lost to open the Nsight graphics It may help someone else in future, I downloaded .run and installed in the default location that is in the root directory. To open the SDK UI:
sudo su
cd /root/nvidia/NVIDIA-Nsight-Graphics-2022.4/host/linux-desktop-nomad-x64
./ngfx-ui
Thanks for the feedback to help out beginners using Nsight Graphics on Linux platforms. Also, I would point to the Nsight Graphics User Guide here User Guide :: Nsight Graphics Documentation which calls out that for Linux, the path to the executable is here <install_directory>/host/linux-desktop-nomad-x64/ngfx.bin.
