I’m implementing a custom lidar plugin and trying to provide the point cloud in the in the returnData portion of the dwLidarDecodedPacket. I’ve set the availableReturns to DW_LIDAR_RETURN_TYPE_1 thru DW_LIDAR_RETURN_TYPE_6 so that I can have up to 6 returns. However, It seems that Driveworks only allocates storage for pointsPerSpin divided by 6 for the amount of points I can store in each returnData[] array. Is that correct? So if our Lidar puts out X rays per “spin”, but we can have up to 6 returns for each ray, then I really need to set pointsPerSpin to X*6 to have enough storage for my return data?
It appears that you have access to direct support through nvonline. Could you post your questions and seek support through it?
In the meantime, please check the checkboxes below to provide some additional information.
Software Version
DRIVE OS 6.0.6
DRIVE OS 6.0.5
DRIVE OS 6.0.4 (rev. 1)
DRIVE OS 6.0.4 SDK
other
Target Operating System
Linux
QNX
other
Hardware Platform
other
SDK Manager Version
1.9.2.10884
other
Host Machine Version
other
Software Version
DRIVE OS 6.0.5
Linux
Hardware Platform
N/A
SDK Manager Version
N/A
N/A
I’m not sure if I have support through nvonline. I tried logging in but my credentials don’t work there (neither does password recovery).
The maximum number of points per return is calculated by dividing ‘pointsPerPacket’ by the number of available returns set by ‘availableReturns’. I hope this explanation will help to clarify your confusion.
Ok, this was what I had gathered based on my experiments, but I wanted official confirmation. Thanks!
