How do you delete 1 key frame?
Everything I have tried deletes all animation data, and the object.
I know how to remove all animation data, by finding an object and deleting ‘AnimationData’. In the Stage. In the Curve Editor, I don’t know what to do.
You select the keyframe and delete it? Or sit at the frame and right the keyframed property then delete. That’s from my memory.
@DataJuggler - simply select the key you wish to delete and press the red key icon in the curve editor.
Thank you. That works. I didn’t notice that little red dot is a button.
